Old 09-30-2004, 05:06 PM   #15
Originally Posted by ALANSD
that sure looks good, although not very retro
ALANSD: Thx. I would have to agree that this is a case of function over form. And I would hate to see anyone install this on their vintage Airstream. But since my deadbolt was installed on the trailer by the PO and I have grown accustomed to the convenience and security it offers, I'm not in a hurry to change it back to original. I think Airstream should offer a similar locking system as an option on their new models.
bbb
"Its always something" - Gilda Radner
"Well then.....nevermind..............bitch" - Rosana Rosana Dana
biggerbadbrad is offline   Reply With Quote
Old 09-30-2004, 05:40 PM   #16
Send a message via Yahoo to silver suz
Brad, do you know where the PO got the lock? silver suz
silver suz is offline   Reply With Quote
Old 10-02-2004, 09:06 AM   #17
DavidsonOverlander's Avatar
1964 26' Overlander
Milton , ON
The original deadbolt on our 1964 Overlander wasn't keyed and could only be locked from the outside. The doorknob is keyed, but it is worn to the point where it can't be locked.
I removed the original deadbolt lock and replaced it with a Baldwin deadbolt. The Baldwin was more expensive than a regular deadbolt, but I think its worth it for the way it looks. I didn't have to do anything to the bolt, it fit fine in the original pocket. The only changes I had to make were:
1. Cut larger holes in the door skin and interior door skin.
2. Replace the block of wood which supported the skin around the previous lock with one with a larger hole to fit the Baldwin.
3. Bend the edge of the door in slightly where the deadbolt screws into it so it was recessed enough to clear the door frame. I did this by hitting it lightly with a punch and hammer until it would clear - sounds scary, but it doesn't show when everything is installed.
Grant
ID:	8957   Click image for larger version
DavidsonOverlander is offline   Reply With Quote
Old 06-23-2014, 11:34 PM   #18
Glenritas's Avatar
1969 25' Tradewind
Shasta Lake , California
Update to this thread ....
Last post was 10.20.2004
This just in 6.20.2014 ... I just ordered a deadbolt from Vintage Trailer Supply .com that has been modified with a small pin for the dead bolt that will not require a large hole in the door frame.
I'll be installing it in the body just above the assist handle next to the door on my '69 Tradewind.
Glen & Jane 1969 all electric Airstream 25' TradeWind
2014 Toyota Tundra
1998 Chevy Tahoe
2001 Casita 13' Patriot Deluxe
My Build Thread https://www.airforums.com/forums/f11...ml#post1997059
Glenritas is online now   Reply With Quote
Lug Bolt Size for '78 Sovereign dinoburb Wheels, Hubs & Bearings 2 03-20-2004 04:34 PM
1983 32' Classic Dead Bolt worn out Kajendo 1982-1983 Limited 5 01-12-2004 04:37 AM
dead bolt joel Doors & Locks 1 08-25-2002 09:35 PM
Easy clean dead bolt FrankR Doors & Locks 0 04-09-2002 01:32 AM
