Old 03-11-2004, 09:40 AM   #29
Send a message via Yahoo to silver suz
key pad
YES! I think that's what I mean! Would that work in a 1971 sov???
It scares me to hear about all these lock failures for my year as I will be spending a significant time alone and being disabled- DO NOT want to ever deal with that problem. and I don't want to be dependent on other people, however generous, to fix my problems, if it's something I can take care of now. I can't be locked out of my medications, oxygen, or safe- clean-room, for even a couple of minutes. the reality is it could mean the difference between life or death, no sympathy please- it's just a fact.
Thanks for your help, Silver Suz
silver suz is offline   Reply With Quote
Old 03-11-2004, 10:03 AM   #30
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
If you have the Keeler lock assembly (later 70's and on)
you can replace the tumbler which is the most often broken part. It cracks from age and usage. This tumbler is 10-15 dollars available at many RV parts places. It is easily replaced, although you will have to use the new key that comes with it.
I did the on in my motorhome when I first bought it.
Part is a Bargman L-300 assembly.
1966 overlander..sold
AIR #005
OUR AIRSTREAM PASSION! BLOG
RESTORING AN AIRSTREAM
retired!
Old 03-11-2004, 12:42 PM   #31
silver suz
The key pad lock is very expensive and would not easily work on your trailer.
Keeler Brass locks were not used until the 1978 models.
You could remove your lock, send it in to be overhauled. That should give you at least 20 more years of service from it, I would think.
Old 03-11-2004, 01:26 PM   #32
where can I get the keypad code
I have a keypad on my limited, however I do not know the code. either does the previous owner.
VIN # maybe. I understand that ford designed it.
RIck
0557 is offline   Reply With Quote
Old 03-27-2004, 06:06 PM   #33
Astrodokk's Avatar
1992 30' Airstream 30
Santa Rosa , Northern California wine country
MH door locks
My original broke so replaced with the one in the pic. Also added a deadbolt for extra security. Nice install by RV specialist.
Name:	outer locks.jpg
Astrodokk is offline   Reply With Quote
Old 03-27-2004, 06:07 PM   #34
Astrodokk's Avatar
Inside peek
of the deadbolt
Old 03-27-2004, 06:10 PM   #35
Astrodokk's Avatar
HOWEVER...
he messed up the aluminum latch for the screen door, so I temp replaced with 2 screws and thin metal until some nice person here posts a pic of what it should or could look like. I think i need to have someone weld or solder a 90 degree solid aluminum piece to the screen door frame.
Name:	lock handle inside.jpg
Old 03-27-2004, 06:12 PM   #36
Astrodokk's Avatar
BTW, he had said when I pointed that out to him that the door was already in that condition..yet that lock didn't fit flush as the smaller original did. If I were to do again I would send out to rebuils as Andy suggests.
Old 03-27-2004, 06:17 PM   #37
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
my screen door has a piece of metal welded right there also. Works ok but I wondered what the original latch was like.
AIR #005
retired!
Old 03-28-2004, 03:21 PM   #38
jjonesnc's Avatar
Cary , North Carolina
Images: 8
Send a message via Yahoo to jjonesnc
Door Lock
Originally posted by Inland RV Center, In
The $600.00 replacement lock is for a 1970 to 1977 trailer, only.
In 1978 Airstream used a lock mad by Keeler Brass. They are no longer in business.
A replacement lock kit is available that fits the 1978 to 1991 trailers.
It's cost is less than $150.00.
As per Airstream, a small modification to the door is necessary.
Total installation time is 1 hour or less.
Not something everyone can do, but most certainly by the person that has a few basic tools and a little mechanical moxie.
Andy,
So the replacment door lock/handle assembly can be purchased thru a airstream dealer for a 1980 model?
jjonesnc is offline   Reply With Quote
The first day. Broken Rib? Charming Wino 1974 Overlander 12 03-07-2004 06:11 PM
Seweer valves broken JLD Waste Systems, Tanks & Totes 3 12-02-2003 07:04 PM
Broken wiring in tail lights Argosy74 Electrical - Systems, Generators, Batteries & Solar 4 10-23-2002 09:09 PM
Broken Window Installation Charcigar Windows & Screens 2 07-30-2002 04:22 PM
Oven gas line broken lbrodsky LP Gas, Piping, Tanks & Regulators 4 07-23-2002 03:52 AM
