Door Dead Bolt Adjustment
I'll give you the solution right away. Compress the rubber seal in front of it. You'll notice a little metal plate. Stick a screw driver between the door and that little plate and push it back out. Done.
The plate is a guide. It got mashed in because we were trying to close the door with the dead bolt engaged.
No need for a service repair call or being all upset at Airstream.
I had a problem with my door dead bolt not being adjusted properly. It wouldn't engage the hole. It was completely out of line. And it was all my fault!!!
