Old 08-30-2015, 06:28 PM   #1
JLGT5107's Avatar
1965 20' Globetrotter
Fairfield , Connecticut
Door fixed
After much trepidation, I have taken on the door repair. It appears that a previous owner expeienced the "loose door at highwy speed mishap" It has haunted me since purchase. I purchased trailer at a tag sale with no real idea of what I was getting into. The previous owner had rigged door with a brace to
compensate for break, so it was not apparent how bad the damage was. When I removed the brace I realized that the frame was badly damaged. In my mind I pictured a mass of fractured pot metal held together with sealer behind the skins. I considered replacing the door, but found them rare and expensive.
My repair cost about $250 with welding and misc.
ID:	246824   Click image for larger version
ID:	246826   Click image for larger version
ID:	246828   Click image for larger version
ID:	246830   Click image for larger version
ID:	246832   Click image for larger version
JLGT5107 is offline   Reply With Quote
Old 08-30-2015, 06:34 PM   #2
Regular Guy
NavyCorpsman's Avatar
1978 31' Sovereign
Hot Springs , Arkansas
Very, very nice!
NavyCorpsman is offline   Reply With Quote
Old 08-30-2015, 06:46 PM   #3
JLGT5107's Avatar
Door fixed 2
As the pictures show, I drilled rivets to remove door then made cradle to preseve shape for welding. I first used 2x8 fir but that twisted before I brought to my welder. I remade with ac plywood. After welding I used grinder with flap sander which I loaded with wax to prevent loading. Did first pass polishing on bench and then bucked skin to frame. I replaced Knob and deadbolt which required patching over previous holes.
ID:	246838   Click image for larger version
ID:	246840   Click image for larger version
ID:	246842   Click image for larger version
broken folding door - can this be fixed? jim1949 General Interior Topics 8 06-27-2015 01:14 AM
shower door latch fixed pal50 Sinks, Showers & Toilets 5 09-06-2013 05:10 AM
Fixed that dump valve !!! 77caravaner Waste Systems, Tanks & Totes 1 05-21-2010 05:55 PM
It's Fixed! swebster Mechanics Corner - Engines, Transmission & More... 7 08-08-2003 06:00 PM
Problem fixed lbrodsky 2001 Safari 1 12-16-2002 08:42 AM
