Old 10-27-2005, 09:01 AM   #1
bilby05
bilby05's Avatar
1962 24' Tradewind
1962 24' Tradewind
Canyon , Texas
Chesler lock, tumbler removal
I have a '69 Sovereign and I need to remove the tumbler to facilitate copying keys. I know there is a small pin on the outer handle, and I understand that by pressing that one can remove the tumbler. Problem is: it won't press, and I don't want to get a bigger hammer. Anyone in this forum have experience with such? Would it be easier to remove the whole latch and lock assembly and take that to the locksmith?
Any help would be appreciated.
thanks
1962 Airstream Tradewind
2001 Ford 7.3 Diesel
bilby05 is offline   Reply With Quote
Old 10-27-2005, 09:07 AM   #2
bilby05
You will more than likely, wind up replacing the complete lock assembly.
Old 10-27-2005, 11:41 AM   #3
balrgn's Avatar
1974 27' Overlander
1954 26' Romany Cruiser
1960 26' Overlander
Rockingham County , New Hampshire
Images: 74
Send a message via AIM to balrgn Send a message via Yahoo to balrgn
thanks
Not familliar with the 69's. Does it look like this?
http://www.balrgn.com/Airstream/DSC02607.jpg
I just had mine out, had a broken E-Clip.
5 screws and it pushed out from the back side. Pretty simple design....
'74 Overlander (T-O-Bee)
'46 Spartan Manor (Rosie)
'54 Cruiser (Bogart)
'60 Overlander (Hoagy)
WBCCI 1754 - AIR # 6281
www.balrgn.com
balrgn is offline   Reply With Quote
Old 10-27-2005, 11:45 AM   #4
balrgn
You have a "KT" lock. It was used on the 1970 to 1977 model trailers.
1966 to 1968 trailers used a Bargman lock.
1969 trailers used a Chessler lock. Chessler is out of business.
The Bargman lock, l-100 special, has an extended striker bolt. It is now used on the 1966 to 1969 model trailers.
Old 10-27-2005, 12:48 PM   #5
bilby05
bilby05's Avatar
1962 24' Tradewind
1962 24' Tradewind
Canyon , Texas
chesler lock removal
Ok. If I were to need to remove the Chessler lock, like to grease it or have new keys carefully fitted, would it be removed by taking out all of the screws(as has been mentioned for other locks) or does the pin in the handle play a role in keeping it together.
thanks, bill b.
Old 10-27-2005, 01:07 PM   #6
bilby05
Remove the two screws from the inside and one or two screws from the edge door frame.
The lock will almost fall out.
Old 10-27-2005, 06:39 PM   #7
bilby05
bilby05's Avatar
1962 24' Tradewind
1962 24' Tradewind
Canyon , Texas
Lock removal
Remove the two screws from the inside and one or two screws from the edge door frame....The lock will almost fall out.
Andy[/quote]
There ya go! That's what I was looking for. I have a tendancy to go the "get a bigger hammer route" if I am not careful. So knowing in advance is a big help. Thanks Andy.
Cheers
310 door lock parts joepospisil General Motorhome Topics 8 10-02-2012 11:14 AM
That @#*# Lock niftypkg Doors & Locks 16 11-20-2005 02:28 PM
Entry Door Lock Set Hunt ends at Inland Grady White 1959 - 1965 Ambassador 3 12-16-2004 09:08 PM
Broken Travel Lock Charcigar Doors & Locks 2 06-08-2004 08:23 AM
Door Lock replacement? 3Ms75Argosy Doors & Locks 2 08-15-2002 11:12 PM
