Old 07-01-2011, 07:14 AM   #43
Originally Posted by manymemories View Post
mine doesnt have any cracks.there is about 1/2 inch gap at the top of door on the latch side.it fits good at the latch and at the top curve but there is a gap in between.i still have both inner and outer skins on and they all have tight rivets.im sure i will have to take the inner one off but not sure what to do after that.i do have a torch set but i do have my reservations about heat and alluminium.any other tricks in your bag besides cutting and welding?by the way,thank you andy for all your threads here.every problem i have with my AS you have answered in other threads.
Your door has a cast frame.
You will need to remove the inner metal.
Then, and this won't be easy, locate the point where the frame stretched. Then you will need to cut the frame at that point, and have it welded.
Reinstall the inner metal, using all NEW holes. after that's done, the fill all the old holes with rivets.
Attempting to rebend the door frame back to it's original shape, usually leads to more problems, such as cracking the frame.
Typically, the frame stretched at the door lock area.
Old 12-28-2011, 04:09 PM   #44
1964 26' Overlander
Renton , Washington
Your gap is only 1/2"? Mine's about an inch.
How do you get the door off?
How do you get the door back on?
One of the forum post says that you can use heat to make the metal remember its shape. How much heat?
I live in Seattle, so I don't have many dry days to work on the door. Is there any way to bang it back into shape while it's still on the frame?
I just fix the floor and now it's raining on it. Arrrrggggh!
dejahardy13 is offline   Reply With Quote
Old 12-29-2011, 07:04 AM   #45
Silver Mist
LI Pets's Avatar
1977 31' Sovereign
Riverhead , New York
build a jig based off the trailer frame, trace the shape out of a 2x6, use clamps or screws thru the old rivet holds to bring it back to shape 100%
ID:	147781   Click image for larger version
'77 Sovereign Intl 31' CB
Old 11-07-2013, 08:51 PM   #46
FunderStreaming
JohnRFunderb's Avatar
1999 28' Excella
Seattle , Washington
Fixing Warped/Bent Door
My door was vandalized , and bent out from the lock side by a crow-bar by about a foot!
Following Bob's guidance, I built a 2" by 6" wood jig by tracing the curvature of the doorframe, but cut about 1/2-inch extra wood off the bottom 2 feet of the jig, so I could stress/over-flex the major bent part of the frame, in case it had some rebound. Then, I screwed the upper half of the frame to the jig with # 6 screws that approximate the door skin rivets diameter, and fit the holes in the door frame perimeter.
For the warped bottom half of the door, I then heated the frame with a heat gun, and gradually strained the bottom of the frame down onto the jig, using the ratcheting cargo straps. This process for the bottom half of the door took over an hour. After the bottom of the doorframe fit the jig, I screwed it onto the jig too, then more heat gun, and then about 4 hours of cooling.
Don't forget that you have to put the outer skin back on first, and then you have to tighten the door part of the hinge apparatus - you can only tighten the hinge nuts from the "inside" of the door. I did not MARK the hinge original positions on the outer door skin, and I had trouble with the door fit (same width on left and right sides, inside the door frame). Then I realized the weight of the door was a big factor in the alignment, and fixed that by doing adjustments with the door placed on the hinges with pseudo-hinge pins, while the inner skin was OFF. Once I had the hinge placements tightened up, everything fit.
Total time to remove the hinge pins, outer and inner skins, build jig, warp the door (with heat) back on the jig (twice), and re-align, and re-assemble the door, was about 24 hours.
But it beats the $4,000 I was quoted by the local AS dealer for a new door! After parts and cost of a heat gun, I was paying myself about $150/hour.
In my opinion, this amount of work is not worth the time, for door adjustments of less than 1/2-inch. I think there is an easier way.
The FunderStream rehab is complete, and we are hitting the highway! JohnF______
_____________________________________
1998 Excella 28'
2008 Toyota Tundra 5.7L with HAHA
JohnRFunderb is offline   Reply With Quote
Old 03-20-2014, 07:26 PM   #47
VNO
1975 Argosy 24
Germantown , Tennessee
can you purchase new doors from airstream or buy it from a used parts airstream
dealer?
Eaglemate is offline   Reply With Quote
Old 03-21-2014, 08:15 AM   #48
dealer?
New entrance doors are available, but rather expensive.
Old 09-19-2014, 12:08 AM   #49
1978 Argosy Minuet 6.0 Metre
Athens , Georgia
My ARGOSY door sprung at 60mph, and now I have a problem I hope soeone can help with.
I recently picked up my ARGOSY from the shop, so this was the maiden voyage. While at the shop the new latch had to be pushed in hard to catch, but I didn't think too much about it,and the dead bolt was very hard to get in. In fact the dead bolt never really seated and thus the sprung door later that day on the first leg of the journey.
At an interim location I removed the door, inner skins, weather bead, and latch/lock assy. I rebent the frame, and installed a long piece of AL on the door's latch side that I riveted the hell outta because the door cracked at the latch hole. The door is firmly holding its shape. I had to order new AL for the interior skin because the old skins have gaps in the corners with the new "improved" door shape. The Al will be in on Tuesday/Wed...next week.
Now the door is hung nicely (sans interior skins), it fits flush, and the latch hole doesn't line up at all. If the door is pushed in, past flush by 1/4" - 1/2 ", until it bottoms out in the door frame, the the latch will barely catch. Not only is the latch hole in the trailer frame not matching up, but the latch is only going in by about 1/8"! No wonder the door sprung! If I slide the door forward on the hinges so the latch can hold, then there will be a huge gap at the rear and there will be no space for the weather seal at the front! What gives!
I'm at the end of my rope and the trip hasn't even started yet!
Thanks!
MIKO in Tennessee.
MIKO92 is offline   Reply With Quote
Old 09-19-2014, 12:18 AM   #50
Athens , Georgia
ARgosy latch won't latch
Here is a picture of the ARGOSY latch dilemma.
Name:	ARGOSY open latch.jpg
Old 09-19-2014, 12:26 AM   #51
ROBERTSUNRUS's Avatar
Salem , Oregon
Images: 18
Hi, instead of moving your door forward, maybe you space back your striker plate.
2005 Safari 25-B
"Le Petit Chateau Argent"
[ Small Silver Castle ]
YAMAHA 2400 / AIR #12144
Old 09-20-2014, 12:55 PM   #52
Athens , Georgia
Perhaps a picture may help?
I attach 2 drawings of the current door situation (which may or may not have been precipitated by the blow-open incident).
It seems that moving the striker plat may be an option, if one were installed. The latch was fitting (albeit with great effort and compression of the weather seal) into the "pocket" that is cut into the door jamb, before the incident. The door was also not flush when closed, before the incident. Now that I know a little better, I would like to fit the door flush when the latch engages the striker/pocket hole. perhaps getting and moving a striker plate might help? I will ask the local RV shop, and see what they can supply me with, in terms of striker plates, eh?
Please note that the latch is shown only to relate its position in the door and the jamb/pocket.
THANKS!
Name:	door problem 1.jpg
ID:	222359   Click image for larger version
Name:	door problem 2.jpg
Old 09-20-2014, 01:11 PM   #53
THANKS!
Drill out the rivets that hold the striker plate, and move the plate as necessary.
I suspect that the plate was previously moved to compensate for excessive wear on the old lock's striker bolt.
Old 09-21-2014, 12:18 AM   #54
Athens , Georgia
No Striker plate installed
Andy,
Thanks for the suggestion.
There is no striker plate, now. Should I get one? If I install it and line up the opening in the striker plate so the striker will go into the striker plate, then the striker will not be in the pocket, and only two rivets will be holding the whole door closed. Is this normal? More importantly, is that safe? Is the striker designed to fit into the pocket?
Is it possible that the door itself is not matched with the trailer? The door I bought the trailer with had blown open several times before, and there was extensive cracking on the door frame. As part of the work I had done, I asked the fellow doing the work to see if he could get a new door frame. He said that he "found" a new door frame (when I picked the trailer up after a new floor and paint, the door frame was not cracked, but it was very hard to close - had to go in past flush to get the striker to catch ). Could the new door be wrong? This seems hard to imagine because the physical constant is the lock assembly dimensions, and the distance from the striker pocket to the outer edge of the trailer skin.
Thanks a lot for looking into this. I appreciate your time!
Name:	door problem4.jpg
Old 09-21-2014, 12:42 PM   #55
Andy,
It appeasrs that the door was not installed correctly.
The hinges should be loosened and the door moved closer to the jamb, on the opening side.
Next, a striker plate must be installed, and yes, with 2 3/16 inch pop rivets.
Striker plates have been installed that way for many decades.
Make sure you install the plate so that the door is properly latched, when it's flush with the door jamb.
Old 10-06-2014, 10:54 PM   #56
Athens , Georgia
ARGOSY striker plate and door seal
Hello, all.
I am very thankful for the advice and experiences of the whole forum. Thanks to Andy from Inland RV who took time while in Hawaii to write!
I installed a home made striker plate (attachment 1) and got the door closing flush. Attachment 2 shows a top view of the striker plate. Note that the hole (pocket) is outside of the pocket in the door jamb (attachment 3) and the striker plate sticks out...is this normal? I put on new inner skins and made sure the door fit flush.
Then I installed the weather seal, and it got in the way. The seal was getting between the door and the striker, keeping it from closing and latching (where the yellow 3M sealant is in attachment 4) , so I trimmed the seal, but now I am not too sure whether that is the way things usually go...because the striker plate was hitting the seal (where the yellow 3M sealant is in attachment 4).
When the door fits flush from the outside, the seal has about 1/4 inch of sunlight coming through the top of the door frame. What is the next step?
The frame, incidentally, is from another airstream of unknown year or type. The shop that painted the ARGOSY had a frame that wasn't cracked, like the one I got from the PO, so they skinned it and painted it and it is what is hanging in my doorway, now...kind of like getting a new door I suppose. Is it possible that the frame I got was the "wrong" size? How much door size variation is there between model years?
Thanks alot for the time and I really am enjoying this...
MIKO in Tennessee.
Name:	striker plate 1 copy.jpg
ID:	223843   Click image for larger version
Name:	striker plate 3 copy.jpg
Name:	striker plate 2 copy.jpg
ID:	223845   Click image for larger version
Name:	bugged door seal 1.jpg
Airabelle has sprung her door jeanarlene 1969 - 1973 Safari 12 02-06-2011 12:09 PM
Door Catches niftypkg Doors & Locks 4 05-22-2007 05:09 PM
Bent (?) Door Jabba Doors & Locks 1 10-26-2002 10:44 PM
Door Seal Types ??? Road Ruler Doors & Locks 3 09-07-2002 05:53 PM
Bent Trailer Door Argosy74 Doors & Locks 3 09-03-2002 08:31 AM
