Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Windows, Doors, Locks & Vents > Doors & Locks
Old 10-12-2006, 10:12 PM   #29
NorCal Bambi
NorCal Bambi's Avatar
Profile:  1963 16' Bambi
Yreka , California
Images: 21
Lets see is door work "WORK". Besides locking both locks on our door before we move the trailer I also tie the door with a piece of rope. I hope that sayes it.
Don
NorCal Bambi is offline   Reply With Quote
Old 10-12-2006, 10:23 PM   #30
Safari Tim
a.k.a. Ambassador Tim
Safari Tim's Avatar
Profile:  1960 28' Ambassador
Northern , California
Images: 35
Realigning a bent door, is easy. There are many ways to do it.
I'm curious what the many ways are...
-Tim
theVAP - Airstream Podcast | My Airstream Home Page | My Photo Gallery
Old 10-13-2006, 02:23 PM   #31
LI Pets
Silver Mist
LI Pets's Avatar
Profile:  1977 31' Sovereign
Riverhead , New York
The Jig
I lined up a 2x6 scribed it and used a saws all to cut it.
You can make it full length, mine was ok near the top so I used a shorter piece of wood.
'77 Sovereign Intl 31' CB
'07 GMC 4x4 2500HD EC 8.1 Allision six | Bedrug | Softopper | Airbags
WBCCI
Time's a-changing Say no to Lawrence Welk attitudes
Old 10-13-2006, 02:29 PM   #32
LI Pets
Silver Mist
LI Pets's Avatar
Step 2
Please realize these pic are after the work was done.
I removed both skins placed the door face down with a jig on each side (only one is in pic.
Using the rivet holes from the outer skin I used wood screws to force the frame into the form.
It didn't take a lot of force there are holes every 6 inches or so.
Now that the frame conforms to the jig I replace the inside skin.
But I leave the frame screwed into the jig until the whole inner skin is secure.
I used the old holes. and added 6 new rivets on each side to lock the frame in this shape.
WBCCI
Old 10-13-2006, 02:34 PM   #33
LI Pets
Silver Mist
LI Pets's Avatar
Thumbs up Last step
Remove jig, flip it over the door now has its corrected shape.
Use the other half of the jig just to keep everything stable, it is not attached, it is just cradled in it for support until the outside skin is put back in place.
It took me about 3 1/2 hours start to finish.
It fit perfect.
WBCCI
Old 06-27-2008, 10:41 AM   #34
sharbours
sharbours
Profile:  1975 Argosy 24
West Linn , Oregon
Sprung door quick fix
This is more of an emergency repair method, but it will correct a 1/2" or so of spring in the door, and can be done almost anywhere in an hour or so. I used this on my 75 Argosy when the deadbolt failed, and the door blew open twice at 60MPH before we realized the deadbolt was the problem, and not my faulty memory. :-)
Buy 3 large ratcheting nylon straps, long enough to go completely around the door vertically, top to bottom. Slowly tighten the straps, being careful to tighten them as evenly as possible. This will take some effort. Eyeball it carefully. When you feel it has corrected some of the "sprung", release everything carefully, and test the fit. The door will relax some after you loosen the ratchets, but it should be a closer fit every time you test it. Repeat until it fits, or you're too nervous to proceed. About half the rivets on the inside panel of my door had weakened during the original event, so this rebending process finished most of them off. Replace any needed rivets. Using this method I was able to correct a 5" gap at the top to a 1/2" gap, which will suffice until I can take it apart and fix it correctly.
sharbours is offline   Reply With Quote
Door Catches niftypkg Doors & Locks 4 05-22-2007 05:09 PM
Bent (?) Door Jabba Doors & Locks 1 10-26-2002 10:44 PM
Airabelle has sprung her door jeanarlene 1969 - 1973 Safari 11 10-11-2002 03:00 PM
Door Seal Types ??? Road Ruler Doors & Locks 3 09-07-2002 05:53 PM
Bent Trailer Door Argosy74 Doors & Locks 3 09-03-2002 08:31 AM
