Old 02-18-2010, 02:05 PM   #1
1978 28' Ambassador
Savannah , Georgia
'78 Ambassador Door Lock
Name:	Airstream78 Inside door latch2.jpg
Name:	Airstream78 Backside of door latch in door.jpg
Here is what is left of door lock. Think I am missing something. Looked at old diagrams, but can't figure it out. Help would be appreciated. Thanks. Jack
Skamper1 is offline   Reply With Quote
Old 02-18-2010, 04:41 PM   #2
Originally Posted by Skamper1 View Post
Attachment 96464
Attachment 96465
The company that made that lock has been out of business for many years.
No parts are available.
All you can do is sort of make do with what you have or replace the entire lock.
Old 03-04-2010, 06:16 AM   #3
1978 28' Ambassador
Savannah , Georgia
Where oh where has my gasket gone?
Took Keeler doorlock to locksmith. Cleaned it up and it appears to be working. Had a key made. Now to reinstall. The diagram shows a gasket. Can I make one or do I really need one?
Old 03-04-2010, 12:42 PM   #4
tlavergne's Avatar
1978 28' Ambassador
Kenton , Ohio
I bet you could make one.
Tom
"Without music to decorate it, time is just a bunch of boring production deadlines or dates by which bills must be paid." -- Frank Zappa
tlavergne is offline   Reply With Quote
Old 03-04-2010, 02:01 PM   #5
1978 28' Ambassador
Savannah , Georgia
Knew I probably could cut one out. Question is where does one get a blank gasket? What material? And does the gasket go on the inside (between faceplate and door) or the outside (between doorlatch and door) of the doorlock? There is a bead of cahlking around the outside plate. Inside the door is vinyl. Thanks. Jack
Old 03-04-2010, 03:30 PM   #6
tlavergne's Avatar
1978 28' Ambassador
Kenton , Ohio
I don't see a gasket on mine to see the thickness or the material. Mine is sealed with silicon from a PO. It works so I leave it alone. If I were to take it off and re-do it I would probably lay a bead of vulkum or parbond around the outside plate of the lock and install it. Make sure to have alcohol or acetone to clean up the extra that squirts out.
