Old 09-09-2018, 08:27 PM   #1
1977 27' Overlander
Portland , Oregon
Anyone know how to raise a door?
Working on a 76 Overlander. Getting the bent door back into shape and itís starting to fit perfectly but needs to go up a little. If I lift up a little at the hinge, it fits perfectly. Do they sell hinge spacers / bushings to raise the door up on the pin a few millimeters? Or do I need to pop the pin out somehow and put a washer in?
ID:	322063   Click image for larger version
licoricewhip is offline   Reply With Quote
Old 09-09-2018, 08:28 PM   #2
1977 27' Overlander
Portland , Oregon
Photos sideways but you get the jist.
Old 09-09-2018, 09:21 PM   #3
Overkill Specialist
GMFL's Avatar
2014 23' International
Dadeville , Alabama
Nylon spacers.
Old 09-09-2018, 09:58 PM   #4
dznf0g's Avatar
Oswego , Illinois
Steel e-clips stacked.
-Rich-
Old 09-09-2018, 10:40 PM   #5
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
Davidson County , North Carolina
This is the part you can use (or cut similar from a nylon washer)
https://www.homedepot.com/p/The-Hill...1395/204726250
This thread is a pretty good discussion of the problem
http://www.airforums.com/forums/f453...ers-98898.html
Alan
2014 Silverado 1500 Crew Cab 5.3L maximum trailering package
A W Warn is online now   Reply With Quote
Old 09-09-2018, 11:02 PM   #6
1977 27' Overlander
Portland , Oregon
Thanks guys! Iíll do the e-clips since an actual washer / spacer would require pulling the pin. Cheers!
Old 09-10-2018, 08:57 PM   #7
2018 33' Classic
Medway , Massachusetts
You can make a "C" washer with nylon or delrin of exactly the right thickness (easy with a lathe) or manually by sanding. Just make the slot slightly more narrow then the diameter of the pin and it will snap on like an e-clip and stay there.
M
MAHofer is offline   Reply With Quote
hello, I was wondering if anyone here is from Las Vegas and know of anyone that rents kikiboi Our Community 6 01-05-2014 04:52 PM
Jack lowers but will not raise trailer-help! wayner1239 Jacks, Stabilizers, Lifting and Leveling 5 05-10-2005 07:00 PM
I need a raise! seaaudio Axles 14 05-21-2004 11:04 AM
Raise the toilet FrankR Sinks, Showers & Toilets 0 03-15-2002 10:57 PM
