Old 07-25-2017, 07:21 AM   #1
1970 25' Tradewind
Chicago
Canít lock KT lock from inside
1970 Tradewind with KT lock. Locks fine with key, inside locking shaft only moves down part way but not enough to lock door. I had lock out and lubed it up and it worked fine while out of door. Iím stumped. Take out and lube up some more or anything else I should look at?
Madmarke007 is offline   Reply With Quote
Old 07-25-2017, 08:12 AM   #2
1976 31' Sovereign
Oswego , Illinois
Smile
My kt lock also does same thing as you described, what I found is slightly pull inside handle when pushing locking pin down, some times same way to unlock also make sure pin is screwed all way tight as tends to work loose.
The Can Can Can travelfables Member Introductions 3 02-01-2014 01:56 PM
"I think I can, I think I can, I think I can".... 2Rhinos Repairing/Replacing Floor &/or Frame 14 08-17-2011 01:39 PM
Broken Inside Lock: '72 Tradewind yochanan Doors & Locks 3 05-18-2006 02:16 PM
$60 to make key for lock inside handle SafeHarbor 1978- 1979 Excella 500 0 04-17-2006 06:30 PM
deadbolt with inside twist style lock CindyH Doors & Locks 4 10-16-2002 08:58 PM
