Old 08-14-2003, 01:25 PM   #1
Dead Bolt
Has anyone installed a dead bolt on an old Airstream? Ours is a 71. Also, can they be bought from the factory or a dealer?
Dan
Dbraw is offline   Reply With Quote
Old 08-14-2003, 01:33 PM   #2
Edie's Avatar
Dallas , Texas
We had one installed on our '77 at an International rally. They installed the lock in the wall of the trailer and the bolt went into the door.
That's all I remember, but maybe Brett can tell you more when he gets online tonight.
Edie
Edie is offline   Reply With Quote
Old 08-14-2003, 01:42 PM   #3
Edie,
Thanks for the quick reply. I'll check later for further info.
Dan
Old 08-14-2003, 06:59 PM   #4
Just an old timer...
85MH325's Avatar
2004 22' Interstate
Tipton , Iowa
Images: 37
Hi, Dan...
I installed a deadbolt in my '70 Safari back in '88 or '89, essentially the same way that Edie did theirs. I installed it in the wall and had the bolt throw into the door. It was a very easy installation, and it was just a standard residential 2" throw stainless steel single-cylinder deadbold available through your home improvement stores.
Roger
AIR 2053 Current: 2004 Airstream Interstate "B-Van" T1N Sprinter & 2006 Born Free 32 RQ Kodiak Chassis
Old 08-14-2003, 07:16 PM   #5
Just a member
thenewkid64's Avatar
1978 28' Argosy 28
Tampa Bay , Florida
Images: 21
Roger has it right.
The one thing that was done to the deadbolt that was installed at Internationl was that the bolt was cut down to half thickness. This allowed for a smaller hole in the door frames. The door is a structural component so a larger hole could cause trouble.
Also by installing in the wall the dead bolt could be used to lock the screen door so it could not be opened without making a racket. This allowed for safe feeling sleeping with the door open.
Brett G
WBCCI #5501 AIR # 49
1978 Argosy 28 foot Motorhome
Old 08-15-2003, 04:59 AM   #6
85MH325's Avatar
2004 22' Interstate
Tipton , Iowa
Images: 37
Thanks, Brett. That's a good point.
It was a long time ago, but I think that the lock I found had a smaller bolt than normal; maybe 1/2" diameter instead of the usual 3/4" or something. I don't have access to the trailer any longer, so I can't say with certainty. Perhaps an RV store would have a lock with a smaller bolt that is more suitable, but at the time, I think I found one at Home Depot that worked OK.
I do recall that I was able to leave a substantial amount of structural framing in place around the hole I drilled in the door and the door frame. It didn't appear at the time that the holes would cause any structural degredation.
Roger
Old 08-15-2003, 07:58 AM   #7
Contributing Member
Pahaska's Avatar
Austin (Hays County) , Texas
Any good lock shop probably won't have it in stock, but they should be able to order you a dead bolt with a smaller bolt. if worse comes to worse, one could always be turned down by a machine shop.
John W. Irwin
2018 Interstate GT, "Sabre-Dog V"
WBCCI #9632
Pahaska is online now   Reply With Quote
Old 08-15-2003, 02:32 PM   #8
Thanks for the info. I'll go get a stainless dead bolt and turn the shaft down on my metal lathe. Sounds like a good project.
Dan
Old 11-24-2003, 11:44 PM   #9
You may want to consider installing a digital door lock. I have one on my A/S and I think its the cat's meow!
bbb
biggerbadbrad is offline   Reply With Quote
Old 11-25-2003, 10:11 AM   #10
dinoburb's Avatar
1982 34' Limited
Tidewater , Virginia
Pictures Here!
Hi Dan,
I had a dead bolt lock on my A/S that died! I went to replace it with another from one of the homeowner's hells, but couldn't make it work. The brand of the lock makes a difference. The cheaper QwikSet units have hollow lock bolts. These can't be ground down to fit the door width. However, the Defiant brand (which was the one originally installed!) has a solid bolt and can be ground to whatever thickness deemed necessary. The following link should be of some help.
http://home.tiac.net/~jtdjtd/aspix/deadbolt.html
Take care,
Old trucks and old trailers . . . a comfortable combination!
AIR 1446
W5CDR
A-6E All Weather Attack Driver, BUFF
USN Aircraft Maintenance Officer, Ret.
'91 Suburban R-2500 w/BBC
'78 Honda GL-1000
'72 Triumph T-100R Daytona
dinoburb is offline   Reply With Quote
Old 11-25-2003, 03:36 PM   #11
deadbolt
dinoburb,
Thanks for the info and great pictures. I'll start drilling and filing as soon as it warms up a little outside.
Dan
Old 09-30-2004, 07:39 AM   #12
Here are some pics of my digital door lock.
Name:	Digital Doorlock1.JPG
ID:	8932   Click image for larger version
Name:	Digital Doorlock2.JPG
Name:	Digital Doorlock3.JPG
ID:	8934   Click image for larger version
Name:	Digital Doorlock4.JPG
bbb
"Its always something" - Gilda Radner
"Well then.....nevermind..............bitch" - Rosana Rosana Dana
Old 09-30-2004, 08:09 AM   #13
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
that sure looks good, although not very retro
1966 overlander..sold
AIR #005
OUR AIRSTREAM PASSION! BLOG
RESTORING AN AIRSTREAM
retired!
Old 09-30-2004, 10:40 AM   #14
The Painted Pig
Moonshot's Avatar
1979 Argosy Minuet 7.3 Metre
Hailey , Idaho
Images: 14
My Argosy Minuet has a deadbolt. However, it's only accessible from the inside. There is no keyed area outside. Because of the door frame flange it seems like trying to change this out for a keyed lock would be pretty difficult.
Has anyone dealt with anything like that before? Or is this another Argosy oddity?
Moonshot is offline   Reply With Quote
Old 09-30-2004, 04:06 PM   #15
ALANSD: Thx. I would have to agree that this is a case of function over form. And I would hate to see anyone install this on their vintage Airstream. But since my deadbolt was installed on the trailer by the PO and I have grown accustomed to the convenience and security it offers, I'm not in a hurry to change it back to original. I think Airstream should offer a similar locking system as an option on their new models.
bbb
Old 09-30-2004, 04:40 PM   #16
Send a message via Yahoo to silver suz
Brad, do you know where the PO got the lock? silver suz
silver suz is offline   Reply With Quote
Old 10-02-2004, 08:06 AM   #17
DavidsonOverlander's Avatar
1964 26' Overlander
Milton , ON
The original deadbolt on our 1964 Overlander wasn't keyed and could only be locked from the outside. The doorknob is keyed, but it is worn to the point where it can't be locked.
I removed the original deadbolt lock and replaced it with a Baldwin deadbolt. The Baldwin was more expensive than a regular deadbolt, but I think its worth it for the way it looks. I didn't have to do anything to the bolt, it fit fine in the original pocket. The only changes I had to make were:
1. Cut larger holes in the door skin and interior door skin.
2. Replace the block of wood which supported the skin around the previous lock with one with a larger hole to fit the Baldwin.
3. Bend the edge of the door in slightly where the deadbolt screws into it so it was recessed enough to clear the door frame. I did this by hitting it lightly with a punch and hammer until it would clear - sounds scary, but it doesn't show when everything is installed.
Grant
ID:	8957   Click image for larger version
DavidsonOverlander is offline   Reply With Quote
Old 06-23-2014, 10:34 PM   #18
Glenritas's Avatar
1969 25' Tradewind
Shasta Lake , California
Update to this thread ....
Last post was 10.20.2004
This just in 6.20.2014 ... I just ordered a deadbolt from Vintage Trailer Supply .com that has been modified with a small pin for the dead bolt that will not require a large hole in the door frame.
I'll be installing it in the body just above the assist handle next to the door on my '69 Tradewind.
Glen & Jane 1969 all electric Airstream 25' TradeWind
2014 Toyota Tundra
1998 Chevy Tahoe
2001 Casita 13' Patriot Deluxe
WBCCI #6269
My Build Thread https://www.airforums.com/forums/f11...ml#post1997059
Glenritas is offline   Reply With Quote
Lug Bolt Size for '78 Sovereign dinoburb Wheels, Hubs & Bearings 2 03-20-2004 03:34 PM
1983 32' Classic Dead Bolt worn out Kajendo 1982-1983 Limited 5 01-12-2004 03:37 AM
dead bolt joel Doors & Locks 1 08-25-2002 08:35 PM
Easy clean dead bolt FrankR Doors & Locks 0 04-09-2002 12:32 AM
