Old 05-31-2016, 11:23 AM   #1
3dawgnight's Avatar
2016 30' International
Fort Lauderdale , Florida
Dead bolt lock not locking
We have a brand new 2016 International. We seem to have a problem with the deadbolt lock. We cannot lock the deadbolt from the inside and have trouble locking it from the outside without putting a lot of pressure on the door. Has anyone else had this problem? Is this an easy fix or do we need to drive 3 hours to the dealership to have it fixed?
3dawgnight is offline   Reply With Quote
Old 05-31-2016, 11:54 AM   #2
HowieE's Avatar
Princeton , New Jersey
Images: 12
If the door is fitting fine you can file the hole in the door towards the inside a bit. That will lessen the need to push on the door to lock it.
Before making any adjustments to the dead bolt in the form of filing the hole bigger make sure the door itself is fitting properly.
Your trailer should be under warranty but then again I would be sure the dealer you got it from has decent reviews on service before going there.
2004 Excursion 4x4
Old 05-31-2016, 12:05 PM   #3
ShinyPete
ShinyPete's Avatar
2014 27' Flying Cloud
Bushnell , Florida
If your coach is really really new, it may just be the gasket around the door isn't compressed that much yet.
This may get easier with a little time. I certainly wouldn't "adjust" anything until the gasket compressed some.......
Hope this helps.
ShinyPete is offline   Reply With Quote
Old 05-31-2016, 01:31 PM   #4
PKI
PKI's Avatar
2015 23' FB Flying Cloud
Walnut Creek , California
Yes, we had the problem. Plan a weekend camping trip and include the a dealer service appointment. If your dealer is not a recommended service group, go to one that is. Until you get it fixed, be gentle. Pat
PS, there is a video about door alignment. U-tube search?
Old 06-01-2016, 11:30 AM   #5
2012 23' Flying Cloud
Valley Cottage , New York
Twist and slam
I have the same problem with the dead bolt lock on my 2012 FC 23'. I have to insert the key, close the door, twist key in direction of locking(left), back to middle, then open the door and close with a mild SLAM, then lock it. It's a pain, but the initial turn seems to align things up so it will lock. Try it but don't slam in lock position. Good luck!
POP2U is offline   Reply With Quote
Old 06-01-2016, 11:38 AM   #6
2016 23' Flying Cloud
Corpus Christi , Texas
Dead bolt lock
Yes, had same problem with 2016FC. Back to dealer - door not aligned. Have had quite a few problems with this new trailer. Surprised!
2fromtexas is offline   Reply With Quote
Old 06-01-2016, 02:36 PM   #7
1973 31' Sovereign
Middletown , California
Where you place any jack stands or how hard you crank on the stabilizers could have an effect on the bolt if it's a tight fit into hole.
ijustlee is offline   Reply With Quote
Old 06-01-2016, 09:08 PM   #8
2016 30' Classic
Santa Rosa , California
Check if the extended bolt is slightly bent. This can happen if someone has tried to shut the door while the bolt was extended. (Ask me how I know). I rebent it slightly with pliers and it works fine now.
Happy Trails,
Phil
phann is offline   Reply With Quote
Old 06-02-2016, 08:08 AM   #9
Surf City , New Jersey
I had the same issue with my 2016 19ft flying cloud.
Colonial airstream replaced the deadbolt and life is good.
But not all of you are fortunate enought to do business with colonial.
They are the best
weber.roger is offline   Reply With Quote
How do I install a regular dead bolt lock to Airstream MyNancy1977 Windows, Doors, Locks & Vents 8 05-06-2015 08:15 AM
dead dead bolt Jim from SB Doors & Locks 3 09-09-2012 11:32 AM
Stupid Dead Bolt Lock!!!! SteveH Doors & Locks 81 04-20-2011 10:42 AM
