Old 07-15-2011, 08:02 PM   #15
1976 Argosy 24
West Allis , Wisconsin
Argosy 24 door latch
Where can I purchase a door latch for an Argosy 24? The latch is manufactured by Bargman. I'm wondering if there is a retrofit replacement which will work without all the Bargman problems like the door flying open when you're going down the road and other horror stories that I hear.
btophek is offline   Reply With Quote
Old 07-15-2011, 08:59 PM   #16
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
I have a '74 Argosy with the infamous KT lock. I purchased a new lock cylinder and key and installed it. The problem with my KT lock is that the hole where the cylinder is located is sooo worn that the cylinder is lose. The new lock pin from VTS is not an exact replica of the original; this combination is not very reliable. I can lock and unlock the KT mechanism, but there are times it takes a lot of fiddling to get it done.
I just decided that getting locked out wasn't worth the hassle of trying to lock the door with the KT lock assembly. So I bit the bullet so to speak and installed a deadbolt lock mechanism.
It took a bit of thinking because there is no room to install the dead bolt in the door and have access to the inside lock handle without modifying the screen door.
So I decided to install the lock mechanism in the trailer body and have the bolt go into the door. I've attached a few photos. It works great by the way.
The door on my Argosy is extruded aluminum. I'm not sure if this set up would work on a door with a cast frame since it requires cutting thru one side of the frame, because the door frame is so thin. You can see the frame reinforcement plate that I fabricated for the inside of the door in order that the bolt is held by more than just the striker plate on the edge of the door.
A couple of days ago I did see an add either on eBay or here in the classifieds, 2 NOS (new old stock) KT locks; One was $375.00 and the other $425.00.
It cost me less than $25.00 to install the dead bolt. Just bought a regular single dead bolt at the big box store. Made sure I got one with a long stroke bolt.
ID:	134916   Click image for larger version
Name:	Inside Dead bolt.JPG
Name:	Edge Of Door.JPG
ID:	134918   Click image for larger version
Old 07-15-2011, 10:46 PM   #17
1978 Argosy 27
Lacey , Washington
Images: 8
Andy,
I would like to have someone go over the steps in doing that. I could not find how to get in there to makethe switch. jjustice
jjustice is offline   Reply With Quote
Old 07-16-2011, 04:33 AM   #18
Originally Posted by jjustice View Post
Andy,
Get a #8 sheetmetal screw about one inch long.
Screw it into the tumbler about 1/4 inch.
Have a small piece of thin plywood handy, along with a claw hammer.
Place the wood below the tumbler to protect the sheetmetal.
Place the claw hammer on the wood and grab the screw with the claw.
Give it a quick "YANK".
That's it, the tumbler will easily pull out.
Old 04-07-2015, 11:33 AM   #19
1973 Argosy 26
Granby , Massachusetts
Those switches
I know this has nothing to do with the lock, although I am planning on replacing the tumbler and it's good to know it's not an exact fit. Anywho, TG, what are the 2 switches to the left of your door in the picture. I have figured out one goes to the light outside but can't figure out what the other one is.
CordellCampr is offline   Reply With Quote
Old 04-07-2015, 12:27 PM   #20
The Sign Lady
1969 23' Safari
1974 Argosy 22
1964 24' Tradewind
Victoria , British Columbia
If it was made by Bargeman there is a small stamped code somewhere on it that a decent locksmith can look up the code and cut a new key by the code alone. I took my whole handle/lock set in to Hubers Lock and Safe near me in Victoria BC because I was frustrated with the looseness of the key in the handle, I was just planning to get him to re tumble it. Turned out the key I had wasn't even made for the trailer it just kinda worked, but not really.... they looked up the code online, cut me a proper key and now I am happy :-)
1969 Airstream Safari
thesignlady is offline   Reply With Quote
Old 04-07-2015, 02:28 PM   #21
1976 31' Sovereign
Oswego , Illinois
Smile door locks
A lot of earlier AS have 2 swts. when facing door from outside,1 over door light other scare light [out side flood light on door side just before front curved panels] they are in front of side window at top of window level, other wise some else will no what other swt. is for I only no of this use. Bill
featherbedder is online now   Reply With Quote
Old 04-07-2015, 02:33 PM   #22
1976 31' Sovereign
Oswego , Illinois
Posted else where on forums, a simple block of wood cut to pattern shown will keep AS great engineering idea of suicide doors from flying open.
Old 04-07-2015, 02:51 PM   #23
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
The 2 switches are the scare light and over door light. Scare light is the round fixture on the right side as you enter the coach.
Old 04-07-2015, 03:58 PM   #24
The Sign Lady
1969 23' Safari
1974 Argosy 22
1964 24' Tradewind
in my trailer there is only one exterior light and the second switch operates the midship light, the one in the center of the ceiling just before the bathroom. That ceiling light also has its own switch and must be switched to an on position for the wall rocker switch to operate it. Many, many a new airstream owner has thought they had a defective wiring or light just to find out they didn't know what that second switch did. I was one of them :-)
What's a 1975 Argosy 26' worth? ValerieW Argosy Motorhomes 8 03-08-2017 10:41 AM
1976 Argosy wrap window install Michael W Windows & Screens 0 02-28-2011 09:20 PM
1973 Argosy / Airstream Camper - $4100 (Newark) 61Ambassador Airstreams on eBay 4 02-13-2011 11:11 AM
22' 1975 Argosy rear door CMSmith All Argosy Trailers 5 02-06-2011 08:36 PM
Argosy Door TG Twinkie Doors & Locks 7 01-29-2011 06:11 PM
