Old 05-04-2016, 04:20 PM   #1
RFP
RFP's Avatar
2014 23' International
Hurst , Texas
Broken Door Handle? Be Prepared With This Simple Mod
OK, I'm a worrier. When I saw this thread about the entrance/exit door handle breaking off, it got my attention: http://www.airforums.com/forums/f44/...ht-133974.html
Having no interest at all in crawling out the "emergency exit" of our 23D, I started checking the latch mechanism to see if there is a way to get it open even with a totally-broken-off-handle.
As it turns out, there is.
In the attached photos, you will see a little "tab" inside the door latch mechanism. Lifting "UP" on this tab will release the latch... exactly what happens when you turn the handle.
So, a few minutes work with a file to create a "notch" in my screen door frame, and drilling a small hole in the door frame allows me to "trip" the latch with a small Phillips screwdriver (now residing in my inside-the-trailer tool kit).
I bought some fuzzy-side Velcro and made new pads for the door frame. I cut a "X" where the hole is drilled in the frame, and, sure 'nuff, the screwdriver goes right through and with about 5-seconds of hunting for exactly the right place, "POP" my door is open.
I plan on buying a new handle assembly (they are only just over twenty bucks) and carry it as a "spare." This level of preparedness should ensure my handle never breaks!
"Spare" door handle here: http://airstreamsupply.com/New-Airst...e-lh-381547-02
Rob
2014 23D International Serenity - "Fortune Cookie"
2015 Ford F150 3.5 EcoBoost, Max Tow - "Cookie Monster"
And some stuff
Fortune Cookie: https://www.flickr.com/photos/rfpd30...57663633667345
"The Black Swan": https://www.flickr.com/photos/rfpd30...57648991024725
RFP is offline   Reply With Quote
Old 05-15-2016, 06:42 PM   #2
MarkJUrban's Avatar
2016 30' International
Richfield , Ohio
When it happened to me, I didn't have to crawl out the emergency exit. Luckily I was in the driveway. I called and woke up my wife (11pm) to open the door . Next time I will crawl out the window. Or wok on creating the "notch"
MarkJUrban is offline   Reply With Quote
Old 05-18-2016, 02:04 PM   #3
KJRitchie's Avatar
2008 25' Classic
Wichita Falls , Texas
I hadn't seen the thread about the door handle breaking off and getting stuck inside. We've (well, my wife) locked ourselves out. I wasn't at the campground at the time but she managed to crawl through the outside, under bed storage (luckily unlocked) opening to get inside.
I'll have to look at my door to find the magic catch.
Kelvin
Old 05-18-2016, 03:00 PM   #4
RFP
RFP's Avatar
Hurst , Texas
Kelvin
Kelvin,
This little "mod" will be a piece-of-cake for you! Of course, now that I've don the "mod," it's a certainty that my door handle will never break. This is such a super-easy preventive step, I thought a lot of Airstreamers would have shown interest. As for me, I just had a life size mental picture of trying to crawl out the minuscule Emergency Exit window... yuk! Hence, the fix. No acrobatics for this old guy.
And some stuff
Old 09-07-2017, 07:52 PM   #5
2016 30' Classic
Lorton , Virginia
Door handle broke off on me, thanks for the instructions. I was able to slide a knife in to catch the black tab without modifying anything. I'll do your mod soon to make exiting easier.
It is really sad to see how cheap the internals are of this mechanism. The door handle is literally just crimped onto the latch plate inside and will eventually fail for everyone given enough time. Nothing surprises me anymore though with Airstream.
Zybane is offline   Reply With Quote
Old 02-10-2018, 08:33 AM   #6
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
I noticed the screen door of my 99 Excella had a notch cut in it and an added piece of Velcro on the inside, but did not know why the previous owner had done this. All I have to do is find a small screw driver!
Thanks for posting this!
Alan
Old 02-10-2018, 01:16 PM   #7
Foiled Again's Avatar
2012 25' FB Eddie Bauer
Virginia Beach , Virginia
you da man! Super clear and helpful.
Moderators, give this thread a sticky!!!!
Old 02-10-2018, 02:33 PM   #8
HowieE's Avatar
Princeton , New Jersey
Images: 12
I noticed on the other tread about door handles that the mechanism was made by TriMark. About that time, 2014 or so, TriMark made door handles for many motor homes that would fail in the locked position and were under a Federal Recall to replace them. I had to replace the handle on a friends, 75 year old single woman that got locked in her motor home, under the recall. TriMark tried to wiggle out of it but when I quoted the recall number they quickly sent newly designed door assembly.
2004 Excursion 4x4
Old 02-11-2018, 04:41 PM   #9
DaveP's Avatar
2004 28' Classic
Monument , Colorado
Thanks for reviving this thread. Just checked my door handle today. It is very loose, so I will be ordering a new one.
DaveP
2004 Airstream Classic 28 "Willard"
2014 Ford F150 FX4 Ecoboost
DaveP is offline   Reply With Quote
Old 07-17-2018, 06:12 PM   #10
Santa Rosa , California
RFP, what a great solution to a potential problem! I just made your modification to our door. While there, I decided that it would be a good idea to dedicate a screwdriver to this task, and keep it handy. I can imagine doing this mod, needing the screwdriver, only to realize that it's in the toolbox in the outside compartment.
Here's what you'll need.
https://i.imgur.com/6E9lRlo.jpg
Determine the proper placement and install.
https://i.imgur.com/zFrMM0R.jpg
This one lives here now.
https://i.imgur.com/XibBL2R.jpg
--Sean
SeanWasHere is offline   Reply With Quote
Old 07-17-2018, 06:46 PM   #11
RFP
RFP's Avatar
Hurst , Texas
--Sean
Wow, Sean, you are truly prepared!
My little dedicated used-to-be-a-screwdriver thingy lives in the same little box of I'll-need-this-sometime goodies (like fuses, etc.). If I ever need it, I hope I can remember that it's there.
And some stuff
Old 07-17-2018, 09:15 PM   #12
Foiled Again (post #7) is right, RFP has invented a really good solution to a potential issue. This ought to be considered for a Sticky.
Hey Moderators, how about a general "Safety Sticky" for things like this?!?
--Sean
Old 07-17-2018, 09:37 PM   #13
Overkill Pundit
GMFL's Avatar
Dadeville , Alabama
Iíve done Robís emergency exit also. Great backup plan for sure.
Old 07-22-2018, 03:14 PM   #14
Kensington , Maryland
Great stuff Tex I just did this and will add a few more process shots.
AS people are the best.
ID:	317766   Click image for larger version
2017 25' FC FB "Buck"
Subforum dedicated to Airstreams and riding bicycles:
https://www.velocipedesalon.com/forum/f62/
Too tall is offline   Reply With Quote
« Bargman L200 Lock | Top | - »
Simple question, probably not so simple answer AWCHIEF Generators & Solar Power 10 01-23-2016 04:23 PM
Be Prepared!!! Cannonball Waste Systems, Tanks & Totes 2 07-28-2014 02:26 PM
Broken Interior Door Latch Handle!!! Boaz1362 Doors & Locks 9 08-19-2009 02:26 PM
Broken interior door handle Excellaphant 1987 - 1989 Excella 9 12-14-2004 03:08 PM
