Old 10-10-2007, 09:56 PM   #1
Islay - 63 O.
dufferin's Avatar
Montreal , -
Images: 11
Send a message via MSN to dufferin
don't get lock outside with recent unit
Hi
I figure out tonight without any consequence but it could have been different that with a recent unit (mine is 2007) the lock pin can be put on lock position just by mistake goin out of the trailer and leave you outside your unit.
I did it but noticed it just before closing the door...
it would have been a bad night
Canadian Atlantic Unit Past President
Protect your dream from others and first yourself...
Few rolling wheels to make our planet a house.
A 1/5th of her that I own.
TAC# : QC-1
my blog
http://rvcampreview.com
dufferin is offline   Reply With Quote
Old 10-10-2007, 10:11 PM   #2
CanoeStream's Avatar
St. Cloud , Minnesota
That doesn't sound like fun! Maybe I should give in and call Inland -- http://www.airforums.com/forums/f453...fix-32012.html
5 meter Langford Nahanni
Old 10-10-2007, 10:23 PM   #3
TBRich's Avatar
2006 19' Safari SE
Tucson , Arizona
Images: 64
Yes, do...I'd recommend it...those locks are (A) lockable while the door is open, then when you close the door, it's locked...and (B) can fall into the "locked" position if the door happens to slam... in fact, it doesn't even take a "slam" for it to happen...
We did the fix offered free by Inland RV...it's an easy fix, and makes the latch lever have more "tension" so it doesn't move as easily on its own...
Just send then an envelope and they'll send you the fix and instructions...takes 5 or 10 minutes to do...
TB
Old 10-10-2007, 10:34 PM   #4
Islay - 63 O.
dufferin's Avatar
Montreal , -
Images: 11
thanks for the link...
does the fix prevent to engage the lock when the door is open. Mine was engage with my sleeve I assume...
TAC# : QC-1
my blog
Old 10-10-2007, 11:04 PM   #5
TBRich's Avatar
2006 19' Safari SE
Tucson , Arizona
Images: 64
No...you can still lock the door before it's closed, but because the latch lever doesn't move as freely, it's much less likely to happen accidentally...
TB
Old 10-10-2007, 11:19 PM   #6
Islay - 63 O.
dufferin's Avatar
Montreal , -
Images: 11
ok... so I may adopt the small cable idea I saw on the Entrance door lock fix thread.
TAC# : QC-1
my blog
Pensacola Unit vs. Big Bend Tallahasse Unit gypsymoth WBCCI Forum 23 04-07-2013 11:19 AM
New Members Seek Recent Model Used A/S twall7 Member Introductions 5 09-23-2007 03:43 PM
A pictures from recent trip... Van On The Road... 12 09-02-2005 10:30 PM
Vintage v. Recent Models Jan Our Community 22 09-06-2003 10:49 AM
