Old 04-17-2005, 08:31 AM   #1
damn door
The door on my 67 globetrotter is out of alignment and as a result you have to really (really) slam it to get it to close. This is great for relieving stress caused by my husband, but otherwise it's not good. Anyone know of someone who could fix this in Northern CA? I tried an airplane repair outfit - they kept it for 3 months and then said they didn't have time to work on it. Nice, huh.
chas trotter is offline   Reply With Quote
Old 04-17-2005, 08:55 AM   #2
myboyburt's Avatar
1993 25' Excella
Beautiful , New Hampshire
Images: 12
Try this link or your local Airstream dealer
http://www.airforums.com/forum...ht=warped+door
Seems some of the folks on the forum have done their own repair to correct their warped door. I also had this problem and my local Airstream dealer (in New Hampshire, sorry) just fixed it on Friday for only $76.00, and my entrance door was bad! It was sagging and the bottom corner stuck out 2 1/2 inches when the door was closed. The door is now in perfect alignment with it's frame.
Michelle & Leon
New England Unit
myboyburt is offline   Reply With Quote
Old 04-17-2005, 09:18 AM   #3
rluhr's Avatar
1968 17' Caravel
2005 30' Safari
Somewhere , roaming America
It might be an easy self-fix. My '68 door closed hard but it turned out to be just a sticky door lock mechanism. Removing it and cleaning it solved the issue.
You might also check the tightness of the hinge bolts. Sometimes adjusting those bolts will alleviate the problem.
Former full-timer | AIRSTREAM LIFE magazine | Tour of America (old blog) | Man In The Maze (current blog)
rluhr is offline   Reply With Quote
Old 04-17-2005, 10:03 AM   #4
balrgn's Avatar
1974 27' Overlander
1954 26' Romany Cruiser
1960 26' Overlander
Rockingham County , New Hampshire
Images: 74
Send a message via AIM to balrgn Send a message via Yahoo to balrgn
Is the door out of shape? Or is it the entry handle? My door lock assembly was getting pretty tough looking, chrome was peeling off and it was not catching very well. I have to push in on the door to get it to latch. It is a bit of a trick to slide the whole thing out but not bad. One thing to remember, if you attempt removal. it may have a screw near the latch. Mine is partially hidden by the rubber seal. Here is a pic of it removed, you can see the screws.
http://www.balrgn.com/Airstream/DSC02607.jpg
'74 Overlander (T-O-Bee)
'46 Spartan Manor (Rosie)
'54 Cruiser (Bogart)
'60 Overlander (Hoagy)
WBCCI 1754 - AIR # 6281
www.balrgn.com
balrgn is offline   Reply With Quote
Old 04-18-2005, 12:14 AM   #5
Hippo's Avatar
Battle Ground , Washington
Has anyone had expierence installing a wider entry door and or a electric lift for the step. Need the larger door for Hippo it is a tight squeeze getting in.
Hippo is offline   Reply With Quote
Door Catches niftypkg Doors & Locks 4 05-22-2007 05:09 PM
1965 Main Door buckmaster 1965 - 1969 Globetrotter 0 10-19-2002 07:47 PM
Door Seal Types ??? Road Ruler Doors & Locks 3 09-07-2002 05:53 PM
Bent Trailer Door Argosy74 Doors & Locks 3 09-03-2002 08:31 AM
