Old 01-19-2006, 02:16 PM   #1
Boaz1362's Avatar
1989 32' Excella
Seabrook , Texas
Broken Interior Door Latch Handle!!!
The interior door latch handle on our 89 Excella was broke this mourning due to closing the door a little too hard. The wind here in Vegas is making excellent kite weather. The mechanism is in perfect working condition but this small pair of vice scripís attached to the shaft is going to be totally unacceptable by the wife. Is this part still available? It kind of looks like a door latch that is used on other makes of trailers. Any and all suggestions would be appreciated.
Thanks, Don
2005 Chevrolet 2500HD W/Duramax Diesel/Allison Transmission
1989 32' Excella 1000
"I'm Retired And Don't Giv-A-Dam!"
Boaz1362 is offline   Reply With Quote
Old 01-19-2006, 02:33 PM   #2
balrgn's Avatar
1974 27' Overlander
1954 26' Romany Cruiser
1960 26' Overlander
Rockingham County , New Hampshire
Images: 74
Send a message via AIM to balrgn Send a message via Yahoo to balrgn
Thanks, Don
Have you looked at VintageTrailer.Com?
They may have what your loking for
Good Luck
'74 Overlander (T-O-Bee)
'46 Spartan Manor (Rosie)
'54 Cruiser (Bogart)
'60 Overlander (Hoagy)
WBCCI 1754 - AIR # 6281
www.balrgn.com
balrgn is offline   Reply With Quote
Old 01-19-2006, 03:55 PM   #3
1994 30' Excella
Mississauga , Ontario
Don,
check out the trimark corporation web site and see if they sell your style of lock.
Al
Old 01-19-2006, 06:47 PM   #4
steelbird312's Avatar
1956 22' Safari
2000 39' Land Yacht XL Diesel w/slide
Crossville , Tennessee
Images: 11
Don, There are a few boneyards around from which you might be able to procur one. There's one in N Central FL, another in Carthage, Missouri. Also, Walts Trailer Sales, I think Ocala, FL has many Airstream related parts. What about the factory. They handle many things that old. Maybe one of these helps.
steelbird312
2000 390 Landyacht XL
1989 29' Excella
WBCCI #6673 jerry Hodge
Have no intention of arriving at the grave safely, but rather to skid in sideways, chocolate in one hand,throttle in the other, totally worn out and screaming
"WOO HOO, WHAT A RIDE!"
steelbird312 is offline   Reply With Quote
Old 01-20-2006, 01:30 AM   #5
Boaz1362's Avatar
1989 32' Excella
Seabrook , Texas
Thumbs up Thanks!
Thanks for all the help. I am checking on all given information and will check back with the results in a week or so. This one will probably have to wait until we get back to our base.
I'm having too much fun here in Vegas now!
Don
Old 01-22-2006, 06:53 AM   #6
1956 22' Safari
Images: 11
Don, This comes from Trailer Life magizine, Jan 2006. Even though it is geared at trailering in general, it is a fine magizine, and trailering is more important than just Airstreams for me- Airstreams are what I have chosen to do my trailering/traveling in! Good luck in your search!
Name:	parts houses for trailers 001.jpg
steelbird312
1989 29' Excella
Old 08-18-2009, 11:49 AM   #7
newnan , 30263
89 Excella 32' Broken Door Handle
I too have an 89 Excella with the very same issue. Please let me know if and or where you were able to locate.
redwinefarms is offline   Reply With Quote
Old 08-18-2009, 12:24 PM   #8
Full Timers/Diesel power.
Mike Leary's Avatar
Cactus Hug , Arizona
Images: 11
Any pics? I had (have) a problem with mine; if it's the same one I have, we're all in trouble, but I can post a pic on how I fixed mine (sorta).
"A settled wisdom, plus the itch to be elsewhere"
Mike Leary is offline   Reply With Quote
Old 08-18-2009, 02:53 PM   #9
1988 32' Excella
West Palm Beach , Florida
We, too, fixed ours with some ingenuity and skills and lots of persistence. Will take some pics and write out a description as best we can to post later.
2dogtraveler is offline   Reply With Quote
Old 08-19-2009, 01:26 PM   #10
1988 32' Excella
Thumbs up repaired inside door lock handle
Inside door handle broke! After looking for a replacement without success, I just made one. Started with the closest-matching parts possible, then put it together.
Used an S&K 3/8" drive x 1/2" (six point) socket. This socket has a groove around it for the "C" retainer clip from original lock. It is very close to the inside diameter of the hole in the cover plate.
Used a 5/16" hex cap screw and nut.
Used 1 piece of 1/8" steel flat stock cut to the handle size.
Now the fun part! Putting it together!
Drill hole in the flat stock handle. Assemble cap screw and nut on handle, place nut in socket. Important note: check for rotation of 3/8" socket to the square shank inside door lock!
Then braze weld the parts together. You will by now have noticed the square shank in the lock is 5/16", a tad smaller than 3/8" socket. This is made up with stainless steel shims or steel sheet metal made to fit.
Final looks are up to you. Paint, rubber handle grip material, vinyl tape, or as we've chosen, just live with it. It works fine.-Mike & Alicia
Name:	26 repaired lock handle.JPG
ID:	85696   Click image for larger version
Name:	27 not pretty but functional.JPG
Name:	28 square shank w shims top & bottom, C ring.JPG
ID:	85698   Click image for larger version
Name:	31 cap screw & nut in sample socket.JPG
Name:	32 similar socket w groove.JPG
ID:	85700   Click image for larger version
Name:	33 original handle.JPG
Name:	34 orig handle backside.JPG
External door handle Excella3287 Doors & Locks 2 11-09-2012 04:47 PM
Broken wiring in tail lights Argosy74 Electrical - Systems, Generators, Batteries & Solar 4 10-23-2002 09:09 PM
cleaning up toilet tank release handle cindy Sinks, Showers & Toilets 0 10-19-2002 11:44 AM
Inside door handle for a 1984 International Bennie 1980-1984 International 0 08-06-2002 08:37 PM
Oven gas line broken lbrodsky LP Gas, Piping, Tanks & Regulators 4 07-23-2002 03:52 AM
