Old 09-02-2016, 11:09 AM   #1
Roquefort's Avatar
1975 29' Ambassador
1986 34.5' Airstream 345
Grefrath/ Germany , NRW
Classic motorhome door
Hey,
we have a 345 classic moho ("Bangles"), there is something interesting with my hinges:
After a few miles, the upper door pin "move's" upwards ITSELF!
Name:	ImageUploadedByAirstream Forums1472835940.601282.jpg
Name:	ImageUploadedByAirstream Forums1472835955.786245.jpg
Name:	ImageUploadedByAirstream Forums1472835971.803044.jpg
Name:	ImageUploadedByAirstream Forums1472835997.706447.jpg
The door fit's "barely" the coach, once we use the levellers, the door closes VERY BAD, if coach is not totally "level-like". (What i am telling is ALLWAYS the fact, regardless the oun is "in" or "out".
I have ALLWAYS to put back the pin, after only a few miles, once i lost aproximately the door...!
Any idea about...?
Sent from my iPhone using Airstream Forums!
Roquefort is offline   Reply With Quote
Old 09-02-2016, 11:29 AM   #2
Keen amature
martin300662's Avatar
1975 20' Argosy 20
Chestfield , Kent
This is quite a common problem on the older trailers and one 'fix' is to insert a hex screw to retain the bolt, or change to a newer type that includes a C-clip to stop it happening. There are many threads about it, here is just one.
http://www.airforums.com/forums/f44/...ng-129634.html
martin300662 is offline   Reply With Quote
Old 09-03-2016, 02:15 AM   #3
Roquefort's Avatar
1975 29' Ambassador
Hinge pin
Thank you Martin!
i have bought spare pins, not knowing there is a "new style" now with C-ring.
I will check!!!
Old 09-03-2016, 03:37 AM   #4
1989 34.5' Airstream 345
Ebro , Fla Panhandle
Funny Roqufort, I just installed thick spacer washers into my hinges to improve the doors closing.
However, concern about possibly breaking the hinges while driving the pins out caused me to cut a small V in the washer and slide it onto the pin from the side.
This has really improved the function of the door immensely.
You could easily put spacers in place with the pin pulled part way out.
Perhaps some thread lock put on the knurled part of the pin, to keep it in place.
Cheers Richard
tevake is offline   Reply With Quote
Old 09-03-2016, 04:45 AM   #5
Roquefort's Avatar
1975 29' Ambassador
Hey Richard,
would you mind to post some pictures of it? My washers are lost, while i drove with probably compleet "pin-off"...!
Maybe you can post also a oicture or two, HOW the door fit's, exspecially, on the bottom side? I have to slam the door hard, to get it closed. It could also be a combination of worn lock and pin maybe, I'll make some pictures later.
Thks, Marcus
Old 09-03-2016, 05:57 AM   #6
mayco's Avatar
1982 31' Airstream 310
champaign , Illinois
Sounds like your hinges may need replaced. New hinge pins can help IF the hole in the hinge casting isnt worn also. Open the door and then lift up on the outer bottom corner of the door. While lifting observe how much movement you have at the hinge. Even a relatively small amount of movement at the hinge can translate into the door sagging a good deal along the bottom outer edge. Have you tried lifting the bottom and then retightening the hinge screws? Of course you have to gain access to the hidden nuts on the back side of the hinge screws. But, if you go that far to expose the back side of the hinge screws I would go ahead and replace the hinges while youve got it apart.
Good luck.
Mike
mayco is offline   Reply With Quote
Old 09-03-2016, 01:03 PM   #7
HI Marcus, in my case the hinges were still well attached to the door, and to the doorframe. The downward load of the door over the years caused wear at the bearing surfaces of the hinge. This created a bit of space at the top of the doorhinge portion.
Here a pic should help, you can see the white thick washer at the bottom of the gap. This has lifted the door enough to make it open and close nicely.
Of course the correct repair is new hinges, but till then this is a help.
Cheers Richard
Old 09-04-2016, 10:07 AM   #8
Roquefort's Avatar
1975 29' Ambassador
Hey,
i am posting some pictures now. The first (no Marcus finger visible) show the door, while she is on her "Jacks" and "level", as best i could. Door closes barely, by "slamming", can only lock with the additional Deadbolt lock.
Name:	ImageUploadedByAirstream Forums1473004844.592643.jpg
ID:	270774Click image for larger version
Name:	ImageUploadedByAirstream Forums1473004861.709296.jpg
Name:	ImageUploadedByAirstream Forums1473004877.276467.jpg
Name:	ImageUploadedByAirstream Forums1473004892.795150.jpg
Name:	ImageUploadedByAirstream Forums1473004917.279550.jpg
This shows DOWN/LEFT
Name:	ImageUploadedByAirstream Forums1473004956.680890.jpg
This shows DOWN/RIGHT
Now, you see the same, as she is on her wheels:
Name:	ImageUploadedByAirstream Forums1473005006.152137.jpg
ID:	270780Click image for larger version
Name:	ImageUploadedByAirstream Forums1473005019.369863.jpg
ID:	270781Click image for larger version
Name:	ImageUploadedByAirstream Forums1473005047.689271.jpg
Name:	ImageUploadedByAirstream Forums1473005065.321550.jpg
As you can see, the DOWN/LEFT part closes badly, regardless if she is on Jacks, or wheels.
Is this normal, are these rigs really that poor build? Even the "iconic" Alu-shell???
(I know by heart, after all my rebuildings inside, the furniture is "decorative & heavy" crap!
Old 09-04-2016, 10:14 AM   #9
Roquefort's Avatar
1975 29' Ambassador
What i show now is the lock:Click image for larger version
Name:	ImageUploadedByAirstream Forums1473005258.868563.jpg
This is on the door, i have adjusted it countless times. Either it work's "so called good" if on Jacks, or on wheels, never on both circumtances.
Name:	ImageUploadedByAirstream Forums1473005353.224717.jpg
This is the doorframe part. The "piece" (don't know the english description) is barely tighten, can't tight it well, no chance to reach the nut inside. I am to anxious to de-rivet the total innerframe, to reach the nuts.
My thought was, to "make" a special wrench by cut & weld like an U-shaped tool. Does anybody know, which size this wrench needs to be then?
These pictures show my hinges, coach on wheels, "as is" today, after a 10 mls trip:
Name:	ImageUploadedByAirstream Forums1473005601.590909.jpg
Downside
Name:	ImageUploadedByAirstream Forums1473005624.407949.jpg
Upside
Name:	ImageUploadedByAirstream Forums1473005650.776488.jpg
Again Upside
2016 Classic: Refrigerator door dented by pantry door handle DavidLawson General Repair Forum 21 09-03-2016 11:56 AM
Classic motorhome door hinge replacement mayco Classic Motorhomes 53 04-21-2016 08:43 AM
1964 door in a Door entry door hinges recycled Windows, Doors, Locks & Vents 1 09-18-2013 06:07 PM
Door in a door '53 cloud inner door size. Flysoncloud Doors & Locks 13 09-18-2010 07:10 PM
