Old 07-25-2015, 06:40 AM   #1
Youngstown , Ohio
Bargman L-200 inside handle fell off
Hi. How is the inside handle on our 68 Tradewind Bargman L-200 held on. Found the whole handle laying on the floor this morning. Slid it back in and everything still works. Still unlocks, etc but pulls right out. Is there a washer or set screw or what can I do to fix. Thanks.
Splinter is offline   Reply With Quote
Old 07-25-2015, 06:43 AM   #2
Youngstown , Ohio
Name:	ImageUploadedByAirstream Forums1437828105.181133.jpg
Name:	ImageUploadedByAirstream Forums1437828144.134362.jpg
Old 07-25-2015, 08:32 AM   #3
HowieE's Avatar
Princeton , New Jersey
Images: 12
Look at the handle shaft. Is there any indication of a C ring groove at the end that would have held the handle in place If so remove the face plate and you should see how to replace the ring.
If not remove the face plate and investigate thing inside.
2004 Excursion 4x4
Old 07-25-2015, 11:19 AM   #4
Youngstown , Ohio
Name:	ImageUploadedByAirstream Forums1437844735.188587.jpg
Old 07-25-2015, 11:19 AM   #5
Youngstown , Ohio
Howie is that the groove?
Old 07-25-2015, 11:27 AM   #6
HowieE's Avatar
Images: 12
My guess is yes. Was there a plate between that grove and the handle side that would have held the handle to the plate if a clip was in that groove?
Did you find any small bits of metal that could have been a C clip when you open it up?
2004 Excursion 4x4
Old 07-25-2015, 06:24 PM   #7
Youngstown , Ohio
Heading out for a week. Gonna take it off when I return. Thanks for your help and I will let you know the outcome HowieE.
Old 07-26-2015, 11:34 AM   #8
1978 Argosy Minuet 6.7 Metre
1971 27' Overlander
1973 31' Sovereign
Griffin , Georgia
Images: 14
not sure if we're talking about the same thing... but I just replaced my missing handle on the inside, L-200. It has a set screw on the underside, that holds it in place...
hope your repair will be that easy. Have fun, and safe travels!
paddle whisp is offline   Reply With Quote
Old 08-05-2015, 03:06 AM   #9
Arrowstream's Avatar
Columbia , South Carolina
There's a washer and a hairpin clip that holds the handle on.
Arrowstream is offline   Reply With Quote
Bargman L-200 lock replacement - 1968 mjmcwhorte 1965-1969 Sovereign 5 01-30-2015 09:13 PM
Interior handle of front door fell off.... holtenc Doors & Locks 4 11-06-2013 02:26 PM
Bargman L-200 Door Handle Lock reedflute General Repair Forum 3 04-14-2012 03:50 PM
