Old 04-06-2019, 01:15 PM   #1
Owners of Willie
2019 27' Globetrotter
Chillicothe , Illinois
Canít get this open-Key wonít turn-all others are fine
Owner of Willie
patriciahawk is offline   Reply With Quote
Old 04-06-2019, 01:25 PM   #2
2014 25' FB Flying Cloud
Kingwood , Texas
Which storage area is it? You may have to access it from the inside of the trailer. Could something inside the storage be blocking the lock from swinging around?
DoubleR is offline   Reply With Quote
Old 04-06-2019, 02:05 PM   #3
Stay Calm and Stream On
HHPJ's Avatar
2017 25' Flying Cloud
Palm Springs , California
Shoot with lock cleaner spray, press in the top of door while turning key... may be too much pressure on tab
Stay Calm and Stream On!
HHPJ is offline   Reply With Quote
Old 04-06-2019, 04:00 PM   #4
Mollysdad's Avatar
Looking at the Globetrotter layout, it appears all the 27' are front bedrooms. The rear has no outside access, so I'm surmising the baulky lock is under the bed.
First, lift up the bed and see if you can get access to the inside of the storage. The latch is held by one small nut, so if you take that off you can open the door and see why the lock is pesky.
Old 04-06-2019, 04:23 PM   #5
nryn's Avatar
Chicago area , Illinois
Originally Posted by patriciahawk View Post
I had a problematic outside storage lock on my shakedown cruise. Turns out on mine that the black handle bit (the bit that lifts and that you rotate to open) has to be FULLY seatedóas in perfectlyóin order to turn the lock. Not sure if this is the case with yours, but try pushing on the black lever and ensuring that it is fully seated around the lock cylinder. Mine ďclickedĒ when it was seated and the lock turned as normal and very smoothly once it did. No other lock on the trailer behaves this way.
nryn is offline   Reply With Quote
Old 04-06-2019, 06:48 PM   #6
Owners of Willie
Thank you for the suggestions. Adjusting the hitch level took care of it. Whew!
Owner of Willie
Old 04-06-2019, 06:49 PM   #7
Owners of Willie
Thank you. We had tried that as well. No access that way. We have twins.
Owner of Willie
Old 04-06-2019, 07:46 PM   #8
Leilanisteve's Avatar
2015 19' International
Boise , Idaho
Same thing happened to us last year of course just before we were leaving the house. Tried everything I could think of. Locksmith couldnít pick the lock
Grabbed necessary gear by lifting up the bed but no chance to reach the lock mechanism from inside. Lock was changed out later. Will try adjusting the jack next time. Thanks
Leilanisteve is offline   Reply With Quote
Old 04-06-2019, 08:20 PM   #9
KK4YZ's Avatar
2017 23' Flying Cloud
Hiawassee , Georgia
We had the same problem with the rear hatch lock on our 23D. After trying to get it unstuck, Called a locksmith who tried everything in his bag of tricks and ended up drilling out the lock.
The latch will still work with the lock drilled out - just isnít lockable. AS sent me a new lock/latch assembly. It was easy enough to replace.
KK4YZ is offline   Reply With Quote
Old 08-06-2019, 04:30 PM   #10
2019 28' Flying Cloud
2014 22' FB Sport
Davie , FL
The same thing happened to me on my FC 28 rear compartment door. The key wouldn't turn the lock cylinder. I was able to access the lock from the inside after lifting up the bed. Though I couldn't reach it or see it I got a mirror and flashlight and with an 18" socket extension I was able to remove the latch. You will need a 1/2" deep socket to loosen the latch nut.
I am asking Airstream to send me a new lock under warranty.
out of sight is online now   Reply With Quote
Old 08-06-2019, 05:17 PM   #11
2018 27' Globetrotter
Mooresville , North Carolina
I have a Globetrotter with twin beds as well. Iíve never had that issue but all the suggestions noted are good. FYI Ė If all those fail in the future, there is a way to access it from the inside. When you lift the mattress off of the bed, the plywood base for the mattress is the ceiling in the outside / inside storage compartments. There should be 6-7 phillips head screws attaching the plywood. Unscrew those, lift it up and you will get access to the lock from the inside to remove the nut. If you ever have to opportunity to do this it will show you how everything is put together.
I had to do some clean up work after service at Jackson Center and had to adjust the bed base when I got home. This is off topic; however, when doing this I had my outside storage compartment bins open while my wife was taking our sheets off to wash. With the compartments open in the daylight we could see gaps around the bed base and the wall. The outside light from the compartments makes any gaps noticeable. If you have any then you can get some insulation / foam strips / etc to fill those areas to keep cold / hot air / dust from entering thru the gaps in the storage compartments.
I also noticed dust at the foot of the bed down at the floor area on the inside shell. Due to the curve of the inside shell and the straight edge of the wall in the storage compartment, there is a gap against the wall on both sides. I stuffed insulation in there as well to keep the cold / heat / and dust out of the interior.
I felt kinda stupid not realizing the ceiling in the storage compartment was the bed base. We would always feel cold air when sleeping next to that wall. Now, it appears to me the majority of that would be cold air in the outside compartments coming up thru any gaps that existed. Iím hoping this will minimize this in the future.
I also added clear sealant where the metal diamond floor in the storage compartment meets the wall. If any water enters the storage compartment, it will enter any gap and be on the interior of your RV in the inside storage compartments.
2018 GMC Sierra 2500HD Duramax
Equal-I-zer Hitch
"Roadrunner"
GOUSC is offline   Reply With Quote
Blackwater valve handle won't shut or open all the way melbel Waste Systems, Tanks & Totes 11 11-03-2010 11:37 AM
Bedroom Lights Don't Turn On/Turn Off and turn back on after a couple minutes. alecg Lights - Interior & Exterior 9 09-01-2010 02:01 PM
won't start using the key/no power at all 72prostreet Electrical - Systems, Generators, Batteries & Solar 15 02-23-2010 05:53 PM
1977 Airstream Argosy with All New Appliances! Turn-Key eBay Watch Airstreams on eBay 0 08-01-2009 12:30 PM
1977 Airstream Argosy with All New Appliances! Turn-Key eBay Watch Airstreams on eBay 0 07-25-2009 12:10 PM
