Old 07-29-2014, 01:01 PM   #1
racoco's Avatar
1976 31' Sovereign
2007 19' Bambi
Midland , Texas
'76 door lock question
While I think I already know the answer; does anyone know a source for repairing this lock?
(clearly I don't know how the "insert image" function works. I'll keep trying and will post it eventually.)
Key just spins now. AS is a 1976 Sovereign. Everything still works except the locking function.
Any help, suggestions, comments much appreciated.
Coco
1976 Sovereign & 75th Anniv Bambi
TAC TX-3
racoco is offline   Reply With Quote
Old 07-29-2014, 01:06 PM   #2
racoco's Avatar
1976 31' Sovereign
2007 19' Bambi
Midland , Texas
Figured out the posting of an image... This is the lock in question. Again, thanks for any help, it is much appreciated.
Coco
TAC TX-3
Old 07-29-2014, 01:16 PM   #3
1973 23' Safari
Encino , California
out of door mart sells the internal springs, take care once apart. The cosmetic outer edge is pot metal and will fracture when pounding on the alignment pins.
Land Shark is offline   Reply With Quote
Old 07-29-2014, 01:18 PM   #4
Silver Hawk's Avatar
1975 31' Sovereign
Palomar Mountain , California
Easy to take apart (from the inside). You'll have to go inside and see whats happening - they're real simple, I fixed mine. Worst case - somethings broken and you need a new lock - they are sold by Vintage and Andy. Might just be a bad cylinder - easy to get new one at lock shop.
Silver Hawk is offline   Reply With Quote
Old 07-29-2014, 07:42 PM   #5
racoco's Avatar
1976 31' Sovereign
2007 19' Bambi
Midland , Texas
Banking on the cylinder. Ordered one to rework it before the weekend but the urgency gave way so I have sometime. Thanks for the tips. I appreciate the help.
But now that I've moved the first pawn, let the renovation games begin.
Coco
TAC TX-3
Old 07-29-2014, 07:52 PM   #6
DryFly's Avatar
1972 Argosy 20
Snoqualmie , Washington
I had the same thing happen on my 72 Argosy. I took it apart and cleaned the moveables, used WD40, and re-assembled. The lock works well now.
These things are a very simple mechanism, so if there is a broken part you'll see it immediately. If not, clean, lubricate, and you're probably good to go.
Do be careful though, they are easy to break
DryFly is offline   Reply With Quote
Old 08-03-2014, 03:12 PM   #7
racoco's Avatar
1976 31' Sovereign
2007 19' Bambi
Midland , Texas
So does anyone know how to "slip" the lock out go the door??
Got the lock loose and ready to pull, but with catch open and angling out, the knob arm is to long to clear the hole. A little stuck.
Thanks.
Coco
TAC TX-3
Old 08-03-2014, 05:45 PM   #8
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Don't know what you mean by the "knob arm". If it is the interior handle. It can be removed.
You may have to drill a few rivets out on the interior skin to give you the additional clearance.
Old 08-03-2014, 08:17 PM   #9
racoco's Avatar
1976 31' Sovereign
2007 19' Bambi
Midland , Texas
Yes, the arm the interior handle attaches to. Handles off, set screw was easy, but like I explained earlier, the arm just won't quite clear the hole it projects through. Close, but no.
Feel like the lock should slip right out but obviously I'm missing something. Thanks.
Coco
TAC TX-3
Old 09-02-2014, 04:59 PM   #10
racoco's Avatar
1976 31' Sovereign
2007 19' Bambi
Midland , Texas
And I should have listened to my wife.
Service manual got here and procedure for lock removal is exactly what she said. Drill out a few near by rivets on the inside of the door and gently lift inner skin enough to clear lock arm and slide lock out.
Not what I was expecting.
Coco
TAC TX-3
Old 09-08-2014, 06:42 AM   #11
There are a couple of dealers that repair KT locks.
Door lock won't when door closed Savage68 All Argosy Trailers 17 06-12-2014 07:39 AM
Accordion Door For Bathroom and Door Lock - 1963 Jinji 1960 - 1964 Globetrotter 2 11-13-2013 07:17 AM
Argosy Motorhome door lock question Belle Argosy Motorhomes 7 03-31-2013 05:01 AM
Door Lock Loose interior Lock Pin.. Bootsinister Doors & Locks 12 10-08-2012 10:19 AM
'67 Caravel Door lock Question vonzellen Doors & Locks 14 11-29-2011 01:26 PM
