Old 06-15-2011, 08:03 PM   #1
2005 19' Safari
Wausau , Wisconsin
Bathroom door handles
bathroom door is 1"thick. Handle protrudes into bedroom 2 1/4" and into bath 2 3/4". "L" shaped handles snag skin, garments, etc. My waist measures 34" (when inhaling). I want to replace with less invasive (skinnier) handles. Replacements on hardware market are for 1 1/2" doors. AS parts have no replacements nor ideas. Any help out there?
widinger@aol.com
Al Dinger is offline   Reply With Quote
Old 06-15-2011, 08:14 PM   #2
2011 25' FB Flying Cloud
Anywhere & , Everywhere
http://www.airforums.com/forums/f453...tch-32520.html
These are available from the Airstream store but cost is about 150 bucks. They were available elsewhere for about half that and I think that source is mentioned in this thread.
Al - K4GLU is offline   Reply With Quote
Old 06-15-2011, 08:28 PM   #3
TBRich's Avatar
2006 19' Safari SE
Tucson , Arizona
Images: 64
We call our bathroom door handle "Captain Hook"... Airstream began using a different one (the flush one) in 2007. We'd love to replace it with something else if it's not too complicated.
TB & Greg and Abbey Schnauzer
#3954
Old 06-15-2011, 09:36 PM   #4
Johnco's Avatar
2006 19' Safari
Anaheim , California
The handle that is standard now can be purchased thru Perlane Sales, Inc. Perlane Sales- Rivnut, plusnut, insert, fastening systems, and more. Phone is 330-928-4866
The part number you are looking for is MR-04-106-24
You'll have to do a little cutting and a little reinforcement to the hollow core door, but the results are worth the effort...no more ripped pockets and snagged shirts. Cost was $70.00 plus freight.
Johnco is offline   Reply With Quote
Old 06-17-2011, 12:55 AM   #5
KerriO's Avatar
2008 27' International CCD FB
Bay Area , California
The previous owners cleaned our inside bathroom door handle with something that completely stripped off the finish. We replaced the handleset with one from OSH that looked nearly identical for less than $20, IIRC. It was made for a thicker door, but the part that is too long could just be hacksawed down with no ill effect. I'd just try to find a standard knob in the style you want and make sure you can cut or file down the core before installing.
[[ Captain's Log ]] Our full-time journey in our 27'FB International
KerriO is offline   Reply With Quote
Old 06-20-2011, 04:12 PM   #6
ESCAPE POD's Avatar
2007 19' Safari SE
Seal Beach , California
Talking $24 mod to replace bath door handle
OK, so it's not a flush-mounted replacement handle, but the total cost for parts was $24, and no wood cutting, shaping, etc. Took an hour (which includes 30 minutes of "am I doing this right?" second-guessing). Removed handle assembly and strike plates, then replaced with closet door "disk" handle inserts, drilled for the knobs. The latch is a spring-loaded ball bearing that nests into a depression in the new strike plate. To eliminate any rattling (which was a problem with the original door as well), I placed a small patch of velcro on the door frame next to the strike plate to keep the door quiet. The brushed aluminum looks pretty good, IMHO. Goodbye, Capt. Hook! [See photos]
Name:	%22Capt Hook%22.jpg
ID:	132907   Click image for larger version
Name:	Hardware removed.jpg
Name:	Door hardware.jpg
ID:	132909   Click image for larger version
Name:	New strike plate.jpg
Name:	Drilled door disk handle.jpg
ID:	132911   Click image for larger version
Name:	New handle.jpg
Name:	Ball bearing latch.jpg
ID:	132913   Click image for larger version
"I have found through trial and error that I work best under duress. In fact, I work only under duress." -Ed Abbey
Jerry & Susan
2007 19' Bambi SE; 2010 Ford F-150 5.4L SuperCrew 4x4 w/ FlipPac camper shell
ESCAPE POD is offline   Reply With Quote
Old 06-20-2011, 05:14 PM   #7
Lost in America
mojo's Avatar
2015 27' FB International
2004 19' International CCD
Santa Fe , New Mexico
So where does one find such a knob?
This is the strangest life I've ever known - J. Morrison
2015 Airstream International Serenity 27FB
2017
Chevy Silverado 2500HD Duramax Diesel
mojo is offline   Reply With Quote
Old 06-20-2011, 05:45 PM   #8
ESCAPE POD's Avatar
2007 19' Safari SE
It's a drawer-pull knob from a local hardware store. There is usually at least one model that is brushed aluminum.
Jerry & Susan
Old 06-20-2011, 06:24 PM   #9
SilverRanger's Avatar
2005 19' Safari
1968 24' Tradewind
Rural , Delaware
Thumbs up
ESCAPE POD
Excellent solution. Although it's not nearly as aesthetically pleasing as yours, here is what I did to solve the belt loop problem. I had all of the parts on hand, so it didn't cost much.
These are stainless electrical outlet cover plates with a drawer pull on the outside and a hole on the inside, which is nearly flush with the door. Solved the problem (and we can still hang stuff on the knob).
ID:	132927   Click image for larger version
2005 Bambi
1968 Trade Wind
2007 Ford F250 4x4 Crew
WDCU
SilverRanger is offline   Reply With Quote
Old 06-21-2011, 04:38 PM   #10
2005 19' Safari
Wausau , Wisconsin
Ranger, How do you keep door closed tightly and secureley when on the road? Looks great. Easy Sawyer
Old 06-21-2011, 05:27 PM   #11
elfirebob's Avatar
2007 25' International CCD FB
1970 23' Safari
1956 16' Bubble
Jamul , California
Images: 159
We retrofitted with Perlane SouthCo latch.
Easy,
We went with Johnco's suggestion after seeing in on Daystreamr's website a few years ago.
See this thread:
for the install, easy and I do not remember removing that much material. My install was just opening up the existing hole with a coping saw and some minor file work. Clean with no snags, and locks the door.
We also had a '06 19'Bambi, understand the issue.
Good luck-
Stream Safe,
Bob U-
San Diego, CA.
The " TinDen "
2007 25' International FB
1970 Safari 23' Land Yacht
1956 Bubble 16' California Whale Tail
Charter Member 4 Corners Unit
(View all of elfirebob's images)
elfirebob is offline   Reply With Quote
Old 08-18-2019, 01:28 PM   #12
2010 30' Flying Cloud
Fulshear , Texas
2017 30' classic. Bathroom door handle lever down extends lock, lever up will retract and open the door. Notice a small spring out of place when I pull out the locking probe. Prior to today, the lever up or down would open the door.
Thought I would wait till I get home to try to disassemble and repair. Not sure if I will need a new handle mechanism or this one can be repaired.
If anyone has a similar issue and has some advise, I would appreciate it.
Part Time is offline   Reply With Quote
Bathroom pictures 1974crane General Repair Forum 0 06-03-2011 04:01 PM
Bathroom sliding door polarlyse General Interior Topics 2 05-21-2011 07:54 PM
What is this tank in my Cloud bathroom? MontanaAIR Fresh Water Systems 3 05-15-2011 01:18 PM
19' Airstream Bambi bathroom Sactown 2005 and newer - Bambi all models 6 04-06-2011 08:02 PM
composite flooring bathroom installation sealing the toilet handn Floor Finishes 1 03-10-2011 06:47 PM
