Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Windows, Doors, Locks & Vents > Doors & Locks
Old 05-04-2016, 03:20 PM   #1
RFP
RFP's Avatar
2014 23' International
Hurst , Texas
Broken Door Handle? Be Prepared With This Simple Mod
OK, I'm a worrier. When I saw this thread about the entrance/exit door handle breaking off, it got my attention: http://www.airforums.com/forums/f44/...ht-133974.html
Having no interest at all in crawling out the "emergency exit" of our 23D, I started checking the latch mechanism to see if there is a way to get it open even with a totally-broken-off-handle.
As it turns out, there is.
In the attached photos, you will see a little "tab" inside the door latch mechanism. Lifting "UP" on this tab will release the latch... exactly what happens when you turn the handle.
So, a few minutes work with a file to create a "notch" in my screen door frame, and drilling a small hole in the door frame allows me to "trip" the latch with a small Phillips screwdriver (now residing in my inside-the-trailer tool kit).
I bought some fuzzy-side Velcro and made new pads for the door frame. I cut a "X" where the hole is drilled in the frame, and, sure 'nuff, the screwdriver goes right through and with about 5-seconds of hunting for exactly the right place, "POP" my door is open.
I plan on buying a new handle assembly (they are only just over twenty bucks) and carry it as a "spare." This level of preparedness should ensure my handle never breaks!
"Spare" door handle here: http://airstreamsupply.com/New-Airst...e-lh-381547-02
Rob
2014 23D International Serenity - "Fortune Cookie"
2015 Ford F150 3.5 EcoBoost, Max Tow - "Cookie Monster"
And some stuff
Fortune Cookie: https://www.flickr.com/photos/rfpd30...57663633667345
"The Black Swan": https://www.flickr.com/photos/rfpd30...57648991024725
RFP is offline   Reply With Quote
Old 05-15-2016, 05:42 PM   #2
MarkJUrban's Avatar
2016 30' International
Richfield , Ohio
When it happened to me, I didn't have to crawl out the emergency exit. Luckily I was in the driveway. I called and woke up my wife (11pm) to open the door . Next time I will crawl out the window. Or wok on creating the "notch"
MarkJUrban is offline   Reply With Quote
Old 05-18-2016, 01:04 PM   #3
KJRitchie's Avatar
2008 25' Classic
Full Time , Texas
I hadn't seen the thread about the door handle breaking off and getting stuck inside. We've (well, my wife) locked ourselves out. I wasn't at the campground at the time but she managed to crawl through the outside, under bed storage (luckily unlocked) opening to get inside.
I'll have to look at my door to find the magic catch.
Kelvin
Old 05-18-2016, 02:00 PM   #4
RFP
RFP's Avatar
Hurst , Texas
Kelvin
Kelvin,
This little "mod" will be a piece-of-cake for you! Of course, now that I've don the "mod," it's a certainty that my door handle will never break. This is such a super-easy preventive step, I thought a lot of Airstreamers would have shown interest. As for me, I just had a life size mental picture of trying to crawl out the minuscule Emergency Exit window... yuk! Hence, the fix. No acrobatics for this old guy.
And some stuff
Old 09-07-2017, 06:52 PM   #5
2016 30' Classic
Lorton , Virginia
Door handle broke off on me, thanks for the instructions. I was able to slide a knife in to catch the black tab without modifying anything. I'll do your mod soon to make exiting easier.
It is really sad to see how cheap the internals are of this mechanism. The door handle is literally just crimped onto the latch plate inside and will eventually fail for everyone given enough time. Nothing surprises me anymore though with Airstream.
Zybane is offline   Reply With Quote
Old 02-10-2018, 07:33 AM   #6
A W Warn's Avatar
2000 25' Safari
Davidson County , NC Highlands County, FL
I noticed the screen door of my 99 Excella had a notch cut in it and an added piece of Velcro on the inside, but did not know why the previous owner had done this. All I have to do is find a small screw driver!
Thanks for posting this!
Alan
Old 02-10-2018, 12:16 PM   #7
Foiled Again's Avatar
2012 25' FB Eddie Bauer
Virginia Beach , Virginia
[emoji868][emoji108][emoji849] you da man! Super clear and helpful.
Moderators, give this thread a sticky!!!!
Old 02-10-2018, 01:33 PM   #8
HowieE's Avatar
Princeton , New Jersey
Images: 12
I noticed on the other tread about door handles that the mechanism was made by TriMark. About that time, 2014 or so, TriMark made door handles for many motor homes that would fail in the locked position and were under a Federal Recall to replace them. I had to replace the handle on a friends, 75 year old single woman that got locked in her motor home, under the recall. TriMark tried to wiggle out of it but when I quoted the recall number they quickly sent newly designed door assembly.
2004 Excursion 4x4
Old 02-11-2018, 03:41 PM   #9
DaveP's Avatar
2004 28' Classic
Monument , Colorado
Thanks for reviving this thread. Just checked my door handle today. It is very loose, so I will be ordering a new one.
DaveP
2004 Airstream Classic 28 "Willard"
2023 Ram 3500 4x4
DaveP is offline   Reply With Quote
Old 07-17-2018, 05:12 PM   #10
Santa Rosa , California
RFP, what a great solution to a potential problem! I just made your modification to our door. While there, I decided that it would be a good idea to dedicate a screwdriver to this task, and keep it handy. I can imagine doing this mod, needing the screwdriver, only to realize that it's in the toolbox in the outside compartment.
Here's what you'll need.
https://i.imgur.com/6E9lRlo.jpg
Determine the proper placement and install.
https://i.imgur.com/zFrMM0R.jpg
This one lives here now.
https://i.imgur.com/XibBL2R.jpg
--Sean
SeanWasHere is offline   Reply With Quote
Old 07-17-2018, 05:46 PM   #11
RFP
RFP's Avatar
Hurst , Texas
--Sean
Wow, Sean, you are truly prepared!
My little dedicated used-to-be-a-screwdriver thingy lives in the same little box of I'll-need-this-sometime goodies (like fuses, etc.). If I ever need it, I hope I can remember that it's there.
And some stuff
Old 07-17-2018, 08:15 PM   #12
Foiled Again (post #7) is right, RFP has invented a really good solution to a potential issue. This ought to be considered for a Sticky.
Hey Moderators, how about a general "Safety Sticky" for things like this?!?
--Sean
Old 07-17-2018, 08:37 PM   #13
Overkill Specialist
GMFL's Avatar
2020 30’ Globetrotter
Dadeville , Alabama
I’ve done Rob’s emergency exit also. Great backup plan for sure.
Old 07-22-2018, 02:14 PM   #14
Kensington , Maryland
Great stuff Tex I just did this and will add a few more process shots.
AS people are the best.
ID:	317766   Click image for larger version
2019 26' U FC RBT "Buck"
Subforum dedicated to Airstreams and riding bicycles:
https://www.velocipedesalon.com/forum/f62/
Too tall is offline   Reply With Quote
Old 07-22-2018, 03:05 PM   #15
Senior Member
sheriff1's Avatar
2012 27' FB Eddie Bauer
Sparks , Nevada
I did the “safety release “ hole and as I was doing it it occurred to me to attack the root of the problem.Click image for larger version
sheriff1 is offline   Reply With Quote
Old 07-22-2018, 03:18 PM   #16
Like minded Sheriff. My burning question is what is under that plastic that I'm going to drill into?
Just recently ordered and installed this handle for my box trailer. Quality is excellent:
Old 07-22-2018, 05:05 PM   #17
Senior Member
sheriff1's Avatar
Sparks , Nevada
3 screws, pull it off, drill and mount handle like you would on a cabinet and replace. EZ!
Old 07-22-2018, 05:34 PM   #18
RFP
RFP's Avatar
Hurst , Texas
Originally Posted by sheriff1 View Post
I did the “safety release “ hole and as I was doing it it occurred to me to attack the root of the problem.Attachment 317777
Actually, sheriff1, your approach, while both easy and effective, is really a 'Band Aid,' not really attacking the underlying problem. The real problem is the method of swedging the handle to the actuator plate.
The potential weakness of the handle assembly can be mitigated by tapping the hole that is already in the back of the handle (10-28 threads) and installing a washer 'stack,' held in place by a #10-28 screw. Also an easy fix that I'll document once I'm finished wasting time with other little projects.
Your handle idea is a really good one, though... I'm not sure I'm smart enough to remember to use it
And some stuff
Old 07-25-2018, 07:56 AM   #19
Gsmblue's Avatar
2015 25' Flying Cloud
Bend , Oregon
I just threw some picks into the tool box.. actually "0-ring hook scribe set"
https://www.harborfreight.com/2-piec...set-42159.html
I can with a head lamp get in-between the screen door and latch. Not easy, but it is a back up position...
https://britishairstream.blogspot.com
Mad Astrophysicist turned sales guy that works to fund his dirty snowboarding habbit, mwah-ha-ha . . .
Gsmblue is offline   Reply With Quote
Old 07-25-2018, 08:03 AM   #20
Sag Harbor , New York
New short video in Post #9 by Too tall FYI:
http://www.airforums.com/forums/f453...le-184660.html
Simple question, probably not so simple answer AWCHIEF Generators & Solar Power 10 01-23-2016 03:23 PM
Be Prepared!!! Cannonball Waste Systems, Tanks & Totes 2 07-28-2014 01:26 PM
Broken Interior Door Latch Handle!!! Boaz1362 Doors & Locks 9 08-19-2009 01:26 PM
Broken interior door handle Excellaphant 1987 - 1989 Excella 9 12-14-2004 02:08 PM
