Old 04-03-2015, 07:38 AM   #1
1971 31' Sovereign
1972 31' Sovereign
Soddy Daisy , Tennessee
Chesler T5 door lock
I have a Chesler T5 lock and was wondering if anyone has ever worked on one of these. I took mine out of a 67 Safari to clean due to knob sticking and found a small spring hanging down inside the mechanism 3/4" long with loops on the ends, trying to figure out where it attaches. Appears it has been taken apart by PO due to screws not tight. Is there a rebuild kit for this style anymore. Found a drawing on the Bargman but doesn't appear to be the same. HELP
cole3444 is offline   Reply With Quote
Old 04-08-2015, 11:59 AM   #2
desertair27's Avatar
1960 26' Overlander
1963 24' Tradewind
El Paso , Texas
Images: 32
Did you ever get an answer or fix for your Lock?
Can you post a picture of it?
desertair27 is offline   Reply With Quote
Old 04-08-2015, 06:54 PM   #3
1971 31' Sovereign
1972 31' Sovereign
Chesler lock
I had a fellow Airstreamer PM me and he sent some pics that helped. I also found this post under Doors and Locks, 1960s Chesler T5 door latch pictorial I think the date range was around 2012. Hope this helps
Old 04-10-2015, 09:47 AM   #4
1960 26' Overlander
1963 24' Tradewind
El Paso , Texas
Images: 32
Thanks for the info
Chesler T-5 lock onirevas Doors & Locks 3 08-25-2009 02:50 PM
chesler lock problems goransons Doors & Locks 1 09-16-2008 03:57 PM
Chesler lock, tumbler removal bilby05 Doors & Locks 6 10-27-2005 06:39 PM
