Old 04-13-2009, 08:48 PM   #1
Natalbany , Louisiana
Door gasket
How do I remove the old gasket and glue from the door frame?
Sjean is offline   Reply With Quote
Old 04-13-2009, 10:10 PM   #2
Melody Ranch's Avatar
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
what I am doing
Use a stiff blade to peal the gasket. Then use MEK (plenty of vent and don't get it on your skin) with a small brass brush. Final wipe clean with the MEK.
Old 04-14-2009, 12:09 AM   #3
gasket removal
You can cut off as best you can, the gasket from the entrance door, the windows and access doors.
Then simply "burnish" off whats left by using a wire wheel in an electric drill.
No need to use any harsch chemicals.
Old 04-14-2009, 03:02 AM   #4
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 40
I use a brass wire wheel in an angle grinder. MEK is not good stuff to be messing with unless absolutely necessary.
Aaron
WBCCI #XXXX AIR #2495
Old 04-14-2009, 05:00 AM   #5
Uberphotos's Avatar
1968 22' Safari
Kalamazoo , Michigan
I also just used a putty knife (stiff) and wire brush. I did try to use some "goo be gone", but that didn't really do anything.
'68 Safari Land Yacht, Double
Check out my blog... http://ssairstream.blogspot.com/
Uberphotos is offline   Reply With Quote
Old 04-14-2009, 06:37 AM   #6
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
Good idea...and it worked
Glad I saw this in time too. I stopped with the MEK and used the brass 3" brush on a drill....worked great and did not screw up the aluminum.
Old 04-14-2009, 08:22 AM   #7
AirstreamGypsy's Avatar
1961 16' Bambi
Mancos , Colorado
Send a message via Skype™ to AirstreamGypsy
I tried using a 3" wire brush on a drill but it seems to leave mark on the aluminum. I realize it will be behind the new seal but it makes me crazy. This brush is "fine" and is silver. All I could find at HD. I really wanted the ones that look like sandpaper folded. I might do the MEK outside after all.
AirstreamGypsy
___________
Charter Member FCU • WBCCI 1818 • CP(Courtesy Parking) • Wi-Fi
My Earthship
AirstreamGypsy is offline   Reply With Quote
Old 04-14-2009, 08:36 AM   #8
What is the best adhesive to use to apply the new gasket?
Old 04-14-2009, 08:47 AM   #9
reggiemon's Avatar
1959 18' "Footer"
Corpus Christi , Texas
I found that "De-Solv-It" actually works well if you use a brass brush & scraper with multiple applications. It seems like it is not going to work at first but with a few applications the old adhesive starts to come off. It’s safe to use.
http://www.orange-sol.com/household/index.html
It won’t be as fast as the wire brush & drill.
I was very impressed with the 3M Super Weatherstrip adhesive that Andy recommends & sells.
http://www.inlandrv.com/catalog/images/51991.JPG
1959 "Globester"
reggiemon is offline   Reply With Quote
Old 04-14-2009, 08:50 AM   #10
silverleeper's Avatar
1967 22' Safari
1960 Caravel
Edmonds , Washington
Images: 8
Originally Posted by Sjean View Post
Hi Sjean, I've used this 3M weatherstrip adhesive with great success.
Lee
1973 F-250 4X4 390
1965 Chevy Suburban 454
AIR 6030
WBCCI 4258
TCT
silverleeper is offline   Reply With Quote
Old 04-14-2009, 08:57 AM   #11
3M8008, which is the black automotive adhesive.
It's far superior for gaskets that are exposed to weather, than the yellow stuff.
Old 04-14-2009, 09:39 AM   #12
Aerowood's Avatar
1971 21' Globetrotter
Arvada , Colorado
You might try one of these products. They will not damage the surfaces
Kip
Old 04-14-2009, 11:00 AM   #13
1961 16' Bambi
Mancos , Colorado
Kip
Thanks Kip! Just what I wanted.
AirstreamGypsy
___________
My Earthship
Old 06-08-2009, 12:02 PM   #14
Ottawa , ON
Hmmm. I just ordered new weatherstripping and was told that it's peel & stick.
Whaddup wid dat?
The Right Gasket for Door in Door mhutchinson Leaks - Weatherstrips, Gaskets, Caulks & Sealants 3 11-23-2012 04:04 AM
Gasket on door or inside of door? Becky B. Leaks - Weatherstrips, Gaskets, Caulks & Sealants 14 07-06-2007 01:06 PM
Leaking door gasket TrailerTramp Doors & Locks 5 05-12-2006 01:24 PM
Need screen door gasket for '56 Flying Cloud cdmagda Doors & Locks 0 06-22-2005 08:07 AM
Price comparison for door/window gasket sets. millionairstream Leaks - Weatherstrips, Gaskets, Caulks & Sealants 5 05-07-2004 04:59 PM
