Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Windows, Doors, Locks & Vents > Doors & Locks
Old 06-11-2008, 09:39 PM   #1
Siddhartha
Siddhartha's Avatar
Profile:  Berkeley , California
Another saggy door story
The top hinge on my 1990 300LE MC door is loose and the screws are stripped. There must be an easy way to secure it so I don't have to pull the door up and slam it so hard each time. Yes? What does one do for stripped mounting screws?
Sid
Siddhartha is offline   Reply With Quote
Old 06-11-2008, 09:54 PM   #2
bake315
bake315's Avatar
Profile:  1994 34' Limited
Elgin , Texas
Images: 161
Hi Sid,
I don't know if this will help you or not, but I had pretty much the same issue on my trailer; couldn't get the screws to tighten on the hinge where it attached to the trailer. Inside the wall there are nuts on the other end of the screws. A lot of Sikaflex, or possibly Vulkem was used to seal around them on the inside. At some point, those nuts worked loose, breaking free from the sealant, and would then just spin on the end of the screws, unable to re-seat themselves. I had to drill the rivets on the door frame trim, and ease the interior metal back to the point where I was able to at least get a wrench on them. They are still not as tight as I would like - will have to go back in at some point in the future and see if I can snug them up a little more. You can get to them, but that's sort of what's involved.
Cheers, Dave
"Finish."
AIR #4188
1994 34' Limited / 2002 Chevy 3500 CC 4x4 D/A Equal-i-zer Hitch / Jordan Ultima 2020
bake315 is offline   Reply With Quote
Old 06-12-2008, 08:12 AM   #3
Siddhartha
Siddhartha's Avatar
Thanks for the quick response Dave. I don't think I'm ready to drill rivets just yet. But I'll save your solution.
Sid
Old 06-12-2008, 08:17 AM   #4
overlander63
overlander63's Avatar
Profile:  1974 31' Sovereign
On The Road , Fulltiming
Images: 58
The drilling isn't that bad, just take your time with it. At least your hinge mounting point isn't behind a ton of "stuff", it's relatively open in that area. Many of us have counters, cabinets, etc. there.
Are you a Herman Hess fan?
Change is inevitable, except from a vending machine
AIR#2611
overlander63 is online now   Reply With Quote
Old 06-12-2008, 10:29 PM   #5
Siddhartha
Siddhartha's Avatar
Good call. After a long and arduous search, Hermann Hesse's protagonist found nirvana at last on the bank of a river, listening to the water flow. I've found mine on the side of the highway, listening to the cars and trucks go "zoom, zoom", so I thought it fitting.
"There is no reality except the one contained within us," Hesse once said. "That is why so many people live such an unreal life. They take the images outside them for reality and never allow the world within to assert itself."
Old 07-24-2008, 07:37 PM   #6
3 Dog Nite
3 Dog Nite's Avatar
Profile:  Baldwinsville , New York
Airstream mechanic's advice
I recently stopped by the Airstream factory for a tour. While there, I inquired about purchasing some new screws as I thought they were stripped out too. A mechanic came out to look for the proper screws. After a quick look, he told me that they normally tighten the screw & nut, then they put a second nut to hold it tight. I asked why not use Loc-tite? He said it will just come loose again over time. Unfortunately, you still have to pull the inside panel off to gain acces to the nuts located inside the door jamb. I'm not looking forward to doing it as I'm fulltiming without a shop to work out of. I figure I'll just do it in a hardware store's parking lot after removing the panel. I wish us both luck in this paticular repair.
3 Dog Nite is offline   Reply With Quote
Saggy bathroom csham General Repair Forum 12 03-21-2008 05:37 PM
Saggy floor - rear door 24 Janet General Interior Topics 9 10-15-2006 07:43 PM
Saggy Bottom ( rear end ) smily Repairing/Replacing Floor &/or Frame 127 10-01-2006 08:28 PM
Saggy Bottom RONALD DODA Interior Restoration Forum 3 06-02-2005 07:42 AM
Saggy As$ '72 J-n-A Our Community 1 08-08-2003 11:10 AM
Cooking Forum - Sailing Forum - Early Retirement
Airstream Trailer Forum - Aquarium & Reef Forum
Royal Forum - Book and Reader Forum - Yoga Forum
Volkswagen Touareg Forum - Jeep Wrangler Forum
Whitewater Kayaking & Rafting Forum - Yoga Forum
U2 Forums
