Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Windows, Doors, Locks & Vents > Doors & Locks
Old 04-07-2015, 05:20 PM   #1
desertair27's Avatar
1960 26' Overlander
1963 24' Tradewind
El Paso , Texas
Images: 32
Bargman L100 needs outer knob
I have this newer style L100 that needs the outer knob. I have located a couple of outer knobs but the lock inner parts are totally different than any I've seen and I'm worried the outer knob may not fit. Anyone ever seen one like this?
Name:   ImageUploadedByAirstream Forums1428448762.413769.jpg
Name:   ImageUploadedByAirstream Forums1428448779.617239.jpg
Name:   ImageUploadedByAirstream Forums1428448794.725052.jpg
desertair27 is offline   Reply With Quote
Old 04-07-2015, 07:21 PM   #2
1997 25' Safari
1973 25' Tradewind
Greenville , South Carolina
That is a Chesler lock. If you want a new or used Bargman L-100 lock which will fit directly in the same door opening, send me a private message r_whiten@hotmail.com and I will help you. I have one Chesler lock but from your picture I am not sure your lock can be repaired.
Rick (Montanablue)
montanablue is offline   Reply With Quote
Old 04-07-2015, 09:30 PM   #3
1960 26' Overlander
1963 24' Tradewind
El Paso , Texas
Images: 32
Name:   ImageUploadedByAirstream Forums1428463762.844562.jpg
Are you sure about it being Chesler?
Old 04-08-2015, 06:31 AM   #4
1997 25' Safari
1973 25' Tradewind
Internal pictures of the Chesler and Bargman L-100/200 locks.
Here are a couple pictures of the inside parts to a Chesler lock:
Name:	photo 1 (5).JPG
Name:	photo 2 (6).JPG
Then here are pics of the Bargman L-100/200 insides:
Name:	L-100 Parts.JPG
Both locks have very different internal parts. The only difference in the Bargman L-100 and L-200 lock is the inside handle. The internal parts are the same.
I hope this helps you the difference between the two styles.
Rick
Old 04-08-2015, 09:23 AM   #5
1960 26' Overlander
1963 24' Tradewind
El Paso , Texas
Images: 32
Thanks Rick
another Bargman L100 question 65will Windows, Doors, Locks & Vents 3 04-29-2014 02:13 PM
Outer skin of unit (roof to outer wall) jaharper Ribs, Skins & Rivets 1 08-01-2011 01:05 PM
Bargman L100 lock 63 Safari airstream4 Doors & Locks 2 09-03-2010 05:18 PM
