Old 04-21-2008, 06:25 PM   #1
Becky B.'s Avatar
1964 17' Bambi II
Schererville , Indiana
Do I have this on wrong?
I tried all the tricks to get this door to shut better after replacing the gasket. I'm now wondering if I've placed on on wrong. Glued it to the door itself as instructed. The problem is, the door is really hard to shut from the inside. I had to put a rope on it to pull with so I don't wreck the lock/handle! As you can see from the pictures, the door dojob is kind of hung up on the gasket. What would happen if I trimmed the gasket from around the dojob (sorry, having a total mind blank about what that thingy is!). Would the water that may get in continue down the gasket, or come in the door? Well, I'll let all of you tell me what to do!
Becky
1964 Bambi II
1988 Avion 32S
Becky B. is offline   Reply With Quote
Old 04-21-2008, 06:32 PM   #2
53flyingcloud's Avatar
1984 29' Sovereign
Savannah , Missouri
I am not sure what going on but..I can't see pictures of your door gasket..??
53flyingcloud is offline   Reply With Quote
Old 04-21-2008, 06:37 PM   #3
Becky B.'s Avatar
1964 17' Bambi II
I'm not sure if anyone can open these......My computer puked last week & I lost my program to shrink pix. Does this work?
Becky
1964 Bambi II
1988 Avion 32S
Old 04-21-2008, 06:44 PM   #4
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
I converted your pictures to JPEG format, maybe this will help...
Name:	gasket door problem 4.jpg
ID:	58773   Click image for larger version
Name:	gasket problem door 1.jpg
Name:	gasket problem door 2.jpg
Richard
Old 04-21-2008, 06:44 PM   #5
Becky B.'s Avatar
1964 17' Bambi II
Let me try again.....
ID:	58776   Click image for larger version
Becky
1964 Bambi II
1988 Avion 32S
Old 04-21-2008, 06:44 PM   #6
Rivets?
nvestysly's Avatar
1992 29' Excella
2010 22' Interstate
Van By The River , Georgia
I Can Open the Pictures
I was able to open the pictures. I simply clicked on each link and my computer asked me if I wanted to save or open the file.
I don't know if the gasket is installed correctly or not. It does appear to be quite a thick gasket based on the picture showing it bulging behind the latch.
Lucius
Lucius and Danielle
1992 29' Excella Classic
1996 GMC Suburban C2500 7.4L
2005 Chevrolet Suburban K2500 8.1L
Got a cooped-up feeling, gotta get out of town, got those Airstream campin' blues...
nvestysly is offline   Reply With Quote
Old 04-21-2008, 06:45 PM   #7
Becky B.'s Avatar
1964 17' Bambi II
Thanks, Richard!
Becky
1964 Bambi II
1988 Avion 32S
Old 04-21-2008, 06:48 PM   #8
Journalist's Avatar
1969 25' Tradewind
Irmo , South Carolina
You sure that's the correct gasket for that particular year? New gaskets are always a little difficult at first, but that looks like it may continue to be a headache for years to come.
AIR #8891
Unrestored 1969 25' Tradewind
Overkill Tow Vehicle of the Year Award:
2001 GMC 3500 4x4 Dually 6.6L Duramax
Journalist is offline   Reply With Quote
Old 04-21-2008, 06:53 PM   #9
Becky B.'s Avatar
1964 17' Bambi II
Well, I ordered it from Inland & they assured me it was the right one. I don't have a chunk of the one I took off, as I redid it last fall. I figured it had to break in, but that doesn't seem to be the case here.
Becky
1964 Bambi II
1988 Avion 32S
Old 04-21-2008, 06:57 PM   #10
Melody Ranch's Avatar
1956 22' Flying Cloud
1953 32' Liner
1955 22' Safari
Valley View , Texas
Images: 78
suggestion #1
Trim the gasget from the latch....so that the latch is not rubbing the gasket. Other than that it looks O.K. Just use it till it settles in. Mine took several months.
Old 04-21-2008, 07:00 PM   #11
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
That's what I did with ours. It works fine, but the door requires more force to close since the gasket now actually contacts the frame.
Old 04-21-2008, 07:00 PM   #12
Becky B.'s Avatar
1964 17' Bambi II
That was my thought, but will I get water in the door if I trim it around the LATCH (thank you very much for the missing word!)
Becky
1964 Bambi II
1988 Avion 32S
Old 04-21-2008, 07:02 PM   #13
Journalist's Avatar
1969 25' Tradewind
If anyone knows which one is the correct one, Inland would be the folks who do. I'd take the above advice and trim it back from the latch. Luckily, we're coming into the summer months, so maybe the heat will help it settle in.
AIR #8891
Old 04-21-2008, 07:02 PM   #14
Well Preserved
1993 21' Sovereign
As long as you just trim enough to get the latch to work, you shouldn't have a problem.
What's wrong... rickandsandi Off Topic Forum 18 08-07-2007 05:59 PM
What did I do wrong Roadtoaster Electrical - Systems, Generators, Batteries & Solar 1 10-16-2006 03:32 PM
What is wrong with? 53flyingcloud On The Road... 20 06-15-2004 04:20 PM
I Was Wrong Happycampers Clearcoat, Exterior Paint & Trim 7 04-09-2004 12:14 PM
Something wrong with.. 53flyingcloud Our Community 7 11-24-2003 02:30 PM
