Old 06-10-2004, 10:57 AM   #1
mtpalms's Avatar
1971 23' Safari
Joshua Tree , California
Bent strike plate
When we took our maiden voyage a month ago and all went well, except that repeatedly opening and closing the door caused the strike plate to get bent, and not latch
Flash forward to the present, and my somewhat frail father-in-law is living in the trailer in our yard while his house is being finished. We had strong winds last night and when I let the dog out this morning, the trailer door was wide open (because he said it was an easy fix, but hasn't done anything about it, and I am sure the door banging open at high speed wasn't good for the skin).
So. Do we need a special replacement for this, and is it possible (or necessary) to reinforce it behind, so it doesn't bend again?
mtpalms is offline   Reply With Quote
Old 06-11-2004, 10:09 AM   #2
The correct striker plate, is cast metal.
It's also supposed to be riveted in place, therefore can't come loose, or bend.
Not a hardware store item.
Photo attached.
Old 06-11-2004, 10:29 AM   #3
mtpalms's Avatar
1971 23' Safari
Thanks Andy.
I need to order an air conditioning shroud too, and I was waiting to see if this was another item I might need to order too from you, first.
I now suspect that my bent plate is aftermarket (and incorrect), because it is just a regular flat plate with no reinforcement. Since the trailer is going to be stationary for awhile yet, we figured there was no hurry - the wind proved us wrong. Luckily it didn't blow open hard enough to damage the skin.
PS What type of rivet? Olympic okay, or something else? Since it is riveted in place, I don't suppose it can be adjusted to the door once it is in place. How does one install it correctly from the get-go, so it works properly?
Old 06-11-2004, 05:39 PM   #4
mtpalms.
4 each # 48 pop rivets are OK.
Where to place is the key. First, center it vertically. Second, measure the distance from the outer edge of the door to the outer edge of the striker bolt.
Set the striker pocket opening, back, that same dimension.
Old 06-15-2004, 03:35 PM   #5
mtpalms's Avatar
1971 23' Safari
order on hold
The air conditioner, which we had charged lasst month, isn't cooling again. When we had it charged, the guy said he suspected a leak, but couldn't find it. They can't come out again until the 24th, and Dad is living in it, so we can't tow it into town without inconveniencing him (he only sleeps in it, and nights are still cool enough for that). I am putting the shroud order, and therefore the plate order, on hold until we know whether the AC is fixable or needs replaced.
I'd hate to get a shroud and then have to replace the AC unit.
Thanks for your help Andy, I'll be in touch later.
Old 06-15-2004, 03:41 PM   #6
Not much of an AC man if he can't find a leak. Electronic sniffers do that in a heartbeat.
If you can't bring the trailer in, then take the AC off, and bring it in.
Seldom, is it "not" possible to correct the older units.
Old 10-31-2005, 02:59 PM   #7
Strike Plate
Photo attached.
That is very nice Andy, and I need one, so how come you will not sell me just the plate, but insist that I buy the whole lock assembly???
Dick
Navigator is offline   Reply With Quote
Old 10-31-2005, 03:02 PM   #8
Navigator.
Never said that.
The plate is available separately, as it does not come with a lock.
Is a bent axle a "dead" axle?? Jason1101 Axles 11 12-12-2007 04:40 AM
Sealant for furnace intake/exhaust plate lbf78SvgnInt31 Furnaces, Heaters, Fireplaces & Air Conditioning 3 03-08-2004 09:55 AM
Historical License Plate Pick Our Community 7 07-26-2003 08:41 AM
Bent Door Repair Road Ruler Doors & Locks 6 09-02-2002 07:27 PM
TV Connection Plate winner Audio, Video & TV 10 06-16-2002 06:00 PM
