Old 01-01-2013, 05:35 PM   #1
desertair27's Avatar
1960 26' Overlander
1963 24' Tradewind
El Paso , Texas
Images: 32
Well I need some help locating some Bargman H20-0 door lock. I have the outer handle just need everything else including the inner handle.
Anybody have any extra parts they'd be willing to sell or have an idea where I could locate them?
This is what I have.
ID:	175736   Click image for larger version
desertair27 is offline   Reply With Quote
Old 01-01-2013, 05:52 PM   #2
Top
Always learning
Top's Avatar
1972 29' Ambassador
1962 19' Globetrotter
1951 21' Flying Cloud
Central , Texas
Images: 24
Send a message via Yahoo to Top
Keep an eye out on Epay and the forums classifieds. They were used on many different trailers, so expand the searching to other brands from the 50s.
Good luck!
Lance
Top is offline   Reply With Quote
Old 01-01-2013, 06:13 PM   #3
toastie's Avatar
1955 22' Safari
Great Lake State , .
try VintageCampers.com :: Vintage Campers, Vintage Trailers, Vintage Parts, Vintage Restorations
toastie
toastie is offline   Reply With Quote
Old 01-01-2013, 06:43 PM   #4
BradS's Avatar
2006 22' International CCD
1957 26' Overlander
Plymouth , Minnesota
Images: 14
Send me an email if you cant find the lock. Do you want right hand or left hand? Vintage Campers is usually a great source. I do have some extra stuff around and I know I have at least one lock
My 57 Overlander thread ( Holly is her name)
http://www.airforums.com/forums/f97/...eak-62257.html
"Life itself is the most wonderful fairy tale"
(Hans Christian Andersen)
WBCCI 10289
TAC MN-69
AIR 11240
BradS is offline   Reply With Quote
Old 01-01-2013, 07:11 PM   #5
reinergirl's Avatar
Hollis , New Hampshire
You sure it's not kicking around in a tin can?
You have a lock that's not been in production for a very long time. Most people end up buying a few on eBay or wherever and cobbling a complete one together.
Some have purchased entire trailers, only to use just the door mechanism. Not trying to discourage you...just that you're probably not going to find a whole one somewhere, take parts as you find them and eventually you'll have what you need.
The " rest of the lock" is in between the door panels, you sure it's missing, not just behind the panel? I believe what you need is actually the L44 or L45 set up.
reinergirl is offline   Reply With Quote
Old 01-02-2013, 07:18 PM   #6
1960 26' Overlander
1963 24' Tradewind
El Paso , Texas
Images: 32
Talking Parts found!!!!!
Thanks everyone,
Vintage Campers had 2 of the inner mechanisms in stock along with the inner handle listed under Barmann L-55,I was searching for the H20-0.I'm learning thanks to all you guys now I know.
Sherri,
You're funny girl! Believe me I've searched every square inch of that trailer. This lock is for a 57 Caravanner and it has an ugly brass house lock.Whats weird is I'm pretty sure the H20 should have been on there originally but the door is cut for a typical house hold lock like it has. Does anyone know if anything other than the H20 could have been spec'd on this model?
Thanks again Lance, Toastie, Brad and Sherri!
