Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Windows, Doors, Locks & Vents > Doors & Locks
Old 06-07-2015, 12:10 PM   #1
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
90s Airstream Locks
1.Are all the outdoor compartment locks are the same type locks? I am able to get into all the compartments except the 2 battery compartments.
They don't look like you can replace the cylinder, just the whole lock for $18 at Inland RV.
2. Is the main door lock located on the door latch the same type lock? Looks like it might be.
Marshall
ID:	240193   Click image for larger version
Old 06-07-2015, 01:09 PM   #2
CBWELL's Avatar
1994 34' Excella
Warren , Manitoba
Battery compartment are the cheap RV locks you can get at any RV store for $6-$10. I just drilled mine out, and replaced with the cheap locks. Easy 15 minute job. Water fill lock is the same cheapie. Main door key is totally different from the battery boxes. Chris
ACI #7394
2012 GMC 2500 HD Duramax Denali
1994 Excella 34'
1987 Limited 34', 1976 31', 1976 Argosy 22' Gone to new homes
Hensley Hitch
CBWELL is offline   Reply With Quote
Old 06-07-2015, 06:25 PM   #3
Skater's Avatar
1995 30' Excella
Bowie , Maryland
On ours, they aren't. We have four different keys, using different blanks, for ours (door, battery, water fill, back compartment). Kind of annoying! I assume this is because they use off-the-shelf locks for each spot, so there's no relatively inexpensive way to standardize. A previous owner etched the purpose of each key on it.
Is it a matter of you just not having the key (as opposed to a broken lock)? If so, try to find someone nearby with a similar Airstream, or call Airstream - you might find their key will work. Turns out a lot of them are the same...
1995 Airstream Classic 30' Excella 1000
2014 Ram 2500 Crew Cab with Cummins 6.7L Diesel
Sold but not forgotten: 1991 Airstream B190
Sold: 2006 F-250 6.0L Powerstroke Supercab
Skater is offline   Reply With Quote
Old 06-07-2015, 07:47 PM   #4
richinny's Avatar
2011 34' Classic
many of the cylinders have code numbers stamped on the front. airstream parts dealers. the mothership might even be able to get you a door key.
Ricky
Old 06-07-2015, 09:41 PM   #5
CRH
1995 25' Excella
xxxxx , xxxxxx
If the cylinder has a code, you can order a key off eBay.
CRH is offline   Reply With Quote
FT in a '90s Airstream? kb0zke Full-Timing 11 02-08-2015 05:04 PM
Wheel Locks, coupler locks Toasty's Dad Hitches, Couplers & Balls 10 03-06-2008 11:55 PM
Comparing... '80s Avion...to...Early '90s Airstream..?? route66 Full-Timing 6 04-29-2006 09:28 AM
Looking for late 80s early 90s Airstream James Hosey Member Introductions 0 01-01-2006 08:49 PM
coach width change from 80s to 90s bake315 1989-1992 Limited 0 04-20-2004 03:34 PM
