Old 11-04-2006, 06:08 AM   #1
balrgn's Avatar
1974 27' Overlander
1954 26' Romany Cruiser
1960 26' Overlander
Rockingham County , New Hampshire
Images: 74
Send a message via AIM to balrgn Send a message via Yahoo to balrgn
Cool Dead Bolt Installation
I have long wanted to install a dead bolt in my '75 Trade Wind. Getting the nerve to drill out the aluminum was the hardest part! Well almost.
'74 Overlander (T-O-Bee)
'46 Spartan Manor (Rosie)
'54 Cruiser (Bogart)
'60 Overlander (Hoagy)
WBCCI 1754 - AIR # 6281
www.balrgn.com
balrgn is offline   Reply With Quote
Old 11-04-2006, 06:17 AM   #2
peegreen's Avatar
1998 31' Excella 1000
South Berwick , Maine
That looks awesome - nice job!
WBCCI 24291
New England Unit
Metropolitan NY Unit
peegreen is offline   Reply With Quote
Old 11-04-2006, 06:24 AM   #3
balrgn's Avatar
1974 27' Overlander
1960 26' Overlander
Images: 74
Thanx, you can see more pics here
http://www.balrgn.com/Airstream/Deadbolt/Deadbolt.htm
I'll post the door later today.
www.balrgn.com
Old 11-04-2006, 06:26 AM   #4
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
Looks like a very clean install. No more worries about the door opening in transit.
What does the inside look like?
What did you get the lock?
How did you modify the door for the bolt?
75 Trade Wind owners want to know!
Richard
Old 11-04-2006, 06:32 AM   #5
balrgn's Avatar
1974 27' Overlander
1960 26' Overlander
Images: 74
Check out the link below (or above) nothing in there, just insulation. Man, I just missed the curtain rail! I'll post a pic of the inside when it warms up, 30 degrees out there!
Where did you get the lock?
Home Depot. Picked up one from a Camper Parts place, was not what I needed, hope to fit that into the Argosy 20, aka the Peanut. Loes did not have one that I liked...
Holy cow! That was tougher, I'll post pics on that later as well. Took alot of filing and de-buring out. Good thing I'm a machinist!
www.balrgn.com
Old 11-04-2006, 06:36 AM   #6
Images: 59
Do you think these would work on a '59 Tradewind?
I bought my deadbolt from Vintagetrailersupply, but I haven't put it in yet. I'm thinking I may need to mount it in the door because older doors have a flange that overlaps the jamb by about an inch.
How much backset did you use?
59 Tradewinders want to know too!
markdoane is online now   Reply With Quote
Old 11-04-2006, 06:38 AM   #7
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 40
Balgrn,
Nice looking install. Make sure you bed the lock in Vulkem! There was a leak on my 80 that actually rotted out the floor at that point. PO didn't fix it properly...I was chasing door frame leaks when I finally looked at the lock and had one of those DOH! moments
Aaron
WBCCI #XXXX AIR #2495
Old 11-04-2006, 06:40 AM   #8
balrgn's Avatar
1974 27' Overlander
1960 26' Overlander
Images: 74
Can you post a pic of your foor area like the one I posted? If your door opens full, I think it does, it is not wise to mount it in the door. It will hit the panel when the door is open...
www.balrgn.com
Old 11-04-2006, 06:41 AM   #9
balrgn's Avatar
1974 27' Overlander
1960 26' Overlander
Images: 74
Originally Posted by wahoonc
Balgrn,
Aaron
Sealed with Parbond, thanks for the heads up!
www.balrgn.com
Old 11-04-2006, 06:57 AM   #10
Images: 59
Here's pictures. I marked the deadbolt area with 1" wide masking tape. Looking at it, I guess I don't have room on the jamb for a deadbolt.
On the other hand, the way the door curves, I think I can mount in the door and still have it clear the panel when open, Might need to mount it higher, about chest level.
Great looking installation!
ID:	28062   Click image for larger version
Old 11-04-2006, 07:05 AM   #11
balrgn's Avatar
1974 27' Overlander
1960 26' Overlander
Images: 74
I'd go with it in the door. That should put it below your handle and it looks like there is not enough room for the assebly to actuate due to the window location. Even with that your gonna have a tight squeeze,,,,,
www.balrgn.com
Old 11-04-2006, 07:24 AM   #12
balrgn's Avatar
1974 27' Overlander
1960 26' Overlander
Images: 74
Dor side
I wanted to add to the bracing because it came so close to the door panel, so I made it from a piece of aluminum square tubing, that made the inside corner square.
Aaron, I still owe you a pic of the inside
ID:	28066   Click image for larger version
www.balrgn.com
Old 11-04-2006, 07:39 AM   #13
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Images: 40
Actually that was azflycaster that wanted the pics I will have to look at mine again but I think both of mine had some type of strike plate mounted on the door frame. That angle looks alot better!
Aaron
Old 11-04-2006, 07:48 AM   #14
balrgn's Avatar
1974 27' Overlander
1960 26' Overlander
Images: 74
Oops, sorry AZ, Brain Froze while I was outside
Here ya go
www.balrgn.com
Experiences with Carrier Air V installation? Sojourner Furnaces, Heaters, Fireplaces & Air Conditioning 10 04-29-2009 07:52 AM
Installation Rally Pahaska WBCCI Rallies & Events 5 11-20-2002 09:38 AM
deadbolt with inside twist style lock cindy Doors & Locks 4 10-16-2002 08:58 PM
dead bolt joel Doors & Locks 1 08-25-2002 08:35 PM
Easy clean dead bolt FrankR Doors & Locks 0 04-09-2002 12:32 AM
