Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Windows, Doors, Locks & Vents > Doors & Locks
Old 02-10-2009, 06:05 PM   #1
Mini Rivet
bmklawt's Avatar
1975 25' Tradewind
Holland , Michigan
Do you need a Bargman L400
I thought I had read in the past here on the forums that a Bargman L-400 lock was hard to come by.
I happen to see a new one at the RV place today if anyone needs it. It's grey not shiny like I have seen on coaches, it is missing the plate and handle for the inside and it's a little scratch up but it is new with keys.
If you need it let me know and I'll go get it.
I think it was $69.99
Bruce,
Parts needed: Sink for rear bath Tradewind
My blog for the 1975 Tradewind restoration
bmklawt is offline   Reply With Quote
Old 02-11-2009, 01:16 PM   #2
Silverhobby's Avatar
Greeeneville , Tennessee
The L-400 has been obsolete since the early 90's when Avion and Holiday Rambler quit using the locks. They do show up on ebay and a few dealers may have them in their older inventory. It is a difficult to find lock. Thanks for posting.
//------AIR # 7303------\\
WBCCI 17109
visit my restoration blog at:
Old 02-17-2009, 07:02 PM   #3
1976 25' Caravanner
Campton , New Hampshire
They must be back , I've seen them listed in several of the RV supply books , the one you see at most RV deralers.
ticki2 is offline   Reply With Quote
Old 05-29-2009, 09:40 PM   #4
Check the part numbers. There are many Bargman locks, but NOT the L-400.
WBCCI 17109
Old 05-29-2009, 09:56 PM   #5
Vintage Alum. Enthusiast
flyfshr's Avatar
1959 24' Tradewind
Phoenix , Arizona
Images: 40
Bargman Door Locks
Here's a couple but which one is the L-400?
FF
ID:	81145   Click image for larger version
4CU 2699 / AIR 10 / TAC AZ-1
I'm haunted by aluminum.
flyfshr is offline   Reply With Quote
Old 11-06-2009, 07:57 AM   #6
Bargman Locks
The locks picture are labeled in the text, counterclockwise, L-100, L-66, L-77, various catches, L-66 Hand L Lock, L-77 Verti Lock, # 22 Porch Light assist Bar. None of these is the L-400. Pictured is the L-400 installed on my Avion. The L-400 lock was also used on Holiday Rambler and possibly the Silver Streak.
Name:	L-400 Bargman lock.JPG
WBCCI 17109
Old 07-06-2010, 06:44 PM   #7
Croton , Ohio
I noticed a repair kit on eBay for the Bargman L-400 lock. It's item number 200492622427.
graydude is offline   Reply With Quote
Old 07-08-2010, 06:53 PM   #8
Croton , Ohio
That lock repair set sold already...but there is one more for sale. It is eBay item number 200493497289.
Old 08-16-2010, 11:58 AM   #9
clydecrashcu's Avatar
1984 31' Excella
1976 Argosy 24
Olsburg , Kansas
door handle fits what
What years did the L400 fit?
clydecrashcu is offline   Reply With Quote
Old 08-16-2010, 02:54 PM   #10
Never any Airstream or Argosy trailers or motorhomes.
Andy Rogozinski
Inland RV Center
Corona, CA
Old 08-17-2010, 07:43 AM   #11
1984 31' Excella
1976 Argosy 24
Olsburg , Kansas
door handle
Andy your post was very helpful to me and I am sure others that may read the original post.
Old 08-17-2010, 09:16 AM   #12
1977 Argosy 24
Milltown , Wisconsin
A friend of mine has a 1975 Argosy that had an L400. Are you saying that this was not the original lock? If not what is the correct lock for a 1975 Argosy?
ventport is offline   Reply With Quote
Old 08-17-2010, 10:27 AM   #13
locks
The early Argosy trailers, up to 1977, used the KT lock. Airstream trailers used the KT lock from 1970 thru 1977.
The problem with the L-400, is that the striker bolt, is not long enough, compared to the KT lock.
The attached photo clearly shows the difference of the striker bolt. Also, the L-400 is smaller, which would require an adapter plate to cover the original KT lock hole.
The L-400 would have to be disassembled, cut the striker bolt in half, weld on an extension, reassemble the lock, and hope the weld doesn't break, down the road. If it did break, you will not be able to open the entrance door.
Granted, the price difference is huge, and so is the gamble.
Andy Rogozinski
Inland RV Center
Corona, CA
Old 08-17-2010, 10:33 AM   #14
Sorry about that.
Andy Rogozinski
Inland RV Center
Corona, CA
Old 08-17-2010, 11:59 AM   #15
1977 Argosy 24
Do you have a picture of the KT lock, is it still available?
Old 08-17-2010, 12:20 PM   #16
I have no idea why the labels for the above photo's did not show.
The top lock is the "KT" lock.
The bottom lock is the Bargmann L-400 lock.
The KT lock is still available, but expensive.
Depending on the year trailer, there are kits available that replace the KT lock, that cost much less, but plates must be added to the door.
Andy Rogozinski
Inland RV Center
Corona, CA
Old 08-17-2010, 12:54 PM   #17
1977 Argosy 24
Thanks Andy for clearing that up. We have been looking for the wrong door lock.
Old 08-31-2010, 10:17 AM   #18
spring , Texas
Andy, I just jumped into this message trail and found it fitting. Possilbly you can help me as well. I have broken the door handle on my trailer. the handel ID says Theodore Bargman model 10-40-010 on the lock plate and 10-40-030 on the handle plate. Best I can tell the package looks just like a Bagman L400 which reports to be 6 7/8"x2 3/4". My latch is 6 1/4x 2 1/4". I am new at this and am not sure where to find a L400 of if it might fit. any thoughts you might share would be great.
MORGRM is offline   Reply With Quote
Old 08-31-2010, 10:34 AM   #19
That indeed is the L-400, but the dimensions on the outside are 6 7/8 X 2 7/8.
However, the markings on the inside and outside plates, match your numbers.
Andy Rogozinski
Inland RV Center
Corona, CA
Old 12-09-2010, 08:20 AM   #20
Cypress , Texas
I managed to find an L400 to replace the one on my trialer. It was gray and not chrome. It also had a different bolt than the original and it too some modification tot he bolt and spacer. I used the bolt from the old lock and between the old lock and the new one got one good lock for the trailer. I kept the old lock for potential spares.
Ken
TXiceman is offline   Reply With Quote
Bargman '86... S C Streamer Lights - Interior & Exterior 11 05-19-2015 03:33 PM
Bargman L300 Ramp Doors & Locks 11 07-07-2009 06:16 PM
Bargman 99 lights gwchitty Electrical - Systems, Generators, Batteries & Solar 9 10-04-2007 04:39 AM
Bargman 99 Question Number99 Lights - Interior & Exterior 18 07-08-2006 10:07 PM
