Old 04-04-2005, 12:51 PM   #1
1994 30' Excella
Mississauga , Ontario
dead bolt and latch pin
Both the dead bolt and latch pin on the exterior door of my '94 excella are worn from vibration when towing and I was wondering if I could get replacement parts for this.
Al
Old 04-04-2005, 02:23 PM   #2
AirConditioner's Avatar
Two Problems
Al
If you do a search on lock repair you will see that Andy from InlandRV has an interesting observation and I'm sure has the parts. I never realized the many problems that stem from out-of-balance wheel assemblies until I read one of his posts on the subject. He also has posted a procedure to have the wheel and brake assemblies balance correctly. Worth a search and reading!
I rebuilt my door lock with tender loving care considering a replacement unit is over $700 retail, if you can find the actual parts. Your's would be much less.
AirConditioner is offline   Reply With Quote
Shakedown safari mtpalms 1969 - 1973 Safari 4 06-07-2004 05:09 PM
1985 Excella door latch Kirby Stone Doors & Locks 4 11-26-2003 03:35 PM
How to lock the door Dbraw On The Road... 17 05-18-2003 07:05 AM
Door lock/latch problems Stefrobrts Doors & Locks 4 04-28-2003 11:12 AM
Water inlet key replacement Road Ruler Fresh Water Systems 7 09-03-2002 09:07 PM
