Old 08-10-2007, 02:49 PM   #1
Ham KI4HJX
1982 27' Excella
1970 23' Safari
Franklin , 28734
Bargman L300
I replaced the missing door lock assembly on my 1982 Excella with a Bargman L300. I had to recut the hole in the outer skin (the original was real rough cut) because the Bargman was wider and not as tall as the original. Also the Bargman comes with a new striker plat with slots to accept the two sholder bolts that come with the new lock. This is the new DOT standard I guess? I had to cut two grooves in the jam to allow the bolt heads room to engage the slots in the striker plate. I did all my cutting with a die grinder and a cut off blade. After fitting the lock I made a trim plate out of a piece of scrap to cover the old hole that showed at the top. I used 1/4 inch high strenght pop rivets to hold the striker plate in place and 1/8 inch rivets to hold the trim piece on. I will try to post some pic's if I can borrow a camera from someone.
Ramp is offline   Reply With Quote
Old 08-19-2007, 11:07 AM   #2
The L-300 is a lock designed for motor home use, not travel trailers.
Old 06-24-2009, 08:53 AM   #3
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
I am getting ready to do this install on my 80 Excella, a Bargman L-300 lock to replace the silly handle that the P.O. put in . I stumbled across a great link with directions for a similar job although not the same lock assembly the idea is right... Thanks to those whop posted this
1975 Airstream Door Lock Replacement
My questions will come when I pull off the lock asembly on there now and see what I find inside the door, hopefully it will all come together. I am off now to buy the aluminum sheet for the covering portion.
1966 overlander..sold
AIR #005
OUR AIRSTREAM PASSION! BLOG
RESTORING AN AIRSTREAM
retired!
Old 06-24-2009, 10:44 AM   #4
Silverhobby's Avatar
1967 26' Overlander
1968 30' Sovereign
Mosheim , Tennessee
It seems with so many of the AS items no longer being built, the trailer itself is the only thing not "orphaned." I know that AS uses parts from other suppliers, but it seems building the best travel trailer in the world, they would use the best materials and products to be found. JM2CW
//------AIR # 7303------\\
WBCCI 17109
visit my restoration blog at:
Old 06-25-2009, 03:25 PM   #5
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
Ya'd THINK?
AIR #005
retired!
Old 06-25-2009, 04:48 PM   #6
Please be advised that the L-300 lock will give you some grief when you try to install it in a trailer door.
That is not the lock kit that we suggest as a substitute for the trailers, because of the changes you will need to make to the door.
Please let us know how you did with it.
Old 07-03-2009, 04:41 PM   #7
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
Will do....I have RAMPS directions, he did well with it.
AIR #005
retired!
Old 07-05-2009, 09:25 AM   #8
Gunter
gunner's Avatar
2000 35' Land Yacht XL w/2 slides
Greenville , Ohio
Is the L300 used on a 1984 Motor Home. I need a new Inside Plate. Can I just purchase the Inside Plate or do I have to purchase the whole assembly? I assume it is still available from the dealer. Any idea what the cost is for either the plate or the assembly?
Gunter
2000 Land Yacht XL 355
gunner is offline   Reply With Quote
Old 07-05-2009, 09:56 AM   #9
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 40
The problem isn't so much with Airstream as it is with the independent suppliers. If a supplier stops providing something Airstream doesn't have much choice except to find something else that will work. Also I suspect that AS prefers to purchase something that will do the job for a lower price to help keep the profit margins up.
Aaron
WBCCI #XXXX AIR #2495
Old 07-06-2009, 08:11 AM   #10
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
I believe it is the same. I found mine from the RV Parts online store. 80 bucks.
If you need measurements PM me.
AIR #005
retired!
Old 07-07-2009, 05:16 AM   #11
Gunter
gunner's Avatar
Greenville , Ohio
Went to Jackson Center yesterday and they advised that my lockset is no longer available even though mine looks like a L300 based on pictures I saw in catalogs. They provided a kit that converts mine to another type of lockset with inner and outer plates to cover up any hole size variances on the outer and inner skin. They advised that this kit is used on both trailers and motorhomes that there is no difference. The kit they provided appears considerable more robust than my current lockset. There were no instructions or information with the kit. They just handed me a bunch of parts put some in a bag gave me verbal instructions and that was it. The lockset has the name Tri/Mark, New Hampton, IA stamped on it.
Gunter
Old 07-07-2009, 06:16 PM   #12
ALANSD's Avatar
1966 26' Overlander
Woodstock , Georgia
Hope that works well for you. My 280 Classic motorhome had the L series lock, and I was easily able to repair the tumbler when it stopped locking. I am holding off installing until I come back form a weekender later this month. Will post the results for sure.
AIR #005
retired!
Theodore Bargman Box Craig 1978- 1979 Excella 500 26 03-16-2014 04:02 PM
Bargman #6 Tailight- What bulb? Creampuff Lights - Interior & Exterior 4 12-21-2006 02:05 PM
Bargman 99 Question Number99 Lights - Interior & Exterior 18 07-08-2006 10:07 PM
Bargman 99 & LEDs? walter1 Electrical - Systems, Generators, Batteries & Solar 27 03-10-2006 06:59 AM
Bargman #99 wedding cake Tail light needed cindy Lights - Interior & Exterior 8 10-16-2002 08:52 AM
