Old 03-04-2011, 05:09 PM   #1
Phly36's Avatar
1976 Argosy 24
Loomis , California
ARGOSY Door Lock Repair/Replace
The door lock on my 1976 Argosy does not lock and is about to break key off. Has anyone out there been able to repair or replace such a problem?
Phly36 is offline   Reply With Quote
Old 03-04-2011, 07:27 PM   #2
1978 Argosy 27
Lacey , Washington
Images: 8
Pic please. There were some cross over locks during this period. jjustice
jjustice is offline   Reply With Quote
Old 03-04-2011, 09:31 PM   #3
loudruff's Avatar
1978 Argosy Minuet 6.7 Metre
1989 29' Excella
Lorain County , Ohio
Send a message via AIM to loudruff Send a message via MSN to loudruff Send a message via Yahoo to loudruff
locks
A good full service locksmith is a good place to start. We were able to get ours done. We have a 1978 Argosy Minuet.
Larry and Lou
CP: Water/30 amp/waste dump/WIFI & Room for 2-3 units; PM us if you are headed our direction!
Air #2695
TAC- OH 2
#1420 NOVA 4-006 Charter member
loudruff is offline   Reply With Quote
Old 03-04-2011, 10:21 PM   #4
Your lock is called a "KT" lock.
It's unique to Airstream "ONLY".
Therefore a locksmith will not have any parts for it.
Some Airstream dealers can overhaul that lock for you.
Old 03-04-2011, 11:43 PM   #5
loudruff's Avatar
1989 29' Excella
helpful thread
You may want to read through this thread about the KT Lock.
http://www.airforums.com/forums/f453...ion-73252.html
We may have been lucky in dealing with our 3 generation old time locksmith who is local. They were successful in finding parts and getting ours working. If you have a locksmith that has been around awhile you might get lucky. It is worth asking. Don't know if our 78 Argosy Minuet has the KT lock.
Larry and Lou
Air #2695
TAC- OH 2
Old 03-05-2011, 02:58 AM   #6
KT locksd were used on the 1970 to 1977 models, both Argosy (when they came to be) and Airstream.
1978's used Keeler Brass locks.
Old 03-05-2011, 10:21 PM   #7
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Success
If your door handle and lock looks like this. Yes, I have had success in getting mine to work again.
Old 03-05-2011, 10:50 PM   #8
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Question for Andy at Inland. What year trailers had the L77 Lock set?
Old 03-05-2011, 10:56 PM   #9
loudruff's Avatar
1989 29' Excella
Thanks, Andy! I will write that down somewhere.
Larry and Lou
Air #2695
TAC- OH 2
Old 03-06-2011, 11:21 AM   #10
Old, old, real old Airstreams.
I am not positive, but late 50's.
Old 03-06-2011, 11:53 AM   #11
Colin H's Avatar
1957 30' Sovereign of the Road
1959 28' Ambassador
1949 24' Limited
Peru , New York
59 & 60
Colin
Colin H is offline   Reply With Quote
Old 03-06-2011, 01:13 PM   #12
1978 Argosy 27
Lacey , Washington
Images: 8
I had to replace my door lock in my '78 Argosy 27'. When I ordered from AS they sent me the squarish looking one that was the correct one for the '78s but I found out that AS back in the '70s sometimes used parts from previous yrs and that was my case. So my lock is the rectangle lock and the replacement came from - - you guessed it-- China. The lock cylinder lasted a whopping six months before it jammed. I contacted AS and they sent me a replacement cylinder with a new set of keys but I would need to take the whole assembly off the door to replace the cylinder and that means a repainting the door (Argosy remember) and thus it won't happen. So I disabled the locking mechanism and place an external lock at the bottom of the door. It keeps the door secure while we go down the road but won't keep an intruder out. I was not a happy camper when the new lock broke in less than 7 months from being installed. AND by the way the new China lock cost over $450!!!! Someone made a great deal of profit on that sale.
Old 03-06-2011, 02:13 PM   #13
Sounds like you have the KT lock.
If so, the tumbler can be changed out in 30 seconds, without ever having to remove the lock.
Old 03-06-2011, 02:40 PM   #14
Colin H's Avatar
1959 28' Ambassador
1949 24' Limited
Peru , New York
Yeah, that is sad isn't it. I've seen pitted old KT locks without keys go on ebay for $250. My best suggestion for you is to install a dead bolt. This gives you great security. They are available through Vintage Trailer Supply. com & other suppliers. I typically drill & tap the end of the dead bolt & install a 3/8 SS hex bolt & cut off the head. This allows you to offset the cylinder slightly & minimize the size of the hole in the door frame & door. This retains as much of the strength in the door & frame structure as possible. The cylinder should be installed in the wall, not the door.
Colin
What's a 1975 Argosy 26' worth? ValerieW Argosy Motorhomes 8 03-08-2017 10:41 AM
1976 Argosy wrap window install Michael W Windows & Screens 0 02-28-2011 09:20 PM
1973 Argosy / Airstream Camper - $4100 (Newark) 61Ambassador Airstreams on eBay 4 02-13-2011 11:11 AM
22' 1975 Argosy rear door CMSmith All Argosy Trailers 5 02-06-2011 08:36 PM
Argosy Door TG Twinkie Doors & Locks 7 01-29-2011 06:11 PM
