Old 12-17-2012, 09:50 PM   #1
shadeemry's Avatar
1975 31' Sovereign
cary , North Carolina
'75 KT lock, roll pins?
So, I have sought to rebuild this lock. I have all the pieaces as well as the lock cylinder(original) and extra spare blank key, But I am having some problems pulling the pins out of the "paddle?" theirs 2, I was able to drill one out, but the other one I cant seem to get the bit to hit it dead center, or grab it, the pins are rusted out. heres some pics...
My question is, do I take this to a machine shop? or can I do it here at home? im not worried about the the pin the paddle connects to, I just have to get it out, so I can replace it.
Name:	DSC07755 (Large).jpg
ID:	174849   Click image for larger version
Name:	DSC07758 (Large).jpg
shadeemry is offline   Reply With Quote
Old 12-18-2012, 01:00 AM   #2
shadeemry's Avatar
1975 31' Sovereign
THe piece I'm trying to replace is the vertical shaft, and the lever spring, so as a not, if I have to cut the vertical shaft out, I'm not opposed.
Old 12-18-2012, 03:28 AM   #3
sandlapper's Avatar
1993 34' Excella
York , South Carolina
Shad, those look like roll pins, which are hard steel and may be difficult to drill out. A drill press , running slow with some cutting oil, and a clamp might get it done.
Have you tried soaking them with a good penetrating oil and then a drift punch?
John
John
WBCCI #268 Palmetto State Airstream Club 22
Region 3 President....come with us, you will like it.
Go often to the house of a friend, for weeds choke the unused path........Emerson
Are you kind?
sandlapper is offline   Reply With Quote
Old 12-18-2012, 05:41 AM   #4
overlander63's Avatar
1993 21' Sovereign
Colfax , North Carolina
You're not that far away from your local dealer, and it would probably be worth your time to take the lock there for repair. I know they have the parts, and the guy I suspect will be given the task of repairing it has a KT lock, and knows how to repair them.
Old 12-18-2012, 05:57 AM   #5
shadeemry's Avatar
1975 31' Sovereign
John
I'll try the drift punch, but doesn't that require that you have access to both sides?
Old 12-18-2012, 06:38 AM   #6
Aerowood's Avatar
1971 21' Globetrotter
Arvada , Colorado
Are you using a roll pin punch, as they have a small ball on the end to stay centered on the pin. they are designed for removing roll pins
Amazon.com: Craftsman 9-43167 Roll Pin Punch Set, 6-Piece: Home Improvement
Old 12-18-2012, 06:55 AM   #7
shadeemry's Avatar
1975 31' Sovereign
Im pretty new at this roll pin thing, do I insert the punch and use it to pull out? As far as I can tell, these are blind holes, the roll pins cant slide out a back, its right against the handle itself, and these have to be removed in order to pull the vertical shaft out to replace it.
Old 12-18-2012, 10:07 AM   #8
sandlapper's Avatar
1993 34' Excella
Shad , if it is indeed a roll pin it will need to be punched out, requiring, as you noted, access to the back side. The proper punch would also maker an easier task.
I don't know how much beating and banging the lock can take before it breaks. Some penetrating oil may help.
John
John
Are you kind?
Old 12-19-2012, 08:08 AM   #9
Aerowood's Avatar
Arvada , Colorado
I don't remember if the holes went all the way through or not. The tools I showed you are for removing pins that are in though holes.
I removed my KT latch, sold it and replaced it with a different type of latch that only cost 40 bucks. I had to reskin the door anyway because it was in sad shape. Its all in my thread below as to how I did this.
Old 12-19-2012, 01:51 PM   #10
shadeemry's Avatar
1975 31' Sovereign
So it turns out the kt locks are not dead end holes, their very tricky..
And you HAVE to be careful, this locks are made of pot metal.
The holes diameter looks to be 1/16 boarding 1/8. Their standard roll pins.
Old 01-07-2013, 10:06 PM   #11
Skatiero's Avatar
1986 32' Excella
Canton , Georgia
I know this is to late to help but I just came across this thread since I share the login with my wife. I have been a certified locksmith for 25 years and I have removed hundreds of blind roll pins over the years in car ignition locks,safes etc. so I thought I would let you know how I did it. First, use a small drill bit, usually somewhere in the 1/16 to 1/8 range and start drilling a hole parallel next to the roll pin. As soon as the bit starts cutting, turn and angle the drilling at about a 45 degree angle to the pin and drill towards it until you just nick it and then stop. (I do it like this because its to hard to start drilling on a curved surface at a 45 degree angle) You have now created a place for leverage. Then I take an awl or some people call it a scratch awl with a nice point ground on the end of it and with the hardware or lock in a vise or somewhere where you can push hard away from yourself and or hands so you don't stab yourself you push into the hole you drilled against the roll pin and pry up. The roll pin will come up enough to grab it with good plyers. This hole will not damage the integrity of the roll pin or hardware and can be tapped back in after service. I used to take a little lead shot ball and tap it in the hole I drilled afterwards and file it smooth to cosmetically make the hole disappear.
Skatiero is offline   Reply With Quote
Old 03-12-2013, 05:59 PM   #12
Moderator Emeritus
Pick's Avatar
1972 31' Sovereign
High Springs , Florida
Images: 36
Mine just bit the dust this weekend. Had to cut the front screen out to gain access to open the door.
I got the latch out and it appears that one of the roll pins rusted completely away, and the other one was partly rusted and failed due to the extra load on it.
Got it apart, so all I need to do is get the remnants out and put new pins in. Otherwise lock set is in good shape except for the actual latch bolt, which is worn.
I am thinking of filling it in with a mig welder and then grinding it back down to "normal". Has anyone done this?
ARS WA8ZYT
Propane Powered Honda EU2000i
Lots of Hot Sauce!
Air # 283
WBCCI 1350
Old 03-19-2013, 10:41 PM   #13
shadeemry's Avatar
1975 31' Sovereign
Got pics so we can see better? And don't weld that at all..it's pot metal..that would destroy that lock so I'm told.
Old 03-27-2013, 09:39 AM   #14
Moderator Emeritus
Pick's Avatar
1972 31' Sovereign
Images: 36
The only part that I was going to fill in weld was the actual bolt. It does not appear to be made of "pot metal", but of some kind of steel.
RickDavis was a guest for a weekend, and he and I decided to fill in the groove with JB Weld. I have not used the door much, since the new roll pins and fill in were performed, just about once a day to open/close windows and vents.
I will post some pictures after I am able to re-size them, for the forum.
ARS WA8ZYT
Lots of Hot Sauce!
Air # 283
WBCCI 1350
Exterior door lock replacement 1986 Excella Sov1969 Doors & Locks 3 07-25-2011 06:34 AM
Lock trouble on 1961 AS Ambassador... help please. 61Ambassador Doors & Locks 13 04-21-2011 02:06 PM
Xena Lock With Alarm For Hitch Coupler wjk Hitches, Couplers & Balls 8 04-13-2011 06:27 AM
Modifying a Fastec door lock jeffkraft200 Windows, Doors, Locks & Vents 12 03-26-2011 03:02 PM
