Old 11-22-2010, 01:49 PM   #1
funkill's Avatar
reno , NV
Images: 27
'73 Door Handle went to crap
Long weekend ... for me, my trailer and my truck.
A friend of mine came to me in the campground and said, "I can't get your trailer door to open". Knowing it wasn't locked, my heart instantly sank. I recalled reading too many posts on this site about the handle and it's dubious repair history.... My exterior door handle would pull out but it didn't do anything to unlatch the door. Thankfully, prior posts also mentioned crawling through a rear compartment door to get inside. I wiggled my butt through the compartment and my dog went ape-sheit as she saw me *prairie dogging up" from under the curbside bed. The interior door handle didn't do anything either and the door remained latched until I pushed on the bottom corner of the door with my foot -- and it sprung open. Since it wouldn't relatch in a closed position, I needed to figure out how to secure it for traveling home without it swinging open and ripping off. I remembered some folks using a door stop and/or a custom wedge to place between the door and the adjacent handle to secure the suicide door closed in transit. I scavenged some metal scraps, a spare locking hitch pin, ratcheting straps and Gorilla tape and was able to secure it closed. I wish I had a picture of the contraption but, alais, the camera was inside.
The outside handle no longer springs back to it's flush/flat psition. The interior handle just swings freely. The locking pin is frozen in place and SEEMS to be in the unlocked position.
I see that the KT Lock is not readily available (for under $600+). I also see that Inland RV has a replacement lock/kit available for installation with some door modifications. I guess I want to see what's up with the original first (and I found the diagram someone else posted awhile ago). But, I'm not certain where to start. Is the first step removing the interior door skin - i.e. drilling out all them rivets? Please let me the easiest way to get to the lock!!!
Laura
Who also returned with a rear truck window that would not operate - and it's raining. Figures. Guess I can resume ruminating about my "life change" later...
funkill is offline   Reply With Quote
Old 11-22-2010, 02:03 PM   #2
TG Twinkie's Avatar
1974 Argosy 26
Morrill , Nebraska
Don't buy new yet!
Can you post a photo of the lock? It may be the same as the one on my '74 Argosy. If so, it is a very simple device, once removed from the door you may be able to make the necessary repairs. I didn't have to remove the inside skin to remove mine. I was able to repair it without much of a hassle.
Old 11-22-2010, 02:07 PM   #3
x
XXXX , XXXX
Laura your lock should be the same as my 73. There are 3 screws on the inner door panel holding the lock and one on the edge of the door. Remove them and the inside door handle(screw from below into handle shaft) and the inside lock knob. You should be able to remove the entire lockset now. There is a small split pin on the shaft for the lock bolt. Either the pin has broken or worst case the shaft itself has snapped and the pin location. The split pin is easily purchased and any hardware store(the big orange has them). Can you post any pics of door and lock?
wasagachris is offline   Reply With Quote
Old 11-22-2010, 02:08 PM   #4
noreen&sal's Avatar
1981 27' Excella II
mays landing , South Jersey
I feel your pain. Early this year while camping in Md. woke up to find us locked in. Forced door open. Found a piece of driftwood on the beach and wedged it in for the ride home. Took the latch apart and found 30 year old shavings of aluminum from when it was originally fit to the door. The slide bolt had broke and fell between the door skins. Cut a hole in the inside skin and retrieved it and had it welded back together by a certified welder. It has been working fine ever since. Keep it lubed up. The 30 year old lube just wasnt working anymore. I keep that piece of driftwood just in case. Make sure you dont slam the door [per Andy]. SAL
noreen&sal is offline   Reply With Quote
Old 11-22-2010, 02:13 PM   #5
funkill's Avatar
reno , NV
Images: 27
previously posted by azflycaster
This same door lock is on my trailer... but this one is prettier.
Oh, and an interior pic from my Ophelia. I see the three inside screws! I know what's for dinner tonight.
Laura
ID:	115802   Click image for larger version
Old 11-22-2010, 02:38 PM   #6
arodriguez60's Avatar
1959 22' Flying Cloud
1969 25' Tradewind
1983 34' Limited
fairview , New Mexico
Images: 85
here is an exploded view from out of doors mart. Most of the parts are available
Avion C11
1959 Flying Cloud
1969 Tradewind
1973 Safari
1983 34 ft Limited
2004 F250 superduty ext cab
2014 F350 longbed superduty crewcab
arodriguez60 is offline   Reply With Quote
Old 11-22-2010, 02:46 PM   #7
x
XXXX , XXXX
Laura here's some pics of my trailer and the old lock. Excuse my feeble attempt at marking the pics with paint. They should help.
Name:	Door Lock 001.jpg
ID:	115805   Click image for larger version
Name:	Door Lock 002.jpg
Name:	Door Lock 003.jpg
Old 11-22-2010, 03:42 PM   #8
funkill's Avatar
reno , NV
Images: 27
Screw driver in one hand, Miller Lite in the other. Glad I don't need a flashlight or I'd have to call it quits. I'll report back with my findings. Thanks for the details.
Laura
Old 11-22-2010, 04:36 PM   #9
Aerowood's Avatar
1971 21' Globetrotter
Arvada , Colorado
If you feel like a real adventurer you can replace it with a more modern type. I replaced mine but had to re-skin the door to do it. check it out on my thread below post 231 and then again on post 250
http://www.airforums.com/forums/f416...nte-26902.html
Old 11-22-2010, 06:36 PM   #10
funkill's Avatar
reno , NV
Images: 27
Okay - turned into a two beer, slice of pizza, 6 trips to the house kinda job...
I have to admit to the fact that, generally, women have less upper body strength than men. So, persuading screws out of place can sometimes be a challenge. The third turd of a screw started to strip and I ended up cutting a slot for a straight edge screw driver. Added WD-40 three or four thousand times and got the latch assembly out!!!
Here's what I have - see anything suspect? I haven't identified the culprit yet but first thought is to look closer at the split pin...
Thanks for all the help thus far. Just one doorn thing after another.
Laura
Name:	exterior handle.jpg
ID:	115824   Click image for larger version
Name:	guts bottom view.jpg
ID:	115826   Click image for larger version
Name:	guts end view.jpg
Old 11-22-2010, 06:58 PM   #11
funkill's Avatar
reno , NV
Images: 27
Couple more pictures. I can see what's not working but I don't know why. The split roll pin moves freely forward and aft.
Looks like the end of the Vertical Handle Shaft (SKU 3043) is bent and is no longer making any contact with the split roll pin. And the small snap wire thing probably isn't in the right place either. I don't see how to change this part out - looks like it is press fit in place? I see some details on the Out-of-Doors Mart website but not enough to figure it out right now. Maybe a call to them in the morning will help...
First pic of where the Vertical Handle shaft is not making contact with the pin and is not acting on the spring. Second pic shows the bent lever part of the Vert Handle Shaft.
Laura
Name:	end of vertical handle shaft.jpg
ID:	115832   Click image for larger version
Name:	bent vertical handle shaft - to right.jpg.jpg
Name:	ODM latch parts.jpg
Old 11-22-2010, 07:29 PM   #12
funkill's Avatar
reno , NV
Images: 27
Looks like the (SKU 3006) Small Roll Pin that fits onto the slide bolt (SKU 3045) is either gone or has sheared off. Again, maybe a call to Out-of-Doors Mart will reveal how it is replaced.
Boy - their site has quite a bit of information. Yeah!
Laura
PS - In post #11 above, I erroneously referred to the Slide Bolt as the Split Roll Pin... should have said:
Couple more pictures. I can see what's not working but I don't know why. The SLIDE BOLT moves freely forward and aft.
Looks like the end of the Vertical Handle Shaft (SKU 3043) is bent and is no longer making any contact with the SLIDE BOLT.
Old 11-22-2010, 07:37 PM   #13
funkill's Avatar
reno , NV
Images: 27
Sweet - latches with a "gentle nudge". I don't know what that means
Laura
Old 11-23-2010, 09:12 AM   #14
funkill's Avatar
reno , NV
Images: 27
Also, I presume a good cleaning is in order... then lube with what?
laura
Door Handle - Replacement for 1981 Excella dienst1 General Motorhome Topics 44 10-08-2011 10:36 PM
Looking for door handle- help please old man listening Doors & Locks 10 02-13-2010 12:49 PM
door handle T&Cairstream Doors & Locks 2 12-11-2007 10:58 AM
