Old 08-31-2010, 11:34 AM   #1
airstream4's Avatar
1997 34' Limited
1963 22' Safari
Troy , Michigan
Question Bargman L100 lock 63 Safari
My 63 Safari has a L-100 lock that doesn't latch! The extension is 1/2" but is from the inside of the door mounting, There is a nylon striker plate on the trailer door frame that extends 1/4" into the opening, but has a clear opening where the striker would catch on the aluminum exterior. Is there a special L-100 with a slightly longer extension?
Should I build up the striker plate so door latches?
The L-100 has a slight opening on the right side of the external handle, 1/16", so I assume the L-100 was not the original lock. What's available?
Paul
Paul
Troy, MI
1963 22'Safari
1997 34' Classic FK
airstream4 is offline   Reply With Quote
Old 08-31-2010, 11:57 AM   #2
Paul
The L-100 was standard on a 63.
Sounds like your striker pocket is broken.
Old 09-03-2010, 05:18 PM   #3
airstream4's Avatar
1997 34' Limited
1963 22' Safari
Troy , Michigan
Thanks Andy!
Your right again! I ordered, Inland rv shipped, I received today and installed! Door and dead bolt close nicely!!!! Ordered late tuesday, I expected next week coming from California but 72 hours later its installed!
Thanks for the answer and thanks for the GREAT SERVICE!
Paul
Paul
Troy, MI
1963 22'Safari
1997 34' Classic FK
Bargman L-77 Door Lock mello mike Doors & Locks 9 08-19-2010 07:35 PM
Bargman L-77 Door Handle Lock Assembly Bob Parker Doors & Locks 7 05-06-2010 04:41 PM
Needed Bargman Door lock yoderconsult Doors & Locks 6 03-24-2010 10:56 PM
Found....new Bargman door handle/lock for many '50s to '60s Rog0525 Doors & Locks 45 10-31-2009 12:05 AM
Bargman lock pin removal pken-do Doors & Locks 1 04-12-2009 08:30 PM
