Old 05-20-2010, 03:03 PM   #1
1988 34' Excella
Orlando , Florida
Broken Inside Door Latch
After reviewing other postings under Doors & Locks this is not an uncommon problem. There have been several unique fixes to this problem but no one seems to have found a source to buy a replacement part. The latch handle can be easily replaced without replacing the entire latch mechanism but I need the handle and from reading other postings other AS owners could use one too. Has any one found a source for the latch or the handle? From the attached pics I am sure several of you will recognize the latch.
ID:	102973   Click image for larger version
ID:	102975   Click image for larger version
Mike Eagle is offline   Reply With Quote
Old 05-20-2010, 05:06 PM   #2
Keeler Brass made your lock.
They have been out of business for many years.
Old 05-20-2010, 05:11 PM   #3
guy99's Avatar
1984 31' Airstream310
Dunsmuir , California
Images: 16
Member John Burkey makes and sells the outside handle for these locks.
See post 5 in this thread. http://www.airforums.com/forums/f453...tml#post809681
1984 310 Limited Motorhome
guy99 is offline   Reply With Quote
Old 01-08-2011, 05:57 AM   #4
1988 34' Excella
Orlando , Florida
Broken Inside Door Latch Handle
I have received several emails requesting pictures of a repair that I made on the broken handle for the inside door latch on my 88 Excella. Pictures of the broken handle are shown on the first post of this thread. The repair was simple to make. I used part of a handle from a water valve I purchased at a local Habitat for Humanity restore for $1. Any flat metal scrap metal will work just as well. Screw #1 is drill and tapped thru the remaining part of the original handle and into the 1/4" square steel shaft that rotates the dead bolt of the latch. This screw provides the turning force to open and close the latch. Screw #2 is added to prevent the new handle from spinning in place and is only drilled and threaded into the remaining "round" portion of the original handle. Both screws are SS, size #4 x 40 even though the heads of the screws are different sizes. Screws were used because you still need access to the inside of the lock mechanism for assembly and any future repair.
Name:	Handle Repair.jpg
Old 01-08-2011, 06:20 AM   #5
noreen&sal's Avatar
1981 27' Excella II
mays landing , South Jersey
Nice job. Looks better than new. Sal.
noreen&sal is offline   Reply With Quote
Broken Door Latch Ranger 6 Doors & Locks 4 09-24-2009 08:23 PM
Broken Interior Door Latch Handle!!! Boaz1362 Doors & Locks 9 08-19-2009 01:26 PM
Screen door latch broken redeagle313 Doors & Locks 5 04-20-2009 05:03 AM
Door Latch broken on '75 Argosy debpatch Doors & Locks 4 05-26-2008 10:32 AM
Broken Door Latch Ranger 6 Doors & Locks 2 12-20-2005 05:55 PM
