Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Windows, Doors, Locks & Vents > Doors & Locks
Old 01-29-2016, 09:23 PM   #1
Mixter's Avatar
1976 27' Overlander
Convert vintage door latch to modern double rotary latch & strike?
Soooo.... I've asked this question a couple times within the past couple years, and never received any input. I'm still not to this point yet, BUT I'm VERY close!
Of course the old 70's KT lock is notorious for failure, and although still obtainable, they are super expensive, AND my door has been butchered by the PO anyway.
My original thought was to rebuild the door and reskin the door so that I could cut the appropriate opening and strike plate to replace with the readily available FASTEC style assembly like this: http://www.ebay.com/itm/Chrome-RV-En...-/301814268687
That said, its still the "old" style latch.
Wondering if the modern style double rotary latch with Bolt style striker are more desirable, reliable, and worthy of the extra effort?
What say you Airstream Renovation Team?
I originally thought I'd have to go sit down at a dealer parts counter to try and figure out what parts I'd need to do this, but I just found everything on Airstreamsupply.com - Here's the parts:
http://airstreamsupply.com/New-Airst...h-lh-381547-03
http://airstreamsupply.com/New-Airst...sher-381547-04
http://airstreamsupply.com/New-Airst...t-lh-381547-01
http://airstreamsupply.com/New-Airst...e-lh-381547-02
I have to rebuild my door anyway because of the mess that was made from the PO cutting everything up to put a household knob on after the old KT mustve died. So I have a blank slate.
Any thoughts, suggestions or ideas welcomed. Is this a worthy upgrade? OR unnecessary time & expense?
Mic
ID:	256521   Click image for larger version
Mixter is offline   Reply With Quote
Old 01-29-2016, 09:25 PM   #2
Mixter's Avatar
1976 27' Overlander
And here's the new style:
ID:	256524   Click image for larger version
Old 02-05-2016, 10:22 AM   #3
Mixter's Avatar
1976 27' Overlander
Nobody?? C'mon metal heads!
Im going to assume the 2008+ doors are same thickness as the vintage 70s.
If thats the case... I think Im going to try and do this. Its not a cheap gamble- was "hoping" someone else out there had some input.
Old 02-08-2016, 09:02 AM   #4
Razinni's Avatar
1977 31' Sovereign
Atlanta , Georgia
I'm curious as well. Has anyone just called a lock smith and told them to replace the cylinder? What's worse case scenario?
"The road goes on forever and the party never ends" - R.E.Keen
Razinni is offline   Reply With Quote
Old 06-21-2016, 10:31 AM   #5
75ArgosyRob's Avatar
1975 Argosy 26
Ripley , West Virginia
I'm wondering the same thing(s).
I've tried a similar lock setup from your eBay link. Mine was same shape but the interior lever/dead bolt knob was black plastic.
It would work with slight mod to skin and jamb. Plunger needs to be longer but figured I could space out striker plate. What ultimately got me was the interference with the screen door... Not allowing you to operate door latch from inside.
Back to drawing board.
Have any links to the second lock?
I like the looks of that.
75ArgosyRob is offline   Reply With Quote
Old 02-19-2017, 09:12 AM   #6
Boerne , Texas
Images: 18
MIXTER, any updates to this thread. Outofdoorsmart has good prices and maybe if the whole latch was purchased as a complete part it would be cheaper than parting out.
James B.
1991 34' excella 1000, bought 05/10, oak floors, granite countertops, Marble bathroom counter and floor, 2 A/C's, 2005 Hensley. 1600 Watts Solar/ 400Ah Lithium batteries
Tow With: 2006 Dodge 2500 Quad LB 2WD, 5.9 Cummins, Edge Insight CTS, Smarty Jr, Bilstein Shocks, Ingalls balljoints.
texascanuk is offline   Reply With Quote
Rivet Type - Door Strike Plate bganso Doors & Locks 2 03-14-2012 09:33 PM
Bent strike plate mtpalms Doors & Locks 7 10-31-2005 03:02 PM
Rotary 12V Bath Vent Switch Condoluminum Electrical - Systems, Generators, Batteries & Solar 4 05-04-2004 08:02 AM
convert center twins to double bed - any ideas? rochsmama General Interior Topics 7 01-10-2004 08:32 PM
Rotary Light Switch 74SovereignInt. Electrical - Systems, Generators, Batteries & Solar 20 10-15-2002 06:31 PM
