Old 07-12-2003, 09:38 AM   #1
montanaandy's Avatar
Bathroom Door Tracking Out Of Alignment
I picked up my 79-31' International yesterday after having work done at the local RV service center and after towing it home found the sliding bathroom door had jumped off the tracking along the front (far right when facing) bracket. I guess that I have a few questions:
1. Will I have to disassemble the aluminum extrusion in order to get to the plastic slide that the door attaches to or can I just reattach the door to the plastic slide without having to take everything apart? If the plastic slide is ruined, is this a part that is still available?
2. There is a full length mirror that runs the length of the door and which adds a considerable amount of weight to the door. Is this something that came standard or did the PO add it.? I would like to remove it because I don't need it but I was just curious whether this was added or was a standard feature of this era of trailer.
3. Would it be possible to easily retrofit an accordian style door for the bathroom (the trailer has them to separate the bedroom and kitchen/living room areas) which wouldn't be prone to coming off track as readily.
Montanaandy
montanaandy is offline   Reply With Quote
Old 07-12-2003, 01:18 PM   #2
Problem Solved
I was able to find the tracking parts that had come loose and reinstall.
Old 07-12-2003, 02:47 PM   #3
Smokey's Avatar
montanaandy
Is the trailer a rear bath? If so, you remove the door from inside the bathroom side by loosening the philips screws in the top bracket. The door then pulls out from the bottom.
The morror is standard. Once the door is off, the mirror can be removed from the bottom with the door lying flat.
george
Smokey is offline   Reply With Quote
Poor design on slide bathroom door lbrodsky 2001 Safari 15 04-17-2005 08:01 AM
advice wanted for bathroom sink replacement Shelby Copeland Sinks, Showers & Toilets 8 12-25-2003 07:06 AM
Pergo in the bathroom Chuck Floor Finishes 8 08-05-2003 05:13 PM
bathroom compartment - removal? Cruiser General Interior Topics 7 05-16-2003 07:24 PM
Need some help and suggestions on bathroom escapeez Plumbing - Systems & Fixtures 2 05-14-2003 12:05 AM
