Old 11-28-2005, 10:36 AM   #15
Images: 59
I think that must be a doctored picture, because when I invented the 'doohickey' the patent office approved the application without delay.
They would never approve the patent if it had been invented by someone else.
Those of you that are using my doohickey without licence will be hearing from my attorney.
Old 11-28-2005, 11:01 AM   #16
Ken J's Avatar
1956 22' Flying Cloud
Durango , Colorado
Images: 14
Well..... its obvious to me that is not a doctored picture - seems to me Wally stole an idea that was patiented? double hmmmmmm ya know the more I look at those old sob trailers, the more I've seen show up on Airstream trailers - Could Wally be just a good marketer of trailers that were copies of other trialers ??? Perhaps it was not the market that put those other trailer companies out of business??? Perhaps his handcarved deadbolt is a disguised missle????? triple hmmmmm
1956 Flying Cloud
Founder :
Four Corners Unit
Albuquerque National Balloon Fiesta
Rally
Vintage Trailer Academy - Formerly the original
restoration rally
Ken J is offline   Reply With Quote
Old 11-28-2005, 11:57 AM   #17
summerkid's Avatar
1956 16' Bubble
Rose Lodge , Oregon
Terry, can you post a pic of the eave deployment? I don't have the grab bar.
Of course I'm an elitist. Look around you.
summerkid is offline   Reply With Quote
Old 11-28-2005, 12:34 PM   #18
Stefrobrts's Avatar
1968 17' Caravel
Battle Ground , Washington
Images: 50
Originally Posted by 65GT
I don't know where you folks are all traveling to, but I don't think I've been on a single trip where that wouldn't get jostled out a dozen times by the roads I've been on! How often do you find that's fallen out in your travels? I'm guessing the attached lanyard is an indicator that it does fall out?
__
Three years of travel, including all the way to OK and back, and it's never fallen out yet (not even in KS)!
Love the pic, guys The mystery deepens...
Stephanie
Old 09-09-2009, 08:22 AM   #19
Tom, the Uber Disney Fan
Minnie's Mate's Avatar
2006 30' Safari
Orlando , Florida
Originally Posted by Stefrobrts View Post
I have a doohickey that came with my trailer, a home-made deadbolt, if you will. It fits on the grab handle by the door and keeps the door from popping open while travelling. When not being used it hangs on a hook just inside the door. Very simple, and works. Mr Grisso, the PO of my trailer, whipped it up, and I think it's just a great idea. I love low-tech solutions, so I thought I'd share.
Thanks for posting the photo Stef. I have been planning on making one for our Airstream. I think I can make one even with my limited skills. I remembered that there was a safety mechanism to keep it from getting lost but I couldn't remember how it was configured. These photos show me how it works. Now what did I do with my band saw?
Family of Disney Fanatics
WBCCI# 4821
Old 09-09-2009, 10:01 AM   #20
frlcad5's Avatar
2000 28' Excella
Stewartstown , Pennsylvania
Smile
I have been using a common doorstop that I bought for less than a buck for years. I drilled a hole in it and inserted a bungie with a plastic knob on it through the hole. I secure the bungie to the handle and slide the doorstop through the handle and wedge the door shut. It doesn't mar or fall out and can be easily removed and hung up in the trailer. No, I didn't invent either the doorstop or the bungie but both work together well to keep the door shut while traveling.
frlcad5 is offline   Reply With Quote
Old 09-09-2009, 10:25 AM   #21
frlcad5's Avatar
2000 28' Excella
Smile
See attached pictures.
ID:	86904   Click image for larger version
Old 09-09-2009, 10:50 AM   #22
Stefrobrts's Avatar
1968 17' Caravel
Images: 50
Brilliant, and simple!
Stephanie
Old 09-09-2009, 02:43 PM   #23
HowieE's Avatar
Princeton , New Jersey
Images: 12
Sure could have used one of these ideas 2 weeks ago. Lost both the deadbolt and the door latch while headed south and had to come up with something on the spot.
2004 Excursion 4x4
Old 09-09-2009, 08:09 PM   #24
Doohickey's Avatar
2009 19' Flying Cloud
Bordentown , New Jersey
Hey....
Doohickey is offline   Reply With Quote
Old 09-09-2009, 08:43 PM   #25
cosmos's Avatar
1965 17' Caravel
Birmingham , Alabama
Images: 8
Doohicky
I'm still giggling at this thread. Good info and too funny. Thanks for the picture, Stephanie, If my Caravel's door ever gets fixed I'll make one. In the mean time the PO had this door fly open and cracked the door casting. Then he fixed the crack by pop riveting a strap over the crack. Nice, but the door flexes now and it doesn't close tight at the lower front edge. Here's my semi - permanent solution. A sort of dead bolt with removable bolt. I push the door closed with my knee and slip the bolt in place. Voila, the door gasket fits weather tight in the lower corner and I can tow with rainproof confidence. When camping I keep the bolt in the trailer to keep pranksters from locking us in. Also I have this bolt as a backup to be sure the door doesn't fly open... a sort of doohicky jr. Anyway, it works for now and someday I can get around to doorframe surgery.
cosmos is offline   Reply With Quote
Old 09-09-2009, 10:03 PM   #26
FreshAir's Avatar
1966 24' Tradewind
Placerville , California
Here is mine...
I like the contrasting color. I can instantly see if it is in place.
Neil.
Name:	Airstream.Door Latch and suicide Lock 002.jpg
Neil and Lynn Holman
FreshAir #12407
Avatar;
1966 Trade Wind
455 cid
1969 Oldsmobile Ninety Eight
455 cid
Old 09-09-2009, 11:26 PM   #27
2005 22' Safari
Gresham , Oregon
Neil.
Looks good, but what is it made of and where do you get it?
Also if the door is locked and deadlocked what are the possibilies of the door opening? We just thought that if both locks were latched, it would be fine>
sempi2 is offline   Reply With Quote
Old 09-09-2009, 11:52 PM   #28
TBRich's Avatar
2006 19' Safari SE
Tucson , Arizona
Images: 64
Has anyone had a door that was double-locked come open in transit on a newer AS? If so I want to know about it!
TB & Greg and Abbey Schnauzer
#3954
