Old 05-04-2005, 08:04 PM   #1
Arrow Access panel door replacement
I have a 65' safari in restoration and need an access panel. I have had no luck finding a used one. Any ideas on fabricating one or leads on finding one.
Thanks, Lou
Lou Bartell is offline   Reply With Quote
Old 05-04-2005, 08:29 PM   #2
Old Paint, rolling again.
sfixx's Avatar
1973 Argosy 20
Lorain County , Ohio
Images: 12
Thumbs up
Hi Lou, I fabricated mine but I was lucky because I still had the aluminum extrusion that is the 1/2 of the hinge that attaches to the door. I simply riveted it to a piece of aluminum that I cut out.
Perhaps you don't need the hinge, just something that will grab behind the opening on the edge oposite of your cylinder lock. Perhaps a piece of aluminum "C" channel riveted to the edge of the door would work. I'll draw a quick picture of what I'm thinking:
Best of luck,
Steve
Have you never questioned those who travel? Have you paid no regard to their accounts- Job 21:29
sfixx is offline   Reply With Quote
Old 05-08-2005, 08:07 PM   #3
Barkingdogg's Avatar
Newcastle , Oklahoma
Post Access door panel
Hi, You might check with Tom at the following link. I believe he said he could make new panels, with locks.
www.griffithrvservice.com
Barkingdogg
Barkingdogg is offline   Reply With Quote
Old 05-09-2005, 06:06 AM   #4
InlandRV.com used to list some on their site.
joatmon is offline   Reply With Quote
Old 05-09-2005, 08:38 AM   #5
rluhr's Avatar
1968 17' Caravel
2005 30' Safari
Somewhere , roaming America
Check with forum member robandzoe -- he has one or two salvaged off other trailers. One might fit your '65.
Former full-timer | AIRSTREAM LIFE magazine | Tour of America (old blog) | Man In The Maze (current blog)
rluhr is offline   Reply With Quote
Old 05-09-2005, 08:44 AM   #6
47WeeWind's Avatar
1948 16' Wee Wind
1953 21' Flying Cloud
Denver , Colorado
Images: 20
Fabricating an access panel
Originally Posted by Lou Bartell
I have a 65' safari in restoration and need an access panel. I have had no luck finding a used one. Any ideas on fabricating one or leads on finding one. Thanks, Lou
Hi Lou:
My 1964 Globe Trotter may, or may not, have access panels similar to your '65 Safari. Mine needed a new 39.5" wide X 14" high panel for the rear service center. I went to a local metal shop and looked in their scrap pile. I found a piece of 1/16" thick aluminum plate and had them cut it to size in their metal brake (shear). The panel width was a tad less than the actual width of the opening, which had inset edges against which the panel door would rest. The panel height was slightly greater than the opening height since my opening has an inset groove along the top into which the panel slips. I added a keyed lock at the center bottom to hold it in place.
The 1/16th" thickness works great. It is thin enough to fit into the groove across the top of the opening yet is thick enough to be stiff and solid when installed. Hope this helps or gives you a similar idea.
Fred Coldwell, WBCCI #1510, AIR #2675
Denver, Colorado - WBCCI Unit 24
Airstream Life "Old Aluminum"
Airstream Life
"From the Archives"
47WeeWind is offline   Reply With Quote
Old 05-09-2005, 02:32 PM   #7
AYRSTRM2's Avatar
1966 22' Safari
Armada , Michigan
Inland RV does sell those doors. We had to get one last year, when our batter came loose and popped out the old one. they aren't cheap, and the have slightly different handle configuration than the original, but they work. I suspect they have someone fab them as needed.
AYRSTRM2 is offline   Reply With Quote
Old 05-09-2005, 04:12 PM   #8
robandzoe's Avatar
1958 30' Sovereign of the Road
Plymouth , New York
Send a message via Skype™ to robandzoe
Actually 3
I have the three access panels from a 1968 Overlander. The fridge, and the two under the center twins. I'll have to measure them and let you know what size. $15 each if interested.
Rob
Rob, Zoe', Stanton, Bryce, Braedon and Finn Baker
Do you Listen to the www.theVAP.com
Plymouth, NY 13832
http://bakersacresofchenango.blogspot.com/
Courtesy parking
Flag Pole Holders - http://robsflagpoleholders.blogspot.com/
robandzoe is offline   Reply With Quote
Old 05-09-2005, 04:17 PM   #9
Originally Posted by robandzoe
...The fridge, and the two under the center twins...
Out of curiosity, one of those doors probably covers battery access. What does the other one protect?
Solar Panel Installation 69Overlander Generators & Solar Power 28 03-03-2013 08:18 PM
replacement panel maznblu Ribs, Skins & Rivets 4 09-18-2002 05:45 PM
Dented panel replaced Jim W Ribs, Skins & Rivets 1 07-08-2002 07:07 PM
Display Panel ALANSD Mechanics Corner - Engines, Transmission & More... 4 06-08-2002 03:28 PM
61 Bambi Panel Replacement 61BambiCanada Ribs, Skins & Rivets 0 06-07-2002 09:41 AM
