Old 01-07-2016, 11:14 AM   #1
Westminster , Colorado
Door fabricator
I have a door I'm not able to fix myself. Would you tell me who you recommend to reshape a door, or where to look for a new door?
Thanks!!
Name:	ImageUploadedByAirstream Forums1452190434.743647.jpg
Name:	ImageUploadedByAirstream Forums1452190451.649764.jpg
ID:	255289Click image for larger version
Name:	ImageUploadedByAirstream Forums1452190466.807542.jpg
painterfam is offline   Reply With Quote
Old 01-07-2016, 11:31 AM   #2
1972 27' Overlander
Woodburn , Oregon
What happened to the door to make it look like that ? Can't imagine
shineybullet is offline   Reply With Quote
Old 01-07-2016, 10:49 PM   #3
@shineybullet - it was pinched when I bought it. My guess is after the door sprang, it was letting in water, and this was their solution. We unpinched it, and it looks worse than if we would have left it!!!
I had a bumper that was taken off, and had to be put back on...a 3" canyon cut out of one of the main support beams to make room for 4" residential plumbing that obviously doesn't fit...so they had to jerry rig it under the belly pan (that was also cut to shreds).
I am guessing that it was a tiny house for grandma and grandpa in someone's back yard, and the person "fixing" the trailer knew enough to be dangerous, but not enough to actually fix anything :/
Old 01-09-2016, 05:45 PM   #4
sgschwend's Avatar
1986 25' Sovereign
2008 F350, 6.4L diesel , Oak Harbor, WA
Images: 13
Can you send me picture of the damged door? Or PM me. I might be able to find the time to make you a new one. I have reshaped mine it was 1 1/2" out at the top and bottom. Must have been hit with a big wind. If I can see the view of the door and it's profile I might be able to help you so that you could fix it.
I just can't make out what I am looking at, try backing up a bit and shoot pictures at both angles.
Steve
sgschwend is offline   Reply With Quote
Old 01-12-2016, 04:47 PM   #5
Name:	ImageUploadedByAirstream Forums1452642398.954821.jpg
ID:	255630Click image for larger version
Name:	ImageUploadedByAirstream Forums1452642419.848078.jpg
ID:	255631Click image for larger version
Name:	ImageUploadedByAirstream Forums1452642432.335027.jpg
Maybe these will be helpful. It is really hard to know what you're looking at with out seeing it in person.
Thanks for taking a look!!
Old 01-12-2016, 10:13 PM   #6
sgschwend's Avatar
1986 25' Sovereign
Images: 13
So the door is in pieces?
It had a center panel/widow?
I did post a repair video on youtube, titled: Airstream door alignment repair. Shows how I fixed mine. The door do come apart quite easily.
1964 door in a Door entry door hinges recycled Windows, Doors, Locks & Vents 1 09-18-2013 06:07 PM
Commercial Airstream Fabricator curious12 General Repair Forum 7 12-27-2012 12:54 AM
Frame Fabricator Needed in Alabama Benjo Repairing/Replacing Floor &/or Frame 14 01-30-2011 07:03 PM
Door in a door '53 cloud inner door size. Flysoncloud Doors & Locks 13 09-18-2010 07:10 PM
