Old 01-05-2016, 07:54 AM   #1
1973 31' Sovereign
Chaska , Minnesota
'73 Airstream Deadbolt in Handle
Greetings,
The previous owner drilled out the cylinder of the deadbolt because they lost the key. Looking for a replacement but can't seem to find one. Any leads on where I can purchase one? It's a Schlage lock.
Also, I'm gambling a bit in trying to put in a new cylinder in the KT lock that was also drilled out. I figure a $40 gamble is worth it if it works against the $500 new KT handle lock assembly that doesn't seem to be made anymore. Anyone put in one of the cylinders? Likely will order it from vintage.
Thanks!
Margesbarge is offline   Reply With Quote
Old 01-05-2016, 07:57 AM   #2
BambiTex's Avatar
1967 26' Overlander
1964 17' Bambi II
Clear Lake Shores , Texas
Call a local locksmith. Local guy replaced the one in our Bambi II for $20.
BambiTex is offline   Reply With Quote
Airstream 250 deadbolt woes Boom Sounds Classic Motorhomes 2 04-18-2015 08:53 AM
Outside handle, Deadbolt and Doorbells! Keyair Classic Motorhomes 14 01-23-2012 06:19 PM
1965 globetrotter door handle @ deadbolt dr-quest Exterior Storage Compartments & Access Doors 2 09-05-2011 05:50 AM
Main door handle/deadbolt for Bambi II? PA BAMBI II 1964 Bambi II 1 02-28-2011 09:43 AM
Pls HELP Replacement of Deadbolt in Handle of '90 Elf1 Doors & Locks 8 01-28-2011 08:16 PM
