Old 05-31-2009, 07:57 PM   #1
1991 29' Excella
fort worth , Texas
Deadbolt Lock
I have a 1991, Classic Excella. The Deadbolt Key will not lock or unlock. Any suggestions?
charlie g is offline   Reply With Quote
Old 10-18-2009, 08:06 PM   #2
1984 31' Excella
Bel Air , Maryland
I know I need to push or pull on the door to take the pressure off the door, then turn the lock. I have a groove in my bolt so it does not slide.
Two Adults, Four Kids, and a Dog camping in an Airstream. We must be crazy!
Silverscream is offline   Reply With Quote
Old 10-18-2009, 10:20 PM   #3
gail's Avatar
2017 16' Sport
Malibu , California
We replaced ours with a new deadbolt. olld locks not always easy to fix
gail is offline   Reply With Quote
Old 10-19-2009, 05:51 AM   #4
1977 31' Sovereign
1989 34' Excella
Johnsburg , Illinois
Check the alignment to see whether the bolt is able to enter the pocket. The door alignment may have shifted or the door hinge pins may have worn. Sometimes you need to pick up on the door to get the alignment right. Once you see that it will work with better alignment then you need to adjust the door hinge adjustments.
Old 10-19-2009, 06:55 AM   #5
willyd's Avatar
1993 34' Limited
Melbourne Florida , Springfield Ohio
You might also check the level of the trailer - could be in a slight bind which will affect the lock.
willyd is offline   Reply With Quote
Old 10-19-2009, 10:05 AM   #6
richinny's Avatar
2011 34' Classic
does the deadbolt move if the door is open when the key is turned? or does the key not turn?
Ricky
The deadbolt lock repair 82skadoo Member Introductions 2 04-19-2008 04:01 PM
Installing a new deadbolt lock Moonshot Doors & Locks 7 10-08-2007 03:44 PM
deadbolt lock John Greenlee Windows & Screens 2 07-10-2004 09:33 AM
Deadbolt Gunnyusmc Doors & Locks 2 09-12-2003 06:02 AM
deadbolt with inside twist style lock cindy Doors & Locks 4 10-16-2002 08:58 PM
