Old 05-18-2006, 02:02 AM   #1
Broken Inside Lock: '72 Tradewind
Lock still appears to function perfectly from the outside but
cannot be locked from the inside.
Locking lever just flops in it's slot.
How extensive of a repair will this be?
yochanan is offline   Reply With Quote
Old 05-18-2006, 06:48 AM   #2
startrekker2001's Avatar
1978 31' Excella 500
Palm Bay , Florida
Images: 34
The door locks are expensive to repair if you use the Airstream replacements. I have a 78 Excella and on two different occasions had problems with the lock/latch. I took the assembly out of the door and disassembled it, found the broken part and had the break brazed by a professional. The first fix cost me a 6 pack of beer, the second cost $10.
A replacement lock for my 78 is $170 and for a 1977 Airstream it is $700. It is best to try to resolve the problem yourself.
Vic
Vic Smith
Director Florida State Rally
www.floridastaterally.org
www.facebook.com/FloridaStateRally
WBCCI Florida Unit 027 Trustee
http://www.airstream-adventures.com/...rida_Unit.html
WBCCI #6782
31' 78 Airstream Excella 500
2001 Ford Excursion V-10
Reese hitch and dual cam sway control
startrekker2001 is offline   Reply With Quote
Old 05-18-2006, 07:20 AM   #3
tphan's Avatar
1972 27' Overlander
Longmont , Colorado
Try this
hi- I have a '72 also, and that locking lever on mine seems to be threaded into something inside- is yours screwed in tight? Check that, and here is an exploded view of the main door lock: http://www.ldservice.com/tim/airstre...-door-lock.jpg
It describes how to get the lock out of the door in the service manual,but basically you take out all visible screws holding it to the inner skin, and door frame, and also take out enough rivets from that skin to be able to bend it out so the lock mechanism can pivot out of the exterior hole.Good luck- Tim
tphan is offline   Reply With Quote
Old 05-18-2006, 02:16 PM   #4
I will check to see if it's threaded.....thanks much to both for the info and link
Broken Inside Door Latch Mike Eagle Doors & Locks 4 01-08-2011 06:20 AM
wires broken off inside hitch robertel Electrical - Systems, Generators, Batteries & Solar 8 09-09-2010 08:31 PM
Door lock appears to be broken and locked from inside too! LucyPepper Doors & Locks 12 10-12-2009 10:20 PM
Broken Travel Lock Charcigar Doors & Locks 2 06-08-2004 08:23 AM
Broken Exterior Door Lock fmzjwill Doors & Locks 37 03-28-2004 03:21 PM
