Old 06-04-2016, 08:33 AM   #43
2015 23' Flying Cloud
Livermore , California
Are most leaning towards the traditional size that is smaller than the OEM guard requireing 2 extra holes?
cactusjk is offline   Reply With Quote
Old 06-09-2016, 04:47 AM   #44
Been pretty quite and have not heard back from Steve.
Old 06-27-2016, 07:56 AM   #45
Anyone find another source for custom inserts? Hard to believe with all the laser cutters out there there are not more options?
Old 06-27-2016, 12:12 PM   #46
Rivet Slave
Rocinante's Avatar
2014 27' FB International
Green Cove Springs , Florida
I posted a note on Airstream Addicts on FB, where I occasionally see a post by David Winick, to ask whether he still makes these, but he didn't respond to that query either.
These days, I think David is mostly busy with an interesting hard apple cider project:
http://www.airforums.com/forums/f295...ml#post1670084
http://www.acmecider.com/
Rocinante is our 2014 International Signature 27FB
Old 06-28-2016, 03:50 AM   #47
Dingo Girl's Avatar
1967 17' Caravel
Cadillac , Michigan
Any one have a photo of one of the inserts?
I'm quite certain i could have them made.
They can't be that big a deal.
I have access to all of the machines.
Dingo Girl is offline   Reply With Quote
Old 06-28-2016, 07:28 AM   #48
Check them out here: http://www.vintagetrailering.com/acc...nd%20stuff.htm
Old 06-28-2016, 09:03 AM   #49
Rivet Slave
Rocinante's Avatar
Here you can see photos of the custom one Dave made for us:
http://www.casarocinante.com/Blog-As...late/i-pMvrqTJ
The width is perfect, but the height was a bit less than the original guard that came with the trailer. So, we drilled a couple of new holes and it works fine. Would have preferred a guard that fit the old position precisely. Anyone who decides to make one for themselves might want to note that so they can avoid making the two extra holes.
Old 06-28-2016, 09:06 AM   #50
That would be greatly preferred!! One that easily fits where the original one was. That might also allow for more writing.
Old 06-28-2016, 10:29 AM   #51
Dingo Girl's Avatar
1967 17' Caravel
Cadillac , Michigan
I will do some research and get an idea what it would cost to make them.
Can someone tell me how thick the aluminum is that David used?
Old 06-28-2016, 10:48 AM   #52
Rivet Slave
Rocinante's Avatar
I've no idea on the thickness. It seems strong enough to serve as a guard for the screen, but it is definitely not as substantial as the original Airstream door guard. The custom door guard is also flat, whereas the stock door guard is configured such that it stands a bit farther away from the screen. That's a nice touch.
Here's a door guard for sale, btw: http://www.airstreamsupply.com/scree...nter-683000-02 However, I can see from the extra pair of holes on the doorframe that this guard is also a bit shorter than the standard one. <sigh>
Also, the Airstream Store had at least one custom door guard at the International this year. Maybe if you reach out to them directly, they can sell this one to you: http://www.airforums.com/forums/f311...ml#post1812704
Good hunting!
Old 06-28-2016, 01:46 PM   #53
Dingo Girl's Avatar
1967 17' Caravel
Cadillac , Michigan
Thank you!
Old 06-28-2016, 02:11 PM   #54
I have the OEM Jackson Center one but never mounted it since I prefer one that uses the existing holes. It is the right width and thickness. If you are serious about making some I can get it to you if needed. PM if you would like it.
Old 06-29-2016, 03:50 AM   #55
Dingo Girl's Avatar
1967 17' Caravel
Cadillac , Michigan
Ok I pmd' you.
Thanks.
One concern is that the holes in the older trailers may have been hand drilled and the spacing may not be the same from trailer to trailer.
2012 Int'l 23D Mod 04: Plexiglass inserts for screen door Hoonanea Windows & Screens 14 06-23-2015 05:38 PM
Fixing screen door screen wacnstac Windows & Screens 8 04-09-2007 10:35 PM
Orange vinyl inserts for Argosy juel Clearcoat, Exterior Paint & Trim 8 11-21-2005 02:54 PM
Installing vinyl inserts juel All Argosy Trailers 5 12-14-2004 05:01 PM
Wood Inserts on the Fridge? Porky Pig Refrigerators 18 11-12-2003 03:22 AM
