Old 09-21-2006, 09:12 AM   #1
~flutterbee~'s Avatar
1996 25' Excella
southern , Illinois
door gasket for '96 Excella
I ran a search & I'm not finding the info I need.
Our existing entry door gasket has separated up on the top corner, allowing water to seep through during a downpour...it looks like the underlying foam material is falling apart.. I'm guessing it can't be reglued, correct me if I'm wrong. Do we need to replace the whole thing? If so, where do we get the gasket? An earlier thread mentioned that they used the same type of gasket from way back all the way through to the mid 90's... but nothing on the newer gasket material.
Many Thanks Kelly
Go confidently in the direction of your dreams! Live the life you've imagined. As you simplify your life, the laws of the universe will be simpler. ~ Henry David Thoreau
~flutterbee~ is offline   Reply With Quote
Old 09-24-2006, 12:11 PM   #2
Many Thanks Kelly
The entrance door gasket must be one piece, and seamed at the bottom of the door.
We, along with a few other Airstream dealers, carry that gasket in stock.
Make sure you install the new gasket with a "super adhesive" only.
Door gasket for '97 Excella Knudsvig Doors & Locks 0 05-07-2015 02:04 PM
The Right Gasket for Door in Door mhutchinson Leaks - Weatherstrips, Gaskets, Caulks & Sealants 3 11-23-2012 04:04 AM
Gasket on door or inside of door? Becky B. Leaks - Weatherstrips, Gaskets, Caulks & Sealants 14 07-06-2007 01:06 PM
Need screen door gasket for '56 Flying Cloud cdmagda Doors & Locks 0 06-22-2005 08:07 AM
Price comparison for door/window gasket sets. millionairstream Leaks - Weatherstrips, Gaskets, Caulks & Sealants 5 05-07-2004 04:59 PM
